Question about Frigidaire GLTF2070DS Front Load Washer
Fault code F 03? Any suggestions?
We've just had the motor, motor controller, shocks, and door lock replaced over a period of 5 weeks. Finally we have a working washer ... for only 2 loads. For the third load we have wet clothes and fault code "F 03" ... Any suggestions?
  • mariabeitel Feb 28, 2009
    Thanks, I'll do that.
  • 52 Answers
Check your drain pump for a restriction.
Also, with a meter check for power to the drain pump.
Posted on Feb 28, 2009
I have a 03 dakota I did a 5.9 swap from a 3.9 I finally finished I have the 03 pcm and harness It will start for 5 seconds then shuts down has a 0340 and 1686 code any suggestions?
the 1686 isnt a ford code but the 0340 is the cam position sensor may be a wiring fault or the sensor its self ,gives you a starting point as this would give the symptoms you describe
May 01, 2014 | Cars & Trucks
I have a fisher and paykell GW712 washing machine that has the 2 green light and 7 red light flashing and beeping after turning on at power point.after pushing buttons 4 or 5 times and turning the power on...
The second light and the seventh light on and beeping is fault 66.
This is info on fault 66.
66. (01000010) Phase 6 - Pressure Transducer (Ptx)
Error - Frequency > 90 kHz
Note: this supersedes Fault code 65 from V41 Motor Control Module
code onwards.
The Motor Control Module has received signals from the water level
sensor (Ptx) above normal frequency values.
Primary Source: Motor Control Module.
Action: Replace Motor Control Module.
Oct 07, 2013 | Fisher Paykel EcoSmart GWL15
Can't open the oven door with an F9 and beeping
Here's the info from the service manual
"Fault Code: F9
Likely Failure Condition/Cause:
1. Door motor failure / jammed. Latch
motor switch failure.
2. Control software failure, or component
failure (relay stuck).
3. Wiring Problem.
Suggested Corrective Action:
1. Press CLEAR key.
2. If CLEAR key does not eliminate problem, turn off power for
30 seconds, then turn on power.
3. Check wiring of Lock Motor, and Lock Switch A and Door
Switch circuits.
4. Unplug P4, apply power (L1) directly to the Lock Motor, if the
motor does not rotate, replace Lock Motor Assembly. Plug
P4.
5. Check Lock Switch A for proper operation (do they open and
close, check with ohmmeter). The Lock Motor may be
powered as in above step to open and close Lock Switch. If
the Lock Switch is defective, replace Motor Lock Assembly.
6. If all above steps fail to correct situation, replace control."
Feb 24, 2011 | Frigidaire GLEB27S7A Electric Single Oven
How to start oven in PROPANE STOVE
Print the following infore for future ref if you wish. How it works is simple tage a look at it in Motion
Component Test Procedure Results
Electronic
range control
F1−1 –Upper Oven >650°F with door unlocked.............................
F1−2 –Lower Oven >650°F with door unlocked.............................
F1−3 –Upper Oven >950°F with door locked.................................
F1−4 –Lower Oven >950°F with door locked.................................
F1−7 –Membrane switch is not responding ...................................
F3−1 –Upper sensor is shorted at (< 100 ω) or
open at (>5 K ω) ...............................................................
F3−2 –Lower sensor is shorted at (< 100 ω) or
Check actual upper oven temperature,
if > 650°F check sensor.
Check actual lower oven temperature,
if > 950°F check sensor.
Check membrane switch for connection or damage.
Check upper sensor, harness, and connections
Engineering
Test Mode
Press BAKE pad.
Enter 100°F using the number pads.
Immediately push and hold BAKE pad for appropriate oven
approximately 3 seconds.
This mode can also be entered by pressing the hidden pad
for 3 second located to the left of the lower oven light pad.
Used to view the actual oven temperature for both ovens at all
times, even when an oven function is active.
This mode will also display the current fault code for 5
seconds in the time digits.
Fault codes
accessed
through
Engineering
Test Mode
F0−0 –No fault .................................................................
F1−5 –Upper hardware failure within control ....................
F1−6 –Lower hardware failure within control.....................
F1−8 –Shorted key in membrane switch ..........................
F1−9 –Internal communication errors within control .........
F1−A –Upper latch switches ............................................
F1−B –Lower latch switches.............................................
F1−C –Upper door switch.................................................
F1−D –Lower door switch.................................................
F1−E –Sensor input not calibrated ...................................
F1−H –EEPROM error .....................................................
F1−L –Temp in ovens are the same for long period .........
F1−N –Internal voltage on control not working .................
F9−1 –Upper lock switch is not correct.............................
F9−2 –Upper unlock switch is not correct.........................
F9−3 –Control does not see upper door lock....................
F9−4 –Lower lock switch is not correct.............................
F9−5 –Lower unlock switch is not correct.........................
F9−6 – Control does not see lower door lock ...................
EE –Control cannot read E-PROM. Unit will shut down.
Default from factory
Replace control
Replace control
Check membrane connection
Replace control
Check latch wire harness
Check lock wire harness
Verify sensor is operating properly
Replace control
Replace control
Check lock wire harness, and lock switch
Disconnect power for 60 seconds. If EE reappears, replace ERC
Test Mode This mode must be activated within the first 5 minutes of
power up.
Press BROIL and CANCEL pad for approximately 3 seconds.
If oven temperature is greater than 400°F, the Test Mode
cannot be activated or will abort if active.
Press and hold individual pads for 4 seconds to activate.
Display will have dashes in all segments to indicate the mode is
active.
Upper Bake: Energizes upper bake element
Lower Bake: Energizes lower bake element
Upper Broil: Energizes upper broil element
Convection Bake: Energizes convection fan
Upper Oven Light: Energizes upper oven light
Lower Oven Light: Energizes lower oven light
Upper Clean: Energizes upper motorized door lock
Lower Clean: Energizes lower motorized door lock
Stop Time: Energizes Beeper
Cook Time: Displays error codes
Timer 1: Energizes ROM version
Timer 2: Energizes EEPROM version
Keep Warm: Cooling Fan
Clock: All display segments light
If functions do not perform as specified, replace ERC
Oven
temperature
adjustment
Push BAKE pad.
Enter 550°F using the number pads.
To decrease or increase oven temperature. Push AUTO SET
pad until negative or positive numbers appear. Oven can be
adjusted from -35° to +35° (-37.2° to + 1.6° C) in 5° F (2.7° C).
To avoid over adjusting oven move temperature -5° each time.
Push OVEN CANCEL button.
Sep 04, 2009 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire oven f9 code
Here's the info from the service manual:
"Fault Code: F9
3. Wiring Problem.
1. Press CLEAR key.
Switch circuits.
P4.
- www.fixyourboard.com
Jul 25, 2009 | Frigidaire FEB30S5D Electric Single Oven
Door locks and F9 fault codes
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 24, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
F90 Err on Kenmore Elite Gas Range 790.3670 How do I get rid of the error?
the F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board. It is unlikely that you will be able to reset this fault code. You can try to completely disconnect electrical power and leave it off for 5 minutes. After reconnecting power, the fault code will probably reappear since the control will still detect that the oven door is locked. The only way to clear the fault code is to disassemble the range and repair or reset the oven door lock assembly. You will need a service technician to complete this repair.
Good Luck
Dec 29, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven door locks and un locks code F90
The F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board.
Dec 16, 2008 | Kenmore 79013 Stainless Steel Gas Kitchen...
I HAVE A FAULT CODE F 11 AND DL F
it looks as if your having a communication problem between your central control unit and your motor control unit.check wiring connection between these two components.if wiring is ok then you will have determine which of these components is malfunctioning.you can also remove kick plate and remove service manual located on either side at bottom.this should give you some help.
Jun 18, 2007 | KitchenAid KHWS01PMT Front Load Washer
Frigidaire GLTF2070DS Front Load Washer Logo
170 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
