Question about Eclipse CD1200 Car CD/ MP3 Player
Getting error 1 code on eclipse cd1200 when connecting ipod cable
Every time i connect ipod cable to cd1200 eclipse radio it reads error 1 what is wrong?
Easy...
If you read your owner's manual, page 45, it states "ERROR 1 = IPOD STOPPED SENDING DATA FOR SOME REASON"
Solution: Check connection with Ipod
Done!
Posted on Mar 01, 2009
Tip
How to connect your iPod to a Car Stereo
Many car stereos have more new connections that MP3 playerslike the iPod can be connected and played through the stereo. For new carradio, you only need to connect the device and the MP3 player. If you have anold stereo, connect your iPod or connect a 3.5 mm stereo cable or FMtransmitter. Connect iPod directly to the stereo with a stereo cable willresult in better sound quality on the FM transmitter, which can be interruptedor static signal.
AUX
1. Find an AUX port. The AUX is a hole, only small to belocated on your car radio face. (The size is perfect for connecting headphonesor an auxiliary cable.)
2. Connect the 3.5 mm stereo cable into the hole in front ofyour car.
3. Connect the other end into the hole stereo AUX jack /headphone jack on top of your iPod.
4. Connect your iPod.
5. Activate the AUX input. This will be different for eachcar. You may need to field through your input options (e.g., FM, AM, CD, etc.)to access the AUX. Or you may need for your stereo pressing the Menu button.Then, the options for auxiliary input field to the AUX input as possible.
6. Find a song on your iPod and press the Play button whenthe auxiliary input is activated. If you do not hear anything, make sure thevolume on the iPod device and radio. If the iPod is playing your song, you'llsee the song progresses on the iPod screen.
FM Transmitter
1. Find an FM transmitter that is compatible with the iPod.So let your FM transmitter near your car radio.
2. Connect the iPod to the FM transmitter.
3. Tune the radio to your car radio has a frequency thatonly static, then the vote of the same frequency channel using the buttons +and -.
4. Connect your iPod. Then a number and press"Play." Make sure to turn all your volume on your iPod. You should beable to use his music. If not, find a new frequency until you find one thatworks with the iPod and the transmitter.
on Aug 09, 2011 | Apple iPod touch
Tip
How to connect an iPod to my Bose Radio
<p>The manufacturer offers two radios Bose iPod connection kit to connect an iPod to the radio. You can purchase the kit to connect the wave or acoustic wave connect kit. Both kits come with a USB audio connection, an iPod dock for iPod, a battery that plugs into the wall and a remote control to use the iPod while in dock. Download all the upgrades to your iPod through Apple's website before connecting a Bose radio. <br /> <p><br /> <p>1. Connect one end of the audio cable is included with the connection kit for iPod "Aux In" on the back of the Bose radio. <br /> <p><br /> <p>2. Connect the other end of the audio cable to the "Audio Out" on the back of the iPod dock. <br /> <p><br /> <p>3. Connect the adapter to an outlet connection kit. Connect the other end of the battery to the "DC Power" on the back of the iPod dock. <br /> <p><br /> <p>4. Set the iPod dock on the right side of the face of Bose radio out. Align the IR sensor on the front of the iPod dock with the IR sensor on the front of the Bose radio. <br /> <p><br /> <p>5. Place the iPod firmly in iPod dock. Point the remote at the IR sensor, iPod dock. Press the "iPod" for the iPod <br />
My mp3 player will not charge
There are only several cause of this problem. They are:
1. defective battery.
2. loose wire connection.
3. corrupted firmware.
It's better to contact the manufacturer, and have them check or repair it for you. Only the manufacturer carries the firmware that will work best with your device.
Mar 12, 2010 | Eclipse CD1200 Car CD/ MP3 Player
My ipod wont restore becuse of error 2003 how do restore it ???
Read This, then get a new cable.
K first off this is an utterly pointless error that caused me to loose valuable files, info, and time.
I was using my ipod and it had been running into a few problems. Such as the time being wrong etc. I plugged it into iTunes and it wouldnt show up. I tried over and over without success. SO eventually i decided to put it into reovery mode. I plugged it into iTunes, it saw it and that it was in recovery. I clicked restore and everything went fine untill it got to actually updating the software. I got error code 6 and error code 2003. I found a tip to restart iTunes a couple times so i did without success. I then found another article talking about battery charges and cheap caples when i got a hunch. The night before i had added an extention cable to my ipod cable so that i could run it to my bed. I pluged the normal ipod caple straight into my computer, hit restore and BAM it worked. Thus I realied that there was no need for me to recover my ipod because let me tell you, 14 gigs of music and videos takes a LONG time to copy to my ipod.
If you have the same problem try this:
1. DO NOT GO INTO RECOVRY MODE
2. Make sure you have the ipod directly connected to your computer (no extensions or hubs)
3. Restart iTunes a few times
4. If all else fails enter recovry mode and hope for the best laugh4.gif user_offline.gif quote.gif
Apr 09, 2009 | Apple iPod touch
MP3, IPOD, CD doesn't appear when I press "Source"
Easy.
If you read your owner's maunal, page 26, the USB is designed for a flash drive (up to 4GB), not an Ipod.
If you would like to play your iPOD, purchase the IPC008 (Ipod Lead) and you're done!
Feb 24, 2009 | Eclipse CD1200 Car CD/ MP3 Player
Dxz785usb radio wont read ipod
IT MIGHT BE A CABLE ISSUE TRY A NEW ONE
Nov 13, 2008 | Clarion Car Audio & Video
How do I set up the clock?
Here are the steps to set the clock:
1. Check that the main unit is in standby mode (clock displayed)
2. Press and hold the [DISP] button
3. Turn the [VOL] button to adjust the time (Right: Minutes will advance, Left: Hours will advance)
4. Press the [DISP] button briefly
These steps were taken from the owners manual available at: http://www.eclipse-web.com.au/DOWNLOADS/Owners%20Manuals%202008/CD1200.pdf
Sep 24, 2008 | Eclipse CD1200 Car CD/ MP3 Player
Jensen VM 9311 iPod Classic
The new ipod will not work with anything other than 2008 alpine products. Apple embedded a chip in the actual cable that tells the ipod that it's ok to pay. What you need is an authentic apple video cable that can only be purchased at the apple store...then hook the inputs up to the video input on the radio.
Mar 28, 2008 | Jensen's VM9312 Car DVD Player
Pioneer ipod connection
You are using the wrong cable. you need the CD-IB100II. is a control box with cable
Jan 25, 2008 | Pioneer AVH-P4900 Car Video Player
Eclipse CD1200 Car CD/ MP3 Player Logo
586 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
