Question about Vizio VW32L 32 in. LCD HDTV
Tv wont turn on
The company said to unplug and hold the on button for one minute,then plug in and try to turn on tv.it didnt work
  • 1 more comment
  • dennis1949 Mar 02, 2009
    repair man said the tv needed a power supply .
  • jillj948 Mar 06, 2009
    I have the same problem but I was not able to get the warranty..Purchased 7/25/07 from Walmart.
  • dennis1949 Mar 09, 2009
    tv needed a power supply and mother board .
My tv was purchased at costco in 2006 ,which would take it out of warranty.But to my delight when i went to costco i noticed where they sell the tvs there was a sign that said that they give there members another 2 year extension on the warranty.They hooked me up to a service man and the tv is in for repair.stay tuned for an update.
Posted on Mar 02, 2009
Tv wont power up?
could be buttons,unplug them and try remote, or the convergence ics are bad
http://www.shopjimmy.com/
Aug 25, 2012 | Mitsubishi WS-55807 TV
My tv wont turn on and its beeping
Unplug the set, press power and hold for 60 seconds, let it sit for 30 minutes and plug the TV back in, try to power on, if no change! the problem is power supply or high voltage issue.
Mar 21, 2012 | Televison & Video
My tv wont come on the green light is on but the screen is not
turn the television off and then unplug it. while it is unplugged hold the power button for three to five minutes then plug it back in and try it. if that dosent work then contact lg tech support they should be able to find the problem
Mar 24, 2011 | LG Televison & Video
MY MEMOREX DVD PLAYER suddenly WONT TURN ON?
Unplug power cord, wait 30 sec. Plug back in. Worked 4 me
Mar 20, 2011 | Memorex MVD2042 DVD Player
When i turn my tv on it says FDA Lock ON and then it turns itself off and wont come back on. it shows the power button is lit up but it has no picture and no sound. we have tried to reset the password to...
Hello
Your TV is locked I thinks. Do the following and see whether it help you.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Dec 20, 2010 | RCA TruFlat 27F520T 27" TV
I accidently unplugged my tv and now I plug back in and it wont turn on. I waited for 30sec and then plugged it back in but it didnt work. I then tried another outlet but still didnt work. All I see is a...
Often you have to press a particular button on the TV. The remote may not work until this is done. Sometimes these buttons are on the front or under the front.
OFTEN the orange flashing light can ALSO mean no video signal is being received. This COULD be the case if you killed the power to the TV and it has lost the channel settings so it is not receiving a signal form ANY source.
Dec 22, 2009 | Toshiba 32AV500U 32 in. LCD HDTV
My little colby dvd player wont open or close and it wont turn off. if it would open, i would try to reset the remote..yes, i have plugged and unplugged and have it plugged directly into tv???
I assume you've tried plugging into a wall socket instead of TV?
Probably won't work, but push and hold power button on unit 10 seconds then release, for that matter try all buttons. Not uncommon problem, usually you have to UNPLUG unit, disassemble to remove DVD and discard unit if cheap enough.
Sep 26, 2009 | Televison & Video
Wont come on
Instead of just unplugging the TV, perform a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If the TV still won't turn on, then it appears something is wrong with it's mainboard since the TV is still receiving power because the standby light is still coming on.  The cost of fixing an older TV's mainboard could be costly or impossible if the part is discontinued.
Mar 25, 2009 | Beko 324250WN 28" TV
Vizio VW32L 32 in. LCD HDTV Logo
170 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
