Question about Brother ULT2001
Bobbin shows on top
Not only does the bobbin show on top, but the top thread starts winding around the bobbin. What a mess!!
I took it to be serviced.
Posted on Mar 11, 2009
How do you wind the bobbin
Most bobbin winding procedures are very generic. There is a small peg on top of the machine and a lever to snap the peg against or the peg itself moves toward a stationery lever. Leave thread on machine like you would begin sewing but u thread the machine. There should be a thread holder of some kind on top to run thread through to hold tension. Wind thread a few times around bobbin and put bobbin on the peg on top of machine. Push lever toward bobbin peg or peg toward lever (whichever moves) and arrow by peg should show which direction thread will wind. Then push pedal and away you go...hope that helps.
Feb 11, 2015 | Sewing Machines
Tip
Winding a bobbin correctly
The heart of sewing is producing a well tensioned seam and achieving this with any sewing machine will be difficult if you don't wind a bobbin smoothly and with even tension onto the thread. If you look at your bobbin and the thread on it looks all lumpy and uneven, then this tip is for you.
Each time you wind a bobbin, whatever sewing machine it is on, it is really important to keep even tension on the thread as it winds onto the bobbin. Many machines will have a little tension disc you take the thread around but your technique is important too.
Usually you take the thread from your spool of cotton on the right, across to the left on the top of the machine and around a tension disc, or through a thread eye, then back to the right to your bobbin winding spindle, if your bobbin has holes in it, then pull the thread tail up through a hole and pop it onto the spindle. Engage the spindle by pushing across against the stop. Now start winding SLOWLY while holding the thread tail up in the air until the core of the bobbin has been covered in fully and your thread has covered up the starting point to hold the beginning tail. Stop winding, and trim the tail off against the bobbin with a pair of snips. Now resume winding at 1/2 to 3/4 speed and do two things, one with each hand. With one hand put tension onto the top of the spool you are winding thread off - use the curve of your scissors handle into the indent on top. And with your other hand, give the thread a nudge as it winds onto the bobbin to ensure you wind fully across the whole bobbin evenly. Watch it carefully to ensure that you get a smooth even wind.
An analagy: if you wind the garden hose onto the hose reel really fast and let it go anywhich way, the hose will kink and wind mostly in the middle then the reel's full and you've still got half the hose to put away. Thread is the same, its been wound onto a spool by a machine in a very precise way; you want the same smooth evenly tensioned winding onto your bobbin so that when you stitch out the seam the thread is consistently fed off the bobbin.
Don't be tempted to wind flat out and just let it take its own path as you won't get good smooth bobbins of thread. And if you let the thread come off the spool at a fast pace the spool may bounce around, causing fluctuations in the tension on the thread. When you stich a seam, the thread will relax unevenly in your seam causing puckers and ho hum stitching.
Simple stuff but it makes a difference!
on Oct 02, 2011 | Sewing Machines
Bobbins wind unevenly- tension issues
Sounds like it is actually the tension on the bobbin winder. Make sure that the thread is following the correct path to the bobbin. Other than getting it repaired, a stand-alone bobbin winder (avlb @ JoAnn's or online) for ~$30 would work. One brand is called the Sidewinder. Verify that your bobbins will work on it because some Singer bobbins will not. It's a nice accessory to have because it saves wear 'n tear on your machine plus you can wind bobbins without unthreading the machine.
FWIW, it is usually better to wind bobbins at a slower speed. Higher speed will tend to make the bobbin jump around and the thread to pop off. In addition, higher speed will tend to stretch the thread going onto the bobbin. The thread will not relax until unwound from the bobbin and stitched into your garment. It may cause the fabric to pucker as the thread relaxes. Slower is better!
Apr 15, 2017 | Sewing Machines
Bobbin
To insert a filled bobbin, lift the presser foot and turn the hand wheel to put the needle at the highest point. Slide open the face plate and drop in the bobbin with the two holes up. Pull the thread into the groove near the center front of the bobbin opening and then to the left (another groove). Then pull it to the back of the machine and close the face plate.
To wind a bobbin, you will need to unthread the machine most of the way. Leave the the thread through first and second thread guides. Then bring the thread around the bobbin winding disc (so that it goes under and around the disc) back towards the bobbin pin (on the top right of the machine). Pull the thread through the correct hole in the bobbin (the one away from the center of the bobbin). Leave a 4" tail. Push the bobbin onto the pin and then push the bobbin and pin as far to the right as it will go. Hold onto the thread tail and step on the presser foot to start winding. After ~10 winds, temporarily stop winding and cut the thread tail. Then step on the presser foot and complete winding. When done, cut the thread to separate the bobbin from the top thread. Rethread the top thread and insert your bobbin.
The manual for the 4228 is available here: http://www.singerco.com/uploads/download/492_4228_4220_030707_new.pdf . See page 31 (18 of the pdf) for pictures of threading and winding the bobbin.
I hope this helps.
Jan 19, 2012 | Singer Inspiration 4228 Mechanical Sewing...
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
Bobbin stich is uneven and a tangled mess
you can dowload a manual from the singer website http://www.singerco.com/accessories/manuals.html
If the bottom stitching is uneven, its mostly the top thread not under tension correctly so check the tension dial and the threading up from the thread spool to the needle.
Also, review how you wind a bobbin, you want a nice smooth wind, not twisting or uneven build across the bobbin. The manual for this machine is pretty brief on this but bobbin winding is crucial to getting a good even flow from the bobbin when stitching seams. You want to wind thread smoothly onto the bobbin, across the full width of it, not just mainly in the middle. Give the thread a nudge with your finger tip to fill top and bottom as it winds.
Also, ensure the thread goes through the bobbin tension disc on top of the machine, and even then, use your scissors handle to put some downward gentle pressure onto the thread spool you are winding off so it doesn't jump or bounce as you wind. Wind the bobbin to 3/4 full, then stop.
And lastly, load the bobbin correctly following the manual directions, make sure it is turning the right way in the bobbin case. Also look at page 16, it shows the "dangle" test where you can check the tension on the bobbin case is right, you should be able to dangle the bobbin by the thread tail and it should "stay" but you should be able to pull on it to release thread too. Adjust the little tension screw in minute increments to get this right. Bobbin case tension springs can fail or break too, so check this out.
Hope this helps you; it is my experience that 90% of machine issues are caused by blunt or wrong sized needles, wrong threading, no tension or incorrect tension or lack of maintenance.
Apr 16, 2011 | White Sewing 1888 Mechanical Sewing...
Problem with the tension when embrod.
lower your top tension down, as it is tighter then your bobbin thread and also tighten your bobbin thread, this is done by the small screw on the bobbin holder, also you can try using the older metal bobbins these are the ones with the small holes around the top and bottom shank, but please make sure that they are the larger size bobbin, and only go very slow at first, try just in sewing mode first or just wind it over by hand.
Aug 12, 2009 | Janome Memory Craft 10000
Singer 7444 trouble winding bobbin
It sounds like you don't have any tension on the thread when winding the bobbin. Make sure that you are running the thread through the tension disc on the top of the machine before going to the bobbin winder.
Feb 28, 2009 | Singer 3116 Simple
Kenmore Sewing Machine model # c877.15
I have a Kenmore as well ,I hope that this will work for you ,too bad that I don't live close to you otherwise I would give a hand. This is the way I fill the bobbin on mine. Mine is located on the top right ,I put the thread into the bobbin hole leaving a small piece of thread hanging for me to hold when I begin the winding, I pull the wheele out to stop the needle from moving while winding, when I am done just push it back in .I run the thread from the spool into the top left it looks like a U turn with a screw go around that without winding just pull it into the bobbin hole. press the foot control and it will begin winding .
Jul 17, 2007 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
63 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
