Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Snowblower drive will stop unexpectly when snowblowing
Have a 2006 Cub Cadet Model WE 26 two stage snowblower. When I'm snowblowing just about 3 minutes or a little more the thing will stop dead in it's tracks. I lift up the rear of it and the wheels turn just fine. But let it down and nothing. Usually this will happen in 2nd Gear. When I put it into another higher gear it will shudder a little and barely move. But when I put it in 1st gear it will work just fine for most of the rest of the time until I'm done. But it will stop too.
I replaced the drive belt (original looked pretty good. Might have been streatched very little) and have had the linkage adjusted by 2 service centers and it still does it. Now my brother in law is having the same thing happen to his 1 year old craftsman machine and my son the same on his brand new craftsman snowblower. What is the problem?
Someone please help me on this because every time I bring it to a service center they tell me nothing is wrong with it.
Thanks
5 Suggested Answers
  • 138 Answers
SOURCE: RIDING LAWN MOWER STUCK IN GEAR
Have someone to rock you while you attempt to move gear shift. Hopefully it is only stuck between gears and will disengage. Your grease in gearbox may have become hard causing problems. If you wash the gearbox with water when hot (after mowing) You may have created moisture in gearbox causing major damage to transmission.
Posted on Mar 28, 2009
  • 8 Answers
SOURCE: Cub Cadet 1610 Drive Belt Diagram
Go to Cub Cadet. com and click parts. Type your model number 1610. You will see parts diagram. Click that. It will show a long list of parts to click on. Choose drive and it will show you a diagram of all the pulleys and how the belt looks. Hope this helps. I had the same problem.
Posted on May 04, 2009
  • 246 Answers
SOURCE: cub cadet 1610 rans the battery down went mowing.
Hello bigdave1138:
From your Description it Sounds like the Stator/Charging Coils are Bad or the Voltage Regulator (if Applicable) is Bad.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=4fQ1f8Xi&p_accessibility=0&p_redirect=&p_lva=3443&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTEmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Wb2x0YWdlIGFuZCBTdGF0b3IgQ2hlY2s*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 12, 2009
  • 109 Answers
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Posted on Jun 29, 2009
  • 10 Answers
SOURCE: Trying to put on mower deck belt for cub cadet
Visit this web site http://www.partstree.com/parts/
you can pull up your Cub
Posted on Oct 18, 2009
I can't start my cub cadet snowblower. Pull rope is stuck. How can I fix?
Take the cover off the rope starter and look for broken parts, also are you sure the engine is not frozen up?
Jan 12, 2017 | Cub Cadet Garden
How do l replace traction control cable on cub cadet 826 SWE
The following link shows how to replace your cable. The link shows a craftsman model , it will be the same procedure as your cub cadet. You can refer to your owner manual for adjustment procedures
Snowblower Won Move How To Replace The Drive Clutch Cable On Craftsman Or...
Download manual
Jan 25, 2016 | Cub Cadet Garden
Will a model OEM 190-621 snowblower fit on a cub cadet LT 1024
Have you tried the cub cadet forum? If not, give it a click:
http://onlycubcadets.net/forum/forumdisplay.php?f=42
Nov 21, 2014 | Cub Cadet Riding Lawn Garden Tractor 25hp...
What is required to attach a MTD Snowblower model 190-032 to a ty4000 lawn tractor
That looks like a Cub Cadet part # for the Snow Blower.
You will absolutely need to customize a Belly bracket and Mule drive. Possibly find a Cub Cadet belly bracket and modify it to match your mounting points on the TY4000
Oct 13, 2014 | Mtd Housing Auger 26" - 684 04071 4044
Mine was doing the same thing and I found that if I put it in reverse for a little while it would be ok again for a short time. I found also that it did this more often when the snow was heavy and wet which makes me think that the rubber drive wheel is getting wet and slipping. If you've brought it in to a shop and they've said that nothing could be found wrong, then it must be something that goes away by the time you get it there - water (I'm guessing).
Feb 28, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
103 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
Dwain Pippen
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
