Question about Olevia LT32HVM 32 in. LCD Television
Olevia 232 s12 choppy picture & audio on local digital channel.
I have comcast cable with direct connection to tv's. 2 of 3 tv's get great reception on the local digital stations, e.g. 5.1 but the olevia is choppy and often says no signal. I did all the auto selections both standard and auto. Some guy at Olevia told me I need to connect through a progressive dvd, cable box or tuner converter. This was after asking if I had an extended warranty which I don't. Can anyone explain why this would happen? Thanks
4 Suggested Answers
SOURCE: TV tuner
Bill, did your tuner go out? I have had the same television for one year. We had a storm and our Buckeye cable went out. All the other tvs came back fine except for the room with the Olevia 232-S12. Everything works now except for the tuner. Cable came in and installed a converter box. Just wondered if you had the same problem (not the storm, but the tuner)
Posted on Feb 09, 2008
SOURCE: I can't program my Comcast remote for my Olevia
I have the same problem and have heard that if you have a comcast remote that takes 4 digit remote codes, it won't work.
You need a newer comcast remote that accepts 5 digit remote codes.
The easiest way to determine if you have a new or old remote is the color of the Ok/Select button. Newer remotes have a red OK/Select button. Older ones have a gray Ok/Select button. Comcast reps may be able to drop one off.
If not, I've heard Radio Shack carries cheap universal remotes that work w/ both Comcast DVRs and Olevia LCD TVs.
Posted on Mar 20, 2010
SOURCE: Olevia 232-S12 bad flash
Would any of you guys mind sharing the latest firmware for the 232-S12? Or can you direct me to a place to get it now that the Olevia website is down?
Posted on Mar 31, 2010
SOURCE: Olevia 232 S12 wall mountable?
did you ever get it mounted? if so, would you mind telling me what kind of mount you ended up using? thanks!
Posted on Jun 18, 2010
Sound quit on Olevia SyntaxBrillian 232-S12
A common symptom of power supply trouble is disappearing sound
Apr 01, 2013 | Olevia Televison & Video
I have a olevia model 232-s12 tv has sound but no pics I checked power supply all checked ok I turn tv on sometimes picture would work image may be very cracky so I assumed it was a tcon board replaced...
Good day.
If you already replaced a new inverter board and T-con board and the problem is still there.Try to play the video on the DVD,if the video is OK check the cable connection and try to run auto scan.
If the problem is still there check the input supply of the system board or main board it should have 5vdc and 12vdc,if it is OK replace the system board.
Review this manual page 4-1 abnormal display http://www.scribd.com/doc/36875894/Olevia-232-S12-SM
I hope this solution will be helpful.Thank you for using FixYa.
Apr 17, 2011 | Televison & Video
I can't program my Comcast remote for my Olevia model 232 S12, I have used all the codes comcast suggested to no avail
The Comcast remote will unlikely have Olevia codes available since its design age is much older than the set's. In addition, it may never have them since Olevia is bankrupt and probably of little interest to Comcast. You might check Comcast's website since the most recent codes will be available there.
Feb 15, 2010 | Televison & Video
Where did you get the firmware from? Can you provide a copy? I bought this TV when it came out and never upgraded the fw, now I can't find a copy anywhere.
Oct 09, 2009 | Syntax 232V Television
No tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
Jun 19, 2009 | Syntax Olevia 226T 26 in. LCD Television
Channel Search
With remote, hit MENU, (use up/down arrows) & scroll to SETUP. Hit ENTER & scroll to TV. Hit ENTER & scroll to AUTO CHANNEL SEARCH. Hit ENTER & scroll to CABLE. Hit ENTER & scroll to AUTO. Hit ENTER, wait as it scans (about 5 min). Your done.
Jun 18, 2009 | Televison & Video
No Non-Hd sound
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 19, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
TV tuner
Jan 08, 2008 | Olevia LT32HVM 32 in. LCD Television
Remote control codes
Juni,
You'll have to look it up by the remote you're using... Then by the brand of Tv you're trying to control.. try here..
http://www.remotecodelist.com/remotes/
Bill
Dec 27, 2007 | Olevia LT42HVi 42 in. LCD Television
Olevia LT32HVM 32 in. LCD Television Logo
281 people viewed this question
Top Olevia Televison & Video Experts
Dave Naylor
Dave Naylor
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
