Question about Euro-Pro 9000 Mechanical Sewing Machine
Machine won't sew at all
We have changed the needle, took the case apart and cleaned it all out, rethreaded both the top and bottom threads, touch the foot pedal and all we can get is chirping. We have tried different sewing stitch selections, and nothing happens. What do we need to do? Help!!!!!!!!!
    New Friend:
IF yOUR MACHINE IS STILL NOT WORKING WOULD YOU CONSIDER SELLING IT FOR PARTS?
Posted on Jul 17, 2014
  • 350 Answers
RE: Euro-Pro 9000 Mechanical Sewing Machine "Won't Sew"
I am wondering if you tried unplugging it for at least 1 minute to let it reset the onboard computer (sometimes they need to be unplugged overnight).
Try the following links....
FAQ @ http://www.euro-pro.com/europro/faqdetail.aspx?modelno=9000
Manual @ http://www.euro-pro.com/europro/manuals/9000.pdf
Customer Service @ http://www.euro-pro.com/europro/feedback.aspx
Let me know if I can assist further!
jackiaria
Posted on Feb 28, 2009
I am getting tangles on bottom of my work and an E7 error message.
try changing the needle--one for the fabric being sewed
make sure bobbin is turned correctly in the bobbin case
make sure top thread has not come off the thread take up lever
Feb 15, 2015 | Elna Sewing Machines
Thread bunching on the bottom of My Excel 23X suggestions how to adjust
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Dec 06, 2014 | Sewing Machines
Bobbin thread tangles
when this happens have you check to see if the thread has come off the thread take up lever?
Feb 09, 2012 | Brother CE5000 Computerized Sewing Machine
Brother xl-2600 As I am sewing ( not thick material) the thread keeps breaking, also over seams it is not sewing through. Then, when my bobbin ran out, went to change it and when pulling the needle down...
try changing the top thread tension to 3 or 4
also rethread the machine just in case the thread is hung up somewhere
take the bobbin out & put the bobbin in reverse of what you did before
you said you changed the needle, check to make sure it in correctly,, the flat side goes to the back of the machine, push it all the way up before tightening the screw
Aug 06, 2011 | Brother XL-5340 Mechanical Sewing Machine
I am sewing scout badges on a uniform and when I sew there is a bunch of needle thread bunched up on the bottom (the top looks fine). And the needle thread gets all caught up around the bobbin.
Clean out the bobbin area if there are any thread tangles there.
Refer to the maintenance section of the manual - see the configuration of the bobbin case and shuttle race? The bobbin case as an extending arm and the race a notch. When inserting the bobbin case into the shuttle, turn the handwheel so the needle is at it's highest position. Then lift the lever on the back of the bobbin case and insert the cast into the shuttle, arm pointing straight up toward the bed of the sewing machine.
Now thread the machine with the presser foot up - always - and see if the tangling stops.
When you forget to lift the presser foot before threading the machine, the tension control does not open to capture the thread. Then when you begin to sew, the top thread has no tension, and the bobbin thread, which does have tension, pulls the top thread to the bottom in messy loops.
Jun 25, 2011 | Kenmore Sewing Machines
Bottom thread too loose; tried rethreading top thread, cleaning bobbin case, refilling bobbin, changing needle, adjusting top tension
Check for correct bottom thread tension.
It's provided by a flat spring on the bobbin holder.
When the bobbin is correctly installed, pulling on the thread
should meet with slight resistance, and the bobbin should spin without
trying to jump out of the bobbin holder.
Dec 18, 2010 | SINGER 7470 Sewing Machine
The bobbin is not preforming properly. It jumps around when I sew and then on the back of the fabric there is a ton of excess thread.
Change needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin
Check tension 3 or 4 is usually good
if the bobbin is top loading they will flop around some when the start getting close to empty
if it's a bottom loading bobbin & case then it's not inserted correctly
Nov 24, 2010 | Singer 7442 Mechanical Sewing Machine
Loose thread on bottom of fabric and locks up needle
Change needle
& bobbin
Nov 23, 2010 | Toyota STF17 Sewing Machine
I have had a singer prelude 8280 for a year now with no problems. now all the sudden the thread is catching in the bobbin casing. The thread on top looks normal, but when you turn over the fabric...
change the needle
clean under the needle plate where the feed dogs are for lint
Nov 20, 2010 | Singer 8280 Mechanical Sewing Machine
Puckered seams :-(
Try using a walking foot. It could be it's not the bobbin but the way the two layers are feeding together. Or, change feet. Or, try a new needle. Rethread the top needle, too--sometimes this alone fixes the problem.
May 09, 2017 | Kenmore 19233 Computerized Sewing Machine
Euro-Pro 9000 Mechanical Sewing Machine Logo
264 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
