Question about Admiral AW22 Top Load Washer
Admiral Top Load Washer Model LNC6762B71 overflowed
Put load of jeans in washer. Washer began filling, but never stopped. Checked machine approximatley 20 minutes later to find water all over the floor and flowing over the top of the tub. Any solutions? Purchased washer 11/02.
  • ctobeck Feb 28, 2009
    Thank you, we'll check this out. The machine also makes a loud
    grinding noise during spinning. Sometimes have to spin twice to
    dry out clothes. We did replace the belt.
  • ctobeck Mar 02, 2009
    Thanks for your help!
  • Admiral Master
  • 3,361 Answers
Remove the control console cover. Find the water level switch.
It has a small tube attached to it.
Remove the tube and blow air through it. It is probably stopped up. Reattach it to the water level switch.
Look over the length of the tube and may sure it is not pinched.
Set the washer to spin and run spin for about 1 minute.
Then run water on a lower level and see if it shuts off.
If not replace the water level switch.
Posted on Feb 28, 2009
  • steve
    steve Feb 28, 2009
    You may need to replace the water pump also.
    Remove the water pump and check for blockage.
    It could be making the noise too.
    The noise could also be coming from tub bearings.
It won't turn on
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com Troubleshoot your Admiral Top Load Washer that has these following ... The machine will not complete cycle (fills but won'twash or agitate) I recalibrate it and it ... my washer will not startbecause of lid latch it is an admiral.
Sep 29, 2015 | Admiral Washer Control Panel Frame 35-5733...
How do i stop machine from filling up with water till it overflows
Sounds like you need to replace the water setting switch.
Oct 13, 2014 | GE WJSR2070B Top Load Washer
The washer water won't turn off once it has filled for all three load sizes.
Might be the water inlet valve at the back of the machine where the hose connects too, replace the valve and see if that fixes the prob
May 09, 2009 | Admiral AW22 Top Load Washer
Water fills to overflowing without stop
replace the hose ..connects to tank other end goes under console to water level switch so no level control
Nov 16, 2008 | Admiral AW22 Top Load Washer
Water Overflow
hi there,
i would recommend checking the water level switch or lid switch and also the cable leading to it. that is what sends a signal to the machine control to stop filling with water.
Oct 10, 2008 | Whirlpool LSR7333 Top Load Washer
Admiral Top load washer won't agitate and squeals
Sounds like the gearbox, unfortunatly this is sealed and is cheaper to replace the machine, presume the machine is quite old.
Jun 28, 2008 | Admiral AW22 Top Load Washer
My Admiral waher model # LNC6762B71 will not spin or drain
with the belt off the pump pulley should turn freeley if it does then with the belt off and in the spin position start the washer with the lid down the motor should run
it it does then you have a transmission problem
if the motor does not run then there is a electrial componet problem
May 17, 2008 | Admiral AW22 Top Load Washer
Admiral AW22 Top Load Washer Logo
434 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
