Question about Philips DVP642 DVD Player
When i play my disk in the phillips dvd player the picture comes out blue. I have this problem with all the cd i try to play. Is it because I have a hdmi tv?
  • Philips Master
  • 5,568 Answers
HDMI (High Definition Media Interface) is just a specific kind of interface, a connection type and can't really influence color.
No knowing which interface you are using, it's hard to make any suggestions but some connection types can suffer from an impedance mismatch which can cause color problems.
Sit down with your manual for each of these to see which kinds of connections you have that are common to both and try others you have to see if another type can improve the color problem you have.
Posted on Feb 28, 2009
How do i fix the dvd blue ray 3d player to load the dvd?
Most likely the laser is failing , try an audio CD if it works then it is a bad laser. A cd has much less data to read.
Aug 26, 2014 | MGD Top Quality Philips HTS3372D 1000-watt...
Phillips TV shows black and white only when playing DVD
If the DVD is built into the TV, try and DVD cleaner Disk.
If it is external, try a different DVD player and disk.
May 27, 2014 | Philips Televison & Video
How do I burn files to a disk to play in DVP3140
I'm assuming you're using a recent-build Windows PC. Here's the link from Microsoft: http://windows.microsoft.com/en-us/windows-vista/burn-a-cd-or-dvd-in-windows-media-player. Media player must be recent enough in version to burn disk media--otherwise, you must obtain a software product that will burn media for you. Your PC must also be equipped with a CD, DVD, or Blu-Ray burner. CD-R disks easily prove available from discount stores, music stores, electronics stores, or online.
As for compatibility, Phillips indicates that CD-R is compatible. I hope that you don't have a problem. That depends upon the media manufacturer and how its product interacts with the Phillips. Compatibility likely won't prove a problem. Certainly, check that out before the next trip....
Aug 20, 2013 | Philips DCP851 Portable DVD Player
How to get Magnavox MBP5320 to play from DVD-RW, DVD+RW, CD+RW disks?
there are 2 sensors in a blue ray player. if the blue ray sensor is burned out, it will only play dvd and should play a cd. mine blue ray players play all disks
Aug 01, 2017 | Televison & Video
A Sony RDR-GX210 DVD player I can play a CD - no problem but when I try a DVD, the TV screen says - ''loading please wait'' and then it drops back to the TV picture witha message - ''Can't play this disc''...
Hi Allan,
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
In your case the lens does not work on DVD , but only on CDs for the reasons above , that is quite common.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Sep 08, 2009 | Sony RDR-GX300 DVD Recorder
My DVD player Phillips dvp 5150 show a region error when i try to play DVD.
I have a a Phillips DVD player with the model number DVP 5150. when i tried to insert a CD in the player, it doesn't show the loading screen in TV. My TV ios of samsung, Please help..
Feb 02, 2008 | Televison & Video
Mp3 disk no audio when playing
First, make sure the CD is an AUDIO CD, and not a DATA CD
If you have recorded a Picture CD or MP3 CD
yourself, ensure that your disc contains at least 10
pictures or 5 MP3 tracks.
MP3(ISO 9660) 96, 112, 128, 256
kbps & variable
bit rate fs, 32, 44.1,
48 kHz
– MP3 discs, picture (JPEG) files
on CD-R(W).
– JPEG/ISO 9660 format
– Maximum 9 characters display.
– Supported sampling frequencies :
32 kHz, 44.1 kHz, 48 kHz (MPEG-1)
16 kHz, 22.05 kHz, 24 kHz (MPEG-2)
– Supported Bit-rates : 32~256 kbps
(MPEG-1), 8~160 kbps (MPEG-2)
variable bitrates
Oct 02, 2007 | Philips DVD 622 DVD Player
Philips DVP642 DVD Player Logo
78 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
