Question about KitchenAid KTRP22EKSS Top Freezer Refrigerator
Kitchenaid Upright Frig/Freezer on Top/White
Frig has 2 columns of shelving next to each other. Was finding water on top shelf on one side. Now finding water on both top shelves. Looks like it is dripping from 2 openings above the shelves. Inside of openings have styrafoam as a lining. Guessing those openings have something to do with the freezer as they look like they lead up to the freezer but not sure. Both frig & freezer are working properly. Water is dripping very slowly. Can't see it drip but can feel the styrafoam is damp. Help! Thanks!!
SOURCE: water leaking inside of refrigerator from freezer
The defrost drain is frozen, you need to take the cover off inside the freezer and there will be a drain hole probably coverd with ice, you will need to pop most of the ice out first then I use a turkey baster and a tub of hot water. Squirt the hot water in the hole over and over again untill it drains. Then just wipe everything down. Problem solved.
Posted on Mar 18, 2008
jumptrout51
  • 3361 Answers
SOURCE: water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Posted on Mar 11, 2009
  • 56 Answers
SOURCE: Need two door shelves, Sub Zero, 251 RFD, the last two shelves
http://www.subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code will get you to the nearest SZ?wolf parts distributor.
Posted on Apr 23, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Water condenses on the ceiling of my frigerator..
Yes, you may have two problems. The seals around the door are defective or the drain to the pan below the refrigerator is blocked or both. I will need you to read a few things that may help you and I am here to help you get this solved. Now because the water is inside the fresh food compartment I believe the drain is blocked in sid the back and rear of the refrigerator. Look at the first link below and see if this applies to you. Then read the second link and ask me questions if you need. Please rate me and Thank You, Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
PART NUMBER AND MODEL SEARCH FEATURE
kitchenaid
-top-mount-refrigerators/">http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
Posted on Jul 15, 2009
lagringa15
  • 9 Answers
SOURCE: freezer in nice and cold but refridgerator is not
due to lots of moisture in the air or high humidity it creates extra frost in the freezing unit this creates blockage in the air flow once the ice crystals build up. the freezer is what keeps the fridge at the normal temperature if the air flow between the two are blocked in the ducting then the fridge temperature will rise the best way to solve this is to open the freezer take out the 4 screws in the back panel tilt the panel forward and blow it with a blow dryer till the ice chunk has melted its a good idea to use a towel and on the top self of the fridge to obsorb excess water this can be kinda messy. or you can unplug your fridge for about 6 or so hours. good luck hope i helped. :)
Posted on Aug 04, 2009
Why is the top shelf of whirlpool upright freezer not freezing?
Just had this issue. Freezer is packed usually & suspected airflow. Emptied bottom 2 shelves & vent strip was solid frost. Bottom 2 shelves were filled w/ solid roasts & other solid large items. Used blowdryer & currently waiting to see if it begins freezing top shelf.
Jul 03, 2014 | Whirlpool EV160NZTQ Upright Freezer 16 cu...
Kichenaid superba architect is warm up top
Check your freon level you can buy piercing valve for about 5 dollars low side pressure should be 11or12 on 134a after about 5 years I have found it sometimes seeps out of compressor
Sep 30, 2012 | KitchenAid Superba Architect KSCS25INSS...
Model #970658324 leaking water from the freezer to top shelf of frig once a week probably with defrost cycle. Help!
more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. Over time it gradually builds and starts voer a larger area. Being you have a top mount refrigerator(freezer on top) there are air ways that connect the freezer to the fridege, which is how its cooled. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt
If thats not an option that you want to use the actual repair method would be to 1) unplug the machine 2) empty everything out of the freezer so you'll have room to work 3) take all the shelving and baskets out 4) locate the screws on the rear wall inside the freezer and remove them 5) take the back panel off exposing the evaporator coils ( the aluminum ) 6) directly below the coils is a trough of sorts and the drain is usually in the middle and runs out the bottom, remove the ice by carefully chipping it out or by using a hair dryer or hot water. 7) once all the ice is gone, the drain is visible and water can flow smnoothly down the drain dry the area and reassemble.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 04, 2012 | Kenmore Refrigerators
Hi I have A GE 18 cube frig model GTA18QBNBWW. Initially the food on the top shelf was freezing in the frig I discouver the coils were blocked by massive clumps of cat fur. i cleaned it out. next day i...
you have done a good job so far . so next ck the dampner at the top in the fresfood side . it may be stuck open causing the freezing . but the evap coil was frozen so you may have a heater out in the freezer so ck the defrost system heaters and defrost terminator . ..mm hope this helps feed back pls
Jan 19, 2011 | Refrigerators
Upright freezer-only top shelf gets frost
it may be that the door is open a lot witch lets in warm air that go's to the top of your freezer and turns into ice so there maybe nothing wrong with your freezer, in winter we heat the house up and close all the windows this holds in the damp air,, in the summer it should be ok, but to test it place a thermometer in the freezer is should be about -21*f or there abouts for a 4 star freezer
Dec 29, 2009 | Freezers
Top shelf of frigidare manual defrost freezer only freezing, other shelves are not cooling.
Is the condenser clean? If it is you may have a refrigerant leak or an inefficient compressor.
Jun 28, 2009 | Frigidaire Freezer Refrigeration White...
Top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
Mar 12, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
FRIDGE SIDE SAMSUNG REFRI NOT COOLING
empty frig side totally shelves too remove white plugs too lite and both panels leave1 screw in upper narrow panel remove 2 shelf supports in middle of frig carefully pull on top of wider bottom panel with constant pressure its frozen behind i took hair dryer once seperated enough at top and dethawd till panel was removable totally thawed reassemble frig works fine
May 17, 2008 | Samsung RS2534 Side by Side Refrigerator
KitchenAid KTRP22EKSS Top Freezer Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
