There really isn't anything more to add about this issue. Is this some odd malfunction? It was brand new out of the package. I even replaced the batteries with new ones. I'm still having the LL display on the small outside remote which is transmitting the same status of LL to the (red) main unit inside.There really isn't anything more to add about this issue. Is this some odd malfunction? It was brand new out of the package. I even replaced the batteries with new ones. I'm still having the LL display on the small outside remote which is transmitting the same status of LL to the (red) main unit inside.
You can't post conmments that contain an email address.
You didn't mention which type of refrigerator you have but the procedure below may work. You have to reset your programming code. If you don't hav the booklet you'll need to call the company and get it. Good Luck.
1. Press and hold the Water Keypad
2. Press and hold the LL Keypad - At this point you're holding two keypads
3. Release the Water Keypad and wait 3 seconds - At this point you're still holding the LL keypad
4. The control will display PE (Programming mode) release the LL keypad
5. Press the LL Keypad once more
6. The control will display the current program code
7. If the code is correct, press and hold the Water Keypad for 3 seconds
You'll need to reset the Electronics Control Computer otherwise called the PCM/ECC/ or ECM. You can do this by unhooking the battery cable for about 15 minutes. If this does not reset it, you may have to do it for up to a day then try hooking the cables up again. See if this works.
Hi: The IR receiver inside the television is becoming intermittent and needs to be replaced. You might also check the connections on the receiver small circuit board for cold or loose solder joints.
Connect it to itunes and update it. However. 4.3.5 isn't much better. It's slow and lags. But it'll fix the phone.
Usually when the phone hangs like that on the logo. It just needs to be hooked up to itunes, click the device on the left, and select either update, or restore. And it'll do it all for ya.
HI,
if you want to have the display show on your television, you have to configure the display settings first on the display setting on the computer. Just follow the steps :
Step 1 : right click on the screen
Step 2 : click on the display option
Step 3: then check if you have an option to choose to extend the display on an external television.
after getting the option, reboot the computer and the display should be showing on the television.
thank you for using fixya.
This is how it works on my 2010 Escape. There are 3 buttons to the lower left of your steering column (Info, Setup, and Reset): 1) when it's displaying the "oil change required" message, hit the "reset" button to get rid of the message2) then hit the "Setup" button twice and you'll see the "oil life" screen, which is now at "0%". It tells you what to do next (i.e. "hold reset" until it say 100%).
I've just fixed mine. There's a reset "button". Take the face plate off, you'll see a little hole, yes it's a hole. Stick something thin and pointy in it and hold a couple of seconds, I used my earring, a pen tip won't work, I tried. It would reset the whole thing, display should show "1:00". Then you just have to work on your settings, adjust the time, etc. Hope it works for you as it has for me.
I bought a remote the other day and got these instructions with it. They worked!
1. Make sure vehicle is in Park
2. Press Vehicle Information button (has the icon of a car and an 'i')until 'PRESS *check mark* TO RELEARN REMOTE KEY' displays.
3. Press set/reset button. The message 'REMOTE KEY LEARNING ACTIVE' will display.
4. Press and hold the lock and unlock buttons on the transmitter at the same time for about 15 seconds. A beep will sound indicating that the transmitter is matched.
5. To match additional transmitters at this time, repeat Step 3. Each vehicle can have a maximum of four transmitters matched to it.
6. To exit the program mode, you must cycle the key to LOCK.
Anytime your unit displays RC1, 2, or 3 - the remote code needs to be reset. Other messages are "chk remote n" or "set n", n being the number 1, 2 or 3. These remote codes are set in case you have multiple products that interact w/ the remote - so when operating one device the other doesn't interfere. Unfortunately, every now and then for completely unknown reasons, they can slip out of the proper code. All you have to do (if your remote is, in fact, functional) is press and hold the number on the remote that corresponds with that which displays on the unit - in your case the number 3, and hold the Enter key at the same time for about 5 to 10 seconds. This should resume operation shortly thereafter. However, you will not see any confirmation on the display as you are performing this reset. It is trial and error.
