Question about Fisher and Paykel GWL11 Top Load Washer
Our fisher and paykel's aggitator has stopped
Tha agitator has stopped working...it will fill so far and then 2 lights will come on, on the control panel and it will beep saying there is a problem.
This only started when we moved the machine to a new house!
  • melshan81 Mar 01, 2009
    Thanks so much..can't seem to find the Teh sheet..could you please post the link for us.
    Many thanks for your help again
    Also i just checked the model and it is a MW511 if this helps any
    Thanks again
  • 145 Answers
Hi, welcome to FixYa.
Going by the fact that you said this happened after a move, I can suggest a couple things it might be-
1. This may sound too simple, but make sure that you don't have the fill hoses reversed (hot to cold and cold to hot) as this machine has a thermistor to sense water temp and it will fault out (That's the beep/lights) if this is the case.
2. You may have the drain hose shoved too far down in the drain or standpipe and getting a siphon condition.
3. You may have damaged the machine's "Out of balance" switch in the process of moving.
Look underneath the control panel for the "tech sheet" for that washer. it will have a "code matrix" which will pretty much tell you what the beeping and lights mean. For example one of the codes is relative to the hot/cold water.
If the tech sheet is not there, let me know, I can find one and post a link to it.
Hope this info is useful to you...
Posted on Feb 28, 2009
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
GW612 wont fill ith water
Try to swap the solenoids to see if that will fix the problem.
If it fixes the problem replace the faulty Solenoid.
May 30, 2013 | Fisher and Paykel Fisher & Paykel Washer
MW511. 2 & 7 lights flash, beeping. No agitate or spin?
Fault code 66 is pressure sensor is faulty
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
Apr 20, 2012 | Fisher and Paykel Washing Machines
My Fisher and Paykel Smartdrive 7.5 kg fwon't agitate
when they beep the main p.c.b bord has detected an error on the f/p series the main fault we have found with this is the small icb sensor that runs along side the capstan drive drum try cleaning it if this does not work try replacing the head control p.c.b bord
good luck
Jul 06, 2010 | Washing Machines
HI. I have an old F&P Smartdrive 085 and I am looking for the reset button on it. It was not completing the cycle and wouldn't turn off so I turned it off at the wall, waited for a while and turned it...
sounds like your motor controller is faulty.the sharp click u heard was the fuse on electronic board popping. unfortunetly there is no reset button. u might need a new controller.if u r not comfortable working with electronics it would b best to ring a repairer in your area. please reply 4 more help
Mar 09, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher and Paykel washing machine fills and won't stop filling...
If the water stops when you shut if off at the wall you have a bad cold inlet valve, or the valve is getting a constant "open" command from the controller and thus the controller is faulty.
Jun 18, 2009 | Fisher and Paykel (IWL12)
Fisher & Paykel WA37T26G Washer
I have one and they are right. Both the drum and the agitator turn so that the clothes are not beaten up.
Also the electronic motor control is fully variable speed. It will go as slow as! Dial up for wollens and it almost massages them. The cycle time is 1/3rd of a front loader.
Jul 20, 2008 | Fisher and Paykel IWL12 Top Load Washer
I was given a 2nd hand Fisher & Paykel SmartDrive051 washing machine a few months ago but now it is not filling with water or agitating in order to wash the clothes.
if some sort of control and lights on but just doesnt start then lid switch. if beeping instead of start then its found a fault. its well over 10 years old , may not be worth repair
Jun 19, 2008 | Fisher and Paykel Washing Machines
Washer repair.
Hall sensor may be damaged on the motor or the control isn't sending voltage to the motor
Sep 27, 2007 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel GWL11 Top Load Washer Logo
190 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
