Question about E-Machines eMachines Desktop PC
I added memory to my desktop, hooked it back up and it goes beep, beep, beep. The memory is seated correctly, there are no lose wires, etc.I've read that some motherboards aren't wired to accept more memory and I should call it a day.I'm going to try to take out 1gb and see what it does. If it "beeps", I'll take out the other 1gb I added and pray it'll be returned to it's sorry original state.
  • smilipanti Mar 02, 2009
    You two were hitting the nail on the head. My Vista Business needs the extra 2 gb's but my bios needs to be updated to accept it.!
    Thank goodness for smart, helpful folks like you! Eternal Thanks!
  • smilipanti Mar 06, 2009
    I haven't had the chance to update my bios and really don't know how.
    The shop that built the machine for me said they'd check it out for me,
    for no fee. Whew! The memory cards were the 100% correct size and were seated correctly so you guys helped me a lot trouble shooting.
    Thanks for the support!
    Smiliepanties
  • 6,784 Answers
Depending on your unit and OS, xp will register 2 gigs and vista will register 4 gigs. also, make sure the mem you are installing is compatible to *********** board as well.
Posted on Feb 28, 2009
    President:
  • 2,653 Answers
You probably need to update your bios first before it will take the memory.
What's the exact model of your computer?
When ever I start this tower up it makes a loud beebing noise and does nothing and the cooling fan goes crazy fast
Hello. I was listening to the video and was listening to the beeping. That is usually a POST code that tells you what to look for. I am giving you a link to check the beep sequence to check a couple things. http://www.bioscentral.com/postcodes/dellbios.htm#. Usually If any cards, Video, audio, etc or memory are not seated properly, you can get this situation. Make sure the CPU fan is clean and the contacts are good to the motherboard. Some systems use a 3 wire plug. Hot, Ground and SENSOR. If the Sensor wire is not read, the CMOS will not let the system start either. This is to protect the CPU from overheating and cooking itself. These are a couple of things to look into. Hope this helps. Please let us know how it goes!
Nov 04, 2012 | Computers & Internet
Intel 31 3 beep sound solve
3 Beeps usually means a memory issue. If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Jun 02, 2012 | Intel DG31PR Motherboard
When I put memory in, it beeps at me & nothing comes up on the monitor
Is this a new memory module you are installing (are you REPLACING or ADDING memory)? How many memory slots does this computer have?
Make sure that the module is seated firmly by gently tugging at it after the locking mechanism is in place to make sure it doesn't fall off. Sometimes the lock engages even though the module is not correctly seated.
You may want to try the module on a different port and if it still beeps, the module may be faulty (if there are any other working and compatible computers to try it on, it will help isolate if it's the memory module or the motherboard's memory ports at fault).
If you have any other spare memory modules, you can try those as well. Whichever component (either motherboard or memory) the problem is isolated to will have to be replaced.
Feb 08, 2012 | eMachines W4685 PC Desktop
My computer lenovo desktop thinkcentre beeps 1,3,3,1 i chaged the memory RAM but no effect seen it continue beeping at booting process, please help me
Cause
Computer RAM (memory) related issue.
Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards. Information about ESD and proper grounding techniques are found on our ESD help page.
Remove added memory
Open computer and reseat memory
Sometimes when the computer is moved or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
Swap memory location
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
Try another computers memory
If you have access to another computer that uses the same memory, try using its known good memory in your computer.
If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced.
Replace memory
If it is determined the memory in the computer is bad we suggest that you replace it.
May 19, 2011 | Lenovo ThickCentre M58p Desktop 7479A3U
Dell Optiplex 725 Beeps at me at me at start up w/o complete start up. Screen Black. As if something is loose? Battery in Motherboard? Did something short out?
POST Beep Codes: OptiPlex GXi If the monitor cannot display error messages during the POST, the system may emit a series of beeps that identifies the problem or that can help you identify a faulty component or assembly. The following table lists the beep codes that may be generated during the POST. Most beep codes indicate a fatal error that prevents the system from completing the boot routine until the indicated condition is corrected.
Beep Code Error Probable Causes 1-3 Monitor not detected Disconnected or faulty monitor 1-1-3 NVRAM write/read failure Defective system board 1-1-4 BIOS checksum failure Faulty BIOS or defective system board 1-2-1 Programmable interval-timer failure Defective system board 1-2-2 DMA initialization failure Defective system board 1-2-3 DMA page register write/read failure Defective system board 1-3-1 Main-memory refresh verification failure Faulty or improperly seated DIMM or defective system board 1-3-2 No memory installed No memory installed or faulty or improperly seated DIMM 1-3-3 Chip or data line failure in the first 64 KB of main memory Faulty or improperly seated DIMM 1-3-4 Odd/even logic failure in the first 64 KB of main memory Faulty or improperly seated DIMM 1-4-1 Address line failure in the first 64 KB of main memory Faulty or improperly seated DIMM 1-4-2 Parity failure in the first 64 KB of main memory Faulty or improperly seated DIMM 2-1-1 through 2-4-4 Bit failure in the first 64 KB of main memory Faulty or improperly seated DIMM 3-1-1 Slave DMA-register failure Defective system board 3-1-2 Master DMA-register failure Defective system board 3-1-3 Master interrupt-mask register failure Defective system board 3-1-4 Slave interrupt-mask register failure Defective system board 3-2-4 Keyboard-controller test failure Faulty keyboard controller (defective system board) 3-3-4 Screen initialization failure Faulty video subsystem (defective system board) 3-4-1 Screen-retrace test failure Faulty video subsystem (defective system board) 3-4-2 Search for video ROM failed Faulty video subsystem (defective system board) 4-2-1 No timer tick Defective system board 4-2-2 Shutdown failure Defective system board 4-2-3 Gate A20 failure Defective system board 4-2-4 Unexpected interrupt in protected mode Defective system board 4-3-1 Memory failure above address 0FFFFh Faulty or improperly seated DIMM 4-3-3 Timer-chip counter 2 failure Defective system board 4-3-4 Time-of-day clock stopped Bad battery or defective system board 4-4-1 Serial-port test failure Faulty I/O chip (defective system board) 4-4-2 Parallel-port test failure Faulty I/O chip (defective system board) 4-4-3 Math coprocessor failure Faulty microprocessor chip or system board 4-4-4 Cache test failure Defective microprocessor or system board
Mar 30, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
Dell inspiron 530s won't boot up and gives me 4 beeps a pause, 4 beeps etc.
4 Beeps indicates a RAM memory failure. Disconnect power, press and hold the power button to release all power from the motherboard, then re-seat the Memory.
If error doesn't go away, try modules one at a time to find the bad one
Dec 27, 2009 | Dell Dimension 8400 PC Desktop
I get a continuous beep when trying to boot my HP 780N desktop.
Beeps like this can eminate from the memory modules, you need to check each module is seated correctly. TURN off the unit and pull the power lead out. open access to the memory modules and simply removed ach one completely then reseat it back gently, never force these things.
Do it to all modules. Hopefully this is all that is the issue. failing this you may have a faulty module so try without one or the other or all to see what happens.
Check visibly for othere clipped in units for the secure seating status. There is an error on the board that has developed and needs to be found by a process of elimination.
AndystUK
Nov 08, 2009 | HP-COMPAQ - P4B266-LA Motherboard
Computer does not boot up
Computer has three short beeps as it starts? computer RAM (memory) related issue.
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
Hope this helps.
Oct 22, 2009 | Gateway GT5404 PC Desktop
I get 3 beeps and no video on my gateway desktop
The beeps usually meen that the memory is either incorrect or not inserted correctly. Try removing the new memory and go back to the original configuration. Though not recommended, putting the memory in while still plugged up should not be the problem.
Sep 01, 2009 | Computers & Internet
Adding RAM
Those beeps are a series of codes that are telling you what is wrong. You can look up the beep codes and the LED codes on the back of the PC at this site: http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/adtshoot.htm That's the long route. The short route is that you likely either bumped your video card and need to re-seat it, or the memory you installed is not completely seated. Try re-seating it if you haven't already.
Sep 19, 2007 | Dell Dimension 4600 PC Desktop
E-Machines eMachines Desktop PC Logo
71 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
