Question about LG DLG3788W Gas Dryer
LG dryer making unbelievable noise!!! Loud thumping noise. Took top off and drum is cracked seam where it is welded. This may be the cause of the noise.
Same problem here. Half of my LG appliances have failed within 2 years. Stay away from LG!!! They look pretty, though.
Posted on Sep 27, 2009
MNTECH
  • 1543 Answers
SOURCE: Maytag Dryer MDG9700AWW has split into the metal drum at the seam
I'd say take the 50% off offer. Dryer drums are very thin, and a weld would most likely still make a thump noise every time it passed the drum supports. (two thumps per revolution) I've seen this on other brands which use thin stainless steel drums. (I didn't look up your model to see if the drum was SS or powder coated metal, or galvanized, or whatever) It is not a real common thing, but certainly not unheard of. I'd say it was indeed a poor weld, but the manufacturer's generally won't help much once it makes it past the warranty period. Don't bother rating this, as anything but a FixYa lowers my rating. Thanks.
Posted on Dec 09, 2008
kachbibi1
  • 979 Answers
SOURCE: Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Posted on Jan 14, 2009
  • 5 Answers
SOURCE: Cracked Drum on LG Dryer Model #DLE2512W
I had a 2514 with a similar problem. Cracked drum. This is what I did to fix it. With the new drum. No noise at all.
Ordered drum from Sears parts. 3045EL1002D
Cost of 85$ + 15 to ship. It came in 5 days.
Here is how to do it on a DLE2514W. Takes about an hour. I only used a phillips screw
driver. Take your time and look over the situation. I hope that I rememberd
everything. Good luck.
Dryer Drum Repair
Dryer Drum Repair
1. Remove L bracket with 6 screws at the top, rear.
2. Slide top back 2 inches to unlatch and remove.
3. Remove control panel with 2 screws at top, inside corners.
4. Carefully unplug 4 plugs from back of control panel.
5. Looking at inside at the top. Remove wiring bundle from 2 guides.
6. Unplug wire from dryer light.
7. Open dryer door and unscrew 2 screws behind door just below lint trap.
8. Remove 4 screws at top of front panel that holds the door.
9. Lift up front panel to remove. I couldn't get the door switch plug to disconnect
so I carefully rotated it an set it on top of the dryer.
10. Remove upper case bracket with 2 screws in front and 2 screws inside at top.
11. slide up a bit to unlock from sides. Watch routing of dryer switch wire bundle.
12. Remove lint trap duct with 2 machine screws. Carefully slide down to remove.
13. Remove front drum support with 4 screws attached to sides. Lift up to disengage
sides. Lift drum to free from rollers.
14. Observe how drive belt is routed around motor and tension roller. Push tension
roller up and release belt. Carefully take belt off and remove.
15. Almost done. Lift drum up at rear to free from rear rollers. Remove.
16. While your're there vacuume up dust and reverse procedure to install.
Posted on Apr 02, 2009
SOURCE: LG DLE3777W dryer thumps when running
It turns out the drum was cracked. I replaced the drum. No more thumping noise.
Posted on Apr 10, 2009
SOURCE: cracked drum on the DLE3777W model
mntech, how do you wrap the belt around the pulleys once they are off, there appears to be too much slack when putting the drum back in the machine?
Posted on Aug 15, 2009
Dryer makes a thumping sound with or without anything in it
Look for a crack in the seam, where the stainless steel drum is welded together, either at the front or back edge of the drum. If weld is cracked, replace drum.
Jan 31, 2011 | LG D5966 Gas Dryer
Dryer makes a clunking noise while drying. Is it possible that the drum is "Out of balance"?
Most likely if it is a thump thump noise a drum roller has a flat spot and is causing the noise.
The dryer will operate ok but it will be loud.
A service call may be needed to replace all 4 drum rollers.
Jan 06, 2010 | LG DLE2532W Electric Dryer
Made noise when turning, now has hole in drum towards the back where the wheel turns the drum, hole about 2in. around
I've seen a few drums where the welded seam of the drum cracked, which causes a thumping noise. I guess if you let that go too long, you will end up with your senerio. Time to replace the drum.
Oct 04, 2009 | LG DLG3788W Gas Dryer
New dryer makes a loud thumping full or
I hope he did nt charge you. Because of the seam in a dryer drum, they do make a slight thumping noise but it should not be real loud. I hope the tech took the dryer apart and checked the rollers. One of them may have a flat spot.
I would ask for a factory represent ive to come out and see if they think they would want a dryer in there home that make that much noise.
Please rate solution
Sep 03, 2009 | Dryers
LG DLE2514w electric dryer has loud thud every turn
Most model dryers are supported at thge rear of the drum with a bearing configuration, but usually the front of the drum is supported by some lining pads or guides. These help hold the rotation of the drum concentric. It sounds like your drum is not spinning concentric. My guess would be that some new guides might need to be installed.
Hope this helps...
Sep 02, 2009 | LG DLE2514 Electric Dryer
Dryer thumps when running, clothes get stuck...
It always helps if you list the brand and model number in your post. I would look at the seam on the drum to see if the weld has cracked. (right at the front and / or rear of the seam.)
Jun 10, 2009 | Dryers
Lg Gas dryer Dlg0332w drum making noise
The drum on my DLG0332W was also making noise at the back of the dryer...kind of a thump thump thump as the drum rotated. My dryer is only 4 years old. I got brave, downloaded the service manual and opened up the dryer. I found that the drum's welded seam was starting to separate where the roller wheels were coming into contact with the drum at the back of the dryer. Looks like a new drum is in order.
Mar 01, 2009 | LG DLE2532W Electric Dryer
Loud Thump each time the Drum Rotates
You have a problem with your dryer drum.  The seam weld has cracked and the drum needs to be replaced.  You will need to call a qualified LG technician to resolve this issue.
Apr 15, 2008 | LG DLE2532W Electric Dryer
Did you resolve your dryer / noise?
LG DLG3788W Gas Dryer Logo
554 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
