Question about Fisher Refrigerators
F&P Fridge freezer N395BH cycle time
I would like to know an average cycle time for a F&P N395BH fridge freezer, ie. how long should it run and how long off with a freezer 85% full and the fridge half full. The ambient day temperature is about 24c av. and night about 18c. The traffic is via one person at home each day for a half day and two adults per evening. Thanks, Mike.
  • Fisher Master
  • 3,361 Answers
Most any refrigerator will run 75% of the time and off 25%.
Posted on Feb 28, 2009
What is the energy consumption in WATTS for my Samsung RT45M/RT41M/RT45E/RT41E Refrigerator? It is not listed in the manual
Thanks for the opportunity to answer your question.
There are many factors that will come into play in determining the actual energy consumption of your fridge.
These items include and are not limited to, How often it's opened (freezer especially), Where it sits in the house, does the sun shine on it? Does it have proper space for ventilation behind it and around it.
How full the fridge is and what you place in it.
The average consumption in Wattage on this fridge is 1200watts while running.
So to figure your yearly cost you will need to know how many times the fridge runs per day and how long it's running. You can then average that time over a month.
Usually you are only going to spend about 60-120 dollars per year to run the fridge if it's inside and used or opened about 10 times a day.
A good idea is to use empty plastic containers in your fridge where you have large empty spaces. This will reduce the amount of space in the fridge that it has to cool and will improve the cooling.
Should you have any further question please feel free to contact me.
Aug 24, 2011 | Samsung Refrigerators
How do you add a switch to disable the thaw cycle from an Amana top freezer fridge.I need to do so i can use solar power on my fridge.the thaw unit uses to much energy so when i am boondocking i can switch...
while i do not reccomend doing this since more energy is used in running the components to make is cool (compressor,compressor fan & freezer fan) all 3 must run to keep it cool while the defrost comes on for 25 minutes about once every 4 days as compered to the cooling components running a average of 24 hrs during the same time span as compared to 25 minutes is to disconnect teh wires from the defrost heater behind the freezer back wall
ps if you read this and give me a bad rating i do not care
Aug 11, 2011 | Amana ATB1832AR Top Freezer Refrigerator
Turned the fridge temperature up (ie. from 3 to 6) but fridge warmer than ever. Gauge on side ambiguous. Now wondering whether 1 is actually the coldest and 6 the warmest. Help! Fridge old so can't trace...
Keeping 3 to 5 degree is good. But check freezer is frosting good. If ice formation around the freezer is over, it will abstract the fan by functioning. If so, check defrost timer, thermostat and heater for not malfunctioning.If defrost cycle is good, there would be constant cool in fridge compartment.
Thanks.
Feb 03, 2011 | Fisher and Paykel Active Smart E522B...
I have a westinghouse virtuoso fridge the freezer is fine but the fridge is not cooling at all everything seems to be running motor wise
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 29, 2010 | Refrigerators
Sanyo Frost Free Fridge (Model SR 1031) very slow to cycle through freeze to defrost back to freeze cycle. The temp in Freezer compartment goes from -17 degrees to -1 degree then back to -17 as it takes in...
DO NOT TRY TO MODIFY TIMING CYCLE.you would need to completely modify printed circuit board and inbuilt computer......some freezers cycle around 6 to 8 hours.the temperature can only be checked say every 12 hours to get an average reading
Feb 10, 2010 | Freezers
Freezer works, fridge doesn't
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 27, 2009 | Refrigerators
Temperature Setting Dial in Fridge
Hi. thanks for the question. # 9 is the high, 1 is low. and it will run for 24 hrs to get on track .thanks the appliance doc
Oct 05, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Fridge "runs" constantly
unit should shut off when temperature reached ie compressor and fan stop.
condensor is just a grid of pipework
heater only comes on when in defrost cycle
Jul 12, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Fridge freezer controls
TURN THE FRIG. TEMP CONTROL TO COLDER THIS WILL OPEN THE FREEZER FLAP MORE AND LET MORE AIR IN FRIG.ALSO THE TEMP CONTROL COULD BE BAD,TURN ALL THE WAY OFF AN TURN ON SLOW AND LISTEN FOR A CLICK IF NO CLICK THE CONTROL IS BAD,THANKS-MIKE
May 25, 2008 | Freezers
Model # PLFU1778ES Fridgidaire
tilting it would not do any harm while running the tilting theory is if you lay a fridge over on its side the oil in the compressor can run into the suction tubing and it is recomended not to plug it in right away . this is to alow the oil time to run back into the compressor housing. did you posibly loose some air space around the freezer. refrigeration is all about the removal of heat. if you block the air flow around the unit it may not be able to aceave the low teperatur set points. hope this helped
Dec 11, 2007 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
Refrigerators Logo
242 people viewed this question
Top Fisher Refrigerators Experts
John Tripp
John Tripp
Joseph Hoffmann
Mike Cairns
Mike Cairns
Are you a Fisher Refrigerator Expert? Answer questions, earn points and help others
