Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door goes up and down but light does not work
I have a 1/2 horse chamberlain opener and the door goes up and down using the remote openers and the mounted button. The problem is that the light does not come on when raising the door or breaking the sensor beam. The bulb is a standard 60 watt bulb and it works. This happend when the bulb blew. Also I can program 2 remote openers to work using the set button on the opener but I can not get a third remote opener to work and when I try it deactivates the other 2 openers.
  • Anonymous Feb 28, 2009
    Light does not come on when door goes up or down, however if i manually operate the contacts that light the bulb it comes on. So, what so I need to change that causes the contacts to operate? sears model 139.65000
  • mtmikeandpat Mar 02, 2009
    I did not see a solution for the problem
    Sergeant:
  • 227 Answers
Sears craftsman 1/2 hp. Door goes up with remote, but when button pushed to go down the light flashes and door doesn't move. If you push the wall mounted switch, the door goes down like normal. Works...
Check the sensors in the doorway. They should both have a small light that is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Sep 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
The remotes opens the door when we leave. The remote will not close the door. Only the wall button will close-we have to hold it down until it is fully closed. Craftsman 1/2 horse 41A5021-3H
Check your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to work you have a bad sensor.
Jan 01, 2011 | Sears Craftsman LiftMaster Chamberlain...
My opener is a 1/2 horse lift master professional chain drive . The door will not close unless you hold the closer button in. From the remote it will only move a few inches and then reverse. The door works...
If the main light flashes 10 times when the door reverses it is a door sensor problem. If not, you probably have a bad RPM sensor board which is a small printed circuit board just in front of the motor.
Jun 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberline 1/2 horse truble shoot
check the infared sensors make sure those are working right. Yo may have to adjust the tension for bring down the door.usually a screw on the motor to adjust the senisitivity.
Oct 09, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Chamberlain remote has stopped working, new
WHEN YOU CHANGE THE BATTERY NO NEED TO REPROGRAM THE REMOTE.
THE FLASHING LIGHT TELLS YOU IT IS SENDING A SIGNAL THAT IS BEING RECIEVED IT IS JUST NOT THE CORRECT CODE TO OPEN THE DOOR.
REPROGRAMING THE REMOTE SHOULD SOLVE THE PROBLEM
HOPE THIS HELPS
Sep 28, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Garage door goes up but will not go down.
UNPLUG THE UNIT AND WAIT 5 MINUTES.
THIS WILL RESET THE CONTROLS.
SEE IF THE WALL BUTTON LIGHTS UP.
IF THIS DOESN'T SOLVE IT GOTO CHAMBERLAIN.COM AND DOWNLOAD THE MANUAL (FREE PDF FILE) IT WILL TAKE YOU THROUGH A COMPLETE DIAGNOSTIC.
HOPE THIS IS HELPFUL
Apr 13, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Garage door opener doesn't work with key pad or remotes
It sounds like for some reason the receiver has lost the stored codes for your remote transmitters. The wired button goes right to the opener so it continues to work.
On the back of the opener you'll see a small pushbutton. Press it and the indicator light nearby will come on. While this light is on, press the button on your remote. The light will go out and the code is stored. Repeat this for each remote. The process is the same for the keypad, except that you need to enter your desired 4-digit code.
If this programming doesn't work you'll need to replace the receiver board. Like any other piece of computerized equipment, it can fail or be damaged by power line problems. But try reprogramming first, as that's the most likely solution.
If this has helped you, please take a moment to rate the solution. Thanks for asking here!
Feb 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Liftmaster Pro. Garage door Problems closing
The sensor eye - or more likely, the other end, the sensor light - probably got knocked out of alignment. The eye should have an LED on it - possibly one that glows green when it's ready to close or red when it's obstructed or out of alignment. Try adjusting the light until the LED on the receiver glows green.
Dec 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener doesnt close all the way.
The motor is probably either stalling because the door is too stiff, or you have a beam break detector that is being triggered when the door is halfway down.
Nov 23, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
170 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
