Question about Haier 42EP24S 42 in. EDTV-Ready Plasma Television
How to connect hdmi
Connect hdmi from cable box to techwood plasma tv that doesnot have hdmi input is there a converter to fitt
    Scholar:
  • 85 Answers
The TV inputs screen will not recognize a Toshiba VCR I've connected to it with red,white & yellow cables.
Because many VCR were not designed to work with these types of TV and the TV has no SCART socket you might have to convert it to fit.
You can do this using a box on sale at Amazon.
http://www.amazon.co.uk/SCART-HDMI-converter-convert-connect/dp/B0092IAA3I
Mar 16, 2016 | Panasonic TC-P42C2 Plasma TV, 41.6 -...
How to connect sega master system 2 to lcd plasma tv
If your TV comes with a composite video input then this may not be an issue. You need the RCA AV cable. Sega outputs only mono audio so put Yellow in TV video In and White in TV audio In (white connector).
http://www.gametrog.com/GAMETROG/HOW_to_connect_Hook_Up_SEGA_Master_System_Instructions.html
If you still have the RF box for the Sega then you should be able to put RF from Sega and TV antenna to the RF box and connect RF box to TV antenna in.
If TV is only HDMI input then you need a converter like this
Composite Video to HDMI Converter
Sep 04, 2014 | Video Game Consoles & Games
NEC PX-50XM4A 50" plasma tv - I get a picture but no sound. I have my cable box plugged in to the DVI port converted to HDMI going to my cable box but I cant get sound when I plug external speakers in to...
HDMI carries both video and audio.
Do you get video and audio on TV. Just to be sure.
Now are the external speakers powered ?
are you connecting the Speakers to Audio Out of the TV ?
By the way, I cannot see any RCA port that is output port on your NEC plasma. NEC 50XM4 User Manual Specifications The audio input is for audio from dvd for example.
Oct 23, 2013 | NEC Televison & Video
Hello I received a lg flatron plasma MZ42PZ14 and just wanted to connect the tv cable to the tv, but i can't find any coax on the tv. what can i do?
This kind of tv u must have cable or satalite tvs pay broadcasting signal cable,so u have a box .Tv have HDMI ports or RCA AV component cable input?The incomming broadcating tv signal go to the cable or satalite boxes.Than u use a HDMI cable or RCA AV component cable go through those boxes than to ur tv HDMI input ports or RCA AV component cable input holes.
Jan 22, 2011 | LG MZ-42PZ14 42 in. Plasma Television
Panasonic TH-46PZ85U Plasma TV All 3 HDMI was working fine with cable box, PS3, XBOX360. I used to connect my pc to the tv with a dvi-hdmi cable, but recently unplugged it. So I tried to plug in the same...
Symptom:
TV shuts off unless all the input (phono and HDMI) cables are disconnected. The
symptom may be intermittent.
Cause:
There is an abnormal AC voltage entering the TV from one of the input cables or AC
outlet.
Remedy:
Follow the Testing procedure to determine if there is a problem external to the product.
Concept
Constant symptom
If the TV no longer shuts off when all input cables are disconnected, then one of the
input cables is introducing abnormal voltages into the TV. Panasonic Plasma TV sets
have 3 wire AC plugs.
As a result, abnormal voltages introduced into this TV will cause the TV to shut off for
protection.
Intermittent symptom
If the abnormal input voltage is borderline (marginal), the TV shut off symptom may be
intermittent. However the cause may still be detectable with a voltmeter.
Protection Proof:
Release the protect mode - the TV has to be unplugged to reset this protection circuit.
Threats from the HDMI input:
Excessive voltage from an HDMI cable connected product will activate the Plasma TV’s
protection circuitry. Placing an isolating / buffering connector (sometimes called a voltage
conditioner) between the TV and the HDMI input cable often solves the problem.
Testing -
Unplug all the HDMI inputs from the TV. Turn on the TV. Plug in the HDMI inputs one at a
time. The cable that causes the TV to enter the protection state is connected to the product
that has the excessive voltage (and signal). Avoid connecting this product until an isolating
connector is found.
Jan 27, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
HDMI inputs are not working
As crcelect suggests you can run the TV on RCA. You should also be able to use coax directly from your cable box. If you don't have cable you can use an rf converter to connect coax.
I have exactly the same problem with my Panasonic TH-42PX75U. I've been told that I may need to run a setup on my cable box to fix the problem. If I find a solution I'll provide details in a future post.
Nov 01, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Use TV as external monitor from laptop
no tube tv won't mirror monitor. needs vga connection at the back of tv.go to store have a look at lcd or plasma screen.the card is ok.
Jun 26, 2009 | HP Pavilion DV6500Z Notebook
Sony Viao HDMI to Panasonic Plasma TV HDMI Input handshake
Try all of your HDMI inputs, one may be rated at the correct voltage to be able to display the video. The offical part that Panasonic was giving for this was PDPHDMIKIT, its basically a HDMI extender that regulates the voltage. The part is still available online, try partstore.com or andrews-electronics.
Apr 23, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
HDMI to DVI-D conversion problem. Not in compliance?
It souunds like te TV is having problems with the streaming data being applied Most plasmas with DVI connections were actually designed for PC type input signals  Unfortunately the TV's input may not be able to stand up to the stream of signal the DVD or cable box wants to display. You can try and lower the output of both devices to 720P Good luck to you
Feb 17, 2009 | Televison & Video
No Video from Denon AVR-588
It cant up-convert component to hdmi. Input and output has to be the same. However, you wont lose anything cuz hdmi and component are comparable
Nov 24, 2008 | Denon Audio Players & Recorders
Haier 42EP24S 42 in. EDTV-Ready Plasma Television Logo
389 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
