Question about Craftsman 26 Hp 54" Deck Yard Tractor
Troy built tractor will not go into neutral
I have a Troy Built lawn tractor model 686 that shifts fine but when you place the shift lever in neural the wheels stay locked up as if it is still in gear. Do I need a new transmission?
  • dale188 Mar 24, 2009
    The problem was the brake pad on the rear axel shaft. I guess that cleaning the rear of the tractor off helped some but I cleaned and adjusted the brake and it works fine now. Thank you for the help.
SOURCE: 20 Year Old Craftsman Lawn Tractor Steering Gear Slips
check top of sector gear mounting plate for waer this is the gear that hooks to you steering gear . the plate that it mounts to will ware down causing it to be loos and slip . the only way i know to fix it is to pull the cross member out and take it to a welding shop and have it built back up.if the bolt is as tight as itcan go .
Posted on May 06, 2009
  • 86 Answers
SOURCE: Craftsman lt1000 with manual transmission,
The detent Shaft inside transmission lost its ball and spring if its working outside transmission,could be other damage .
Posted on May 09, 2009
SOURCE: Loss of drive in a Craftsman Lawn tractor
I also have a Craftsman tractor with the same problem. Sears repairman said it needed a new transmission and it would cost $1,400 to install. A new one is about $1,000. Anyway, if you remove the battery and the battery tray under the seat it will expose the transmission fill hole (hex). I opened the top and it looked empty. I had a bottle of 90 weight gear oil in my shop and filled the transmission to the top. I have not had any problems with it since. $4.00 bottle of oil verses a new tractor is worth a try.
Posted on Nov 30, 2009
  • 472 Answers
SOURCE: i hav a 42 inch y4500 lawn tractor. i hit a
yes you will have to bend the shifter you may have to take it off to do that
Posted on Mar 08, 2010
  • 110 Answers
SOURCE: I have a 14.5hp craftsman lawn tractor, model
Assuming you have a MANUAL (IE non-hydro) transmission ....
Can you shift with the engine OFF? If so, the problem is a dragging dirve belt transmitting power even though the clutch pedal is depressed. Check the adjustment, and that you have FULL travel on the pedal.
If you CAN'T shift with the engine off, then either the linkage is jammed/stiff, or there's an internal trans fault.
If you DO have a hydro trans, disconnect the linkage at the trans and attempt to move the lever on the side of the trans with vise-grips or similar. If you can move it without much effort, the linkage is siezed, if not, then internal trans fault.
Posted on Jul 17, 2010
Testimonial: "Thanks for the info. I thought it might be in the trans. but I was hoping there was a way to check the fluid. I can't find a plug or filler cap. And no, I don't have the manual. Vince"
My lawn mower model 425613x8a only drives in reverse what is my problem and how do I fix it?
I'am not to familiar,with this model number,of this tractor. But i do know that there is a safety switch,installed below the shift lever. Usually this switch,controls the neural,forward and reverse for your tractor. I suspect the forward motion contact is bad in the switch itself. You will have to remove the motion drive assembly and purchase a new switch,sometimes the safety switch is part of the whole assembly. You can find this assembly,under the shifting lever under the tractor,s floor. It could be on the right side or the left side depending on the location of the shifting lever.Sincerely,Brad Locke DTD 12/03/15
Sep 07, 2013 | Sears Garden
Change blades on a lawn tractor pony? troy built
just jack it up so you can get under the deck and unscrew the bolt on center of ech blade take note on how the curves of blade are angled do one at a time incase you forget but bolt back up tight and you are ready to cut if you try to resharpen the blades make sure you balance them or they will mess up the deck bearings
Nov 02, 2010 | Troy Garden
Troy built lawn tractors, belts
You may have a pully that is not spining freely. Or you may have a pully that is not positioned straight. Ariens had a problem with that. so your troy built may have the same.
Apr 19, 2010 | Garden
I have a Troy Built 6605 lawn tractor. The engine
check your belt might be off a pully or maby your spring is off
Nov 09, 2009 | Garden
I have a Troy Built lawn tractor, after removing
Clearly the cable either broke, came loose.
Aug 22, 2009 | Garden
Craftsman 42 in 19.5 unable to control speed forward motion
is this perhaps a hydro trans? if so, try putting the shift lever in neutral, then let off the brake pedal, use the shift lever to go forward and to neutral to stop - same with reverse, don't even use the brake pedal except for emergency stops. if it's a manual shift, it's possible the belt is incorrect, and/or the belt guides are bent or the belt is improperly routed - the belt guides are important as they allow the belt to "blossom" off the engine pulley, reducing the "shock" load when engaged - hope this helps
Jul 14, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Troy built lawn tractor won't start.changed plugs.
i have a troy bilt riding mower,i start the mower it only runs for 15 to 25 min's ,so i changed the coil to see if it would run long. but after a few minunts it stop again so i don't know if maybe it's my carb. what could it be.... help
Jul 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Craftsman 26 Hp 54" Deck Yard Tractor Logo
417 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
