Question about Nintendo New Super Mario Bros. for DS
I can't pass house no. 8 It's always restart at the middle of the house I can see the fly but after it's always restart
  • ilikeapples May 11, 2010
    What world??? there's no ghost house in world Eight. So, if you could be a bit more specific. We can help.
  • 19 Answers
Posted on Apr 14, 2009
Why does my chain saw lose power and shut off as soon as it gets hot.can't restart until it cools off.
Check coil pic up or the electrical pick up in the pull string housing. Remove that and u will see the fly wheel next to that is the electrical pick up .look at fly wheel make sure magnets are clean surface ,they are in the fly wheel itself.after that remove coil and clean surface that faces fly wheel. Using a match book cover place it between fly wheel and coil ,make sure it moves but not falls out snug ,tighten coil screws and remove match book cover. If it dose it again re place coil look for small engine shop in your area and the can help get u a new one .weak spark means coil,sparkplug
Sep 15, 2014 | Poulan PP4218AV 18" Chain Saw
How do you find a flies nest?
Fly spray the flies and see where the rest are hanging around. Some food somewhere in your house that has gone bad is a probable cause or a dead animal under the house or in the walls .
Aug 31, 2014 | Cars & Trucks
Torque specs on fly wheel on a massey 281
Flywheel Setscrews 80ft/lbs Flywheel Place Bolts 90ft/lbs Flywheel Housing Setscrews 3/8 UNF (Standard) 36ft/lbs Flywheel Housing Setscrews 3/8 UNF (Durlock) 67ft/lbs Flywheel Housing Setscrews 3/8 UNF (4.2482 engines) 42ft/lbs
Aug 04, 2014 | Cars & Trucks
Cranshaft position sensor
JEEP ZJ it is
and you can look your self here, anytime (ign. sys. opt page 8)
first off , always post engine size ,
why do you want to know, post symptoms first.
lost spark
got DTC code P-340 or 355 or some other DTC cranking,
no scan RPM? what,
the 4L the CKP is located on the fly wheel ,
sitting in the drivers seat its at the 11pm location, on the bell housing
or top left corner of the BELL, (the bell is where the clutch is)
the (im reading page 8)
"on the top of cylinder block ,near the rear right cylinder head"
2 bolts holding it there.
one can say the 5.2 the sensors is on bell/fly 1-2pm loaction.
so 4L is 11pm and 5.2L is 2pm.
triggered off the Flywheel.
Jan 04, 2014 | 1995 Jeep Grand Cherokee
What parts make a house fly,i.e complete labeling of a house fly
Quite possibly are you speeking of a flywheel housing?
Nov 08, 2010 | Garden
I have a Yard Machine Lawn mower by MTD it has a briggs and stratton engine. The pull cord pulls, to easily I might add, but will not start the lawn mower. It doesn't seem to engage the motor. What might...
If you think the rope pulls too easily the engine may not have enough compression. Consider doing a compression test or a leak-down test on the cylinder.
Oct 23, 2010 | Mtd 22" Yard Machine Push Mower
I have the original nintendo and wanted 2 know how u get the whistles for mario 3
I will give you the directions and a video that will show you all three whistles:
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
These are the locations of all the warp whistles. Warp Whistles:
1. At the end of World/Level 1-3, there's a white block. White blocks allow you to "fall into the background", after you stand on them, & duck for a few seconds. You don't stay in the bg forever, however. Anyway, run behind the "curtain" at the stage end, & you'll be in a secret Toad house. Later in the game, one of the letters Princess sends you, tells you that a whistle is in the darkness at the end of the 3rd world. This means 1-3, although confusion has come of this, prior to knowledge of where the whistles are at.
2. World 1 fortress - at the end of the 1st room. Knock out the dry bones. Get the super leaf, if you aren't raccoon Mario already. Get a running start, & fly up to the ceiling. Fly on the ceiling, & keep running right. You'll fall down in a room, w/ a treasure box, containing the whistle.
3. At the end of the World 2 map, there's a rock that you have to smash, w/ the hammer you get from one of the 3 wandering hammer bros. on this map. Only 2 are visible at 1st. The 3rd gives you the whistle. On a side note, the toad house here will usually give you a frog suit.
Also on a side note, using a whistle in the warp zone(World 9), will take you directly to the World 8 pipe in the zone. Warping in world 1 takes you to the top 3 pipes(worlds 2, 3, & 4), in 2, 3, & 4, the middle pipes, in worlds 5, & 6, the middle 3 pipes(worlds 5, 6, & 7), & in worlds 7, or 8, it just takes you to the world 8 pipe.
Oct 12, 2010 | Nintendo M04041 Console
I need to know where the number 5 piston is
ford starts with #1 is pass front #2 is 2nd pass from front #3 is 3rd pass front # 4 is forth from pass front now i dont know if it is a v8 or v10 if it is a V8 THEN # 5 IS THE FRONT DRIVERS SIDE IF IT IS A V10 THEN #5 IS THE REAR PASSENGER SIDE
Dec 27, 2009 | 2005 Ford Expedition
Hi R
There should be a middle position between O & I
check carefully - not much movement in needed
Oct 12, 2009 | Water Heaters
Thunder flies in my monitor
Hmmm, Thunder flies usually are found on plants and vegetables, how did they get in your computer?
Regardless, they shouldn't stay alive in there too long, as they don't have any food feed off. Normally, I'd say don't worry about it and just let them die, but you may need to go in there and clean them out manually so they don't spread around your house too much.
Jul 05, 2009 | Dell E153FP 15" LCD Monitor
Nintendo New Super Mario Bros. for DS Logo
35 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
