Question about HP scanjet 3970 digital flatbed scanner
Hp 3970 scanner doesn't turn on.
When I check the hardware manager it doesn't find it. Could it just be a bad cord? How could I check that. Can I use a power cord adapter to check?
Hello
my scanner should not correct working imagewith full area yellow color
Posted on Feb 28, 2009
What kind of power cord does the hp scanjet 3970 need?\r\nalso the cord to conect to the computer. I have set it up on my HP laptop and it will not scan . I keep getting the message that I need to check if...
Let's compare bananas with bananas and apples with apples... if you have the unit ON with some lights and some activity going on, than the POWER CORD is just fine... you seam to refer of a communication problem (not a power problem) from the unit to the computer... normally for HP multi-function devices you have to install a USB cable and the software FIRST than connect the unit when the installer ask you to do so, FIRST UN-INSTALL all drivers & software you installed previously, reboot the computer with the unit OFF, connect the USB cable, than pop in the installation CD, go through the setup (accordingly) than when the installer ask you to connect the unit, turn it ON, than let the installer finish the configuration...
Hope this helped!
Mar 13, 2011 | HP scanjet 3970 digital flatbed scanner
Where do I get a new power cord for the HP 3970 which has been in storage for a while, but I want to begin using it agains, and can't locate the power cord. HP has discontinued this model and nothing on...
The correct part number for just the "brick style" power module (AC Adapter) for an HP Scanjet 3970 is L1970-80003. It is a specific 12V DC 2 Amp module. Today it can be purchased for $18.06 plus shipping from the HP Parts Store. However, if you are looking for just the power cord to your scanner's AC adapter, this brick style power module AC adapter does require a separate standard C13 detachable power cord to the specifications of your area, for instance, in the USA the power cord to connect the scanner to the power module AC adapter is part number 8120-6260, and it is a common power cord for monitors and computers. I learned all this because I had a scanner error message when I tried to use a different power module on the HP Scanjet 3970 when I lost the power cord to the original module. I hope this info helps somebody else, too.
May 24, 2010 | HP ScanJet 3970 Flatbed Scanner
My hp sacanjet 3970 doesn't work
Most likely cause of the "Scanner could not be initialized" error on the HP Scanjet 3970 is due to using an incorrect power adapter and cord -- the only power module and cord that work for the HP Scanjet 3970 are these part numbers: 8120-6260 for the power cord and L1970-80003 for the power module / AC adapter I hope this info helps you.
May 23, 2010 | HP ScanJet 3970 Flatbed Scanner
I lost power cord for my HPScanjet 3970 where can I get one?
you can buy online or from hp call centre. if you are in delhi visit nehru place you will find the cable there
Feb 08, 2010 | HP ScanJet 3970 Flatbed Scanner
My HP 3970 scanner has been working for years. No
Sounds simple enough. You will have to do a couple of things in order here. Unplug the cable from the back of the computer, and the scanner itself. Then unplug the power cord from the wall for the scanner. Wait about 20-30 seconds, then plug the scanner back into the wall. Now plug the cable in to the scanner, then the computer. Turn on the scanner and it should work. If by chance this does not work, then you may have to reinstall the drivers. If you don't have the disc, check out the manufacturer websight support section. Good luck
Feb 04, 2010 | HP scanjet 3970 digital flatbed scanner
Hp scanjet 3970 won't power on
Is the AC adapter getting warm when it's plugged in?
No fuses inside.
Jun 10, 2009 | HP ScanJet 3970 Flatbed Scanner
Using hp scanjet 3970 Just loaded hp scanning software and the large install of the 3970 drivers. When I enter the program the scanner opens and scans te image on the tray. (I am trying to scan a...
Have you checked the cord from the scanner lid to the scanner base. if that doesn't work I would try uninstalling the scanner and then reinstalling it. It sounds like a problem with the twain driver for the scanner.
Dec 20, 2008 | Computers & Internet
HP scanjet 3970
hi frined
take ur adper & show the store he will give u same needed code of power u have to nearest electronic or electrical store there u get a power cable
thmx using fixya
Apr 06, 2008 | HP scanjet 3970 digital flatbed scanner
HP scanjet 3970 digital flatbed scanner Logo
166 people viewed this question
Ben Johnson
