Question about JVC HX-C6 Shelf System
My JVC HX-C6 is locked and i cant get a single cd out of it how do I unlock it?
  • bear7880 May 15, 2009
    turned on stereo sfter powere outage it says protect will not do anything? needs unlock code
Push the STOP button then lift the CD tray while holding the STOP button. then you release the STOP button, then the tray.
Posted on May 06, 2009
I cant find the AUX input in my JVC HX-Z1 Compact Stereo System
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/JVC-HX-Z1-manual/id/314dj297/t/2/
Page 3, item 8. Explained on page 10.
Apr 17, 2011 | JVC HX-Z1 CD Shelf System
Jvc hx-c6 is in protect mode help
check speaker wireing if thats not the pro then u may have over heated the unit.the stk xxx exc are pro bad youll have 2 open that bad boy up.
Jan 31, 2010 | JVC HX-C6 Shelf System
Jvc speakers with sony system
yes. the impedance should be 6 or 8 ohms.,should be fine.
Dec 05, 2009 | JVC HX-C6 Shelf System
JVC HX-C6
Hello, Yes you can, if they are the regular speaker wire (2 wires--black+red or something similar)
Nov 22, 2009 | JVC HX-C6 Shelf System
Protect comes up on my hx-c6
That is the common symptom of the defected STK-IC in power amp.section that busted already or just a loose connection.First try to resolder the pins of STK-IC and also all component parts joint in power amplifier section if its works! if not that is the time you replace it, so it works normal again.
Hope it may helps you...
Jun 12, 2009 | JVC HX-C6 Shelf System
My brother connected my HX-C6 shelf system to the pc and now it turns off and says PROTECT.
sounds like he may have run the wires from the computer speaker out plug instead of the line out plug. Check that by plugging headphones into the back of the computer where the cord is. If the sound is loud through the headphones, try plugging them into the other out plug. The correct plug will not have much volume at all through the headphones. Try this and let me know if it helps :)
May 06, 2009 | JVC HX-C6 Shelf System
JVC HX-7 (protect)
The problem is that the output amplifier section has a problem and the protection circuits are shutting down the system to prevent further damage. This should be a simple repair for any local service shop. If you can't find someone local, look up at the JVC website for an authorized service center. Use your zip code to locate the closest one.
Dan
Sep 29, 2008 | JVC HX-C6 Shelf System
JVC HX-C6 goes directly into "Protect Mode".
I received a reply promptly from JVC to check power connections for shorts. O course I had already done that. So as a last resort, I pushed the power switch on and held it for maybe 10 seconds. It seems to have reset the unit, and it's playing fine. Best of luck, hope you all read this and it works for y'all. AJ
Sep 26, 2008 | JVC HX-C6 Shelf System
JVC HX-C6 Shelf System Logo
178 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
