Need a mike wireing diagram for a kenwood trio ts700g transceiver
HI I need a wreing diagram for the trio ts700g to wire up a mike that can be used to transmit on vhf
Hi Mikeymc_2,
With the Connection pins on the plug facing you and the Locating groove in the 6 o'clock position, the pins are numbered from 1 - 4 in an anti clockwise direction.
Pin #1 Microphone
Pin #2 PTT
Pin #3 Chassis Ground
Pin #4 Microphone Ground
Info is from Kenwood. Subject ; Misc Connectors. 26 / 01 / 99. Hope this helps. 73. REX 9Y4PM.
Any problems contact me at rmclea@tstt.net.tt
Posted on Feb 28, 2009
Need wiring diagram for Kenwood KDC-X679 CD receiver for my 1997 Chevy truck
The manual for the Kenwood Excelon KDC-X679 has the wiring diagram for the connections to the car/truck on page 33. Crutchfield has the manual on the product page: http://www.crutchfield.com/S-FpCU7SY0yQm/p_113KDCX679/Kenwood-Excelon-KDC-X679.html . (Click on the Details tab.) The direct link to the manual is http://pdf.crutchfieldonline.com/ImageBank/v20050828082600/Manuals/113/113KDCX679.PDF .
Kenwood also has the manual on their support page: http://manual.kenwood.com/en_contents/search/ . Just enter the model number. On this site, you can find the manual is several languages. The direct link to the English version of the manual is http://manual.kenwood.com/files/B64-2764-00.pdf .
I hope this helps.
Jan 30, 2016 | Kenwood Car Audio & Video
Magnum delta force radio wiring diagram for Mic turner 2pluse 2
Must know the pin out of the transceiver your wiring it too.
like cobras 1.ground 2.audio 3. TX 4. RX... then wire accordingly.(same as the 4 pin exports)..
Use a ohm meter to find the correct wires on your mic switch.
then you know how to wire any mic to any transceiver.
This will work for the turner 2+2
Aug 24, 2014 | Radio Communications
Do u have the wirring diagram for a turner+3 desk mike 8 pin to a kenwood ts140s
only 3 wires needed .. shield(ground) on 7, white(audio) on 1, black(transmit) on 2
Aug 18, 2014 | Radio Communications
Kenwood tr 9130
http://myradio.piczo.com/microphoneplugandsocketpinouts?c
states that the pinout is as follows.
I believe this is a semi standard connector that you can find at "some" radio shacks. If not you can take any Kenwood mic and soldier the wires to the old plug.
If you want a new connector try Mouser or Allied.
KENWOOD-TR9000-9030-9130-9300-9500-7700-7730-7750-7800-7850-7930-7950-8400
PIN1 MIC
PIN2 PTT
PIN3 DOWN
PIN6/CENTER EARTH
PIN4 UP
PIN5 NC + 8VOLT SOME MODELS
Jul 01, 2014 | Radio Communications
Need a wire harness plug for a kdc319
Kenwood adapter looms are readily available from your local Auto Accessory store, of from Ebay.
These are a 'plug & play' solution (pre-wired), which eliminates the need to cut any of your existing vehicle's wiring.
Ideally, you want a single adapter loom with Kenwood plug on one end, with your vehicle's "factory" plug on the other (all common brands are available).
e.g. Kenwood ---> Ford; Kenwood ---> GM etc etc
Cheers,
Dec 30, 2012 | Kenwood KDC-319 CD Player
Voltage of the backlight on the Kenwood TS-60 Need to replace the backlight on the Kenwood TS-60 Transceiver radio. Need bulb voltage, type or number. Any specifics would be helpful
check voltage of existing wire leads....any 12 volt wheat lamp will do or use resistor with 6 volt....copper electronics carries 12 volt grain of wheat replacements for .49
Jan 25, 2010 | Radio Communications
Need a wiring diagram please
wiring diagram or colour code for kenwood cd player model kdc-5108
Nov 16, 2009 | Kenwood KDC-W3534A CD Player
Open the frequency from 137-173mhz in th-th-k2e transceiver
google mods dk look under kenwood modifications. you will have to join membership is free basis a fee for premium downloads. you can get this mod free.
May 14, 2009 | D-Link DHP-301 Transceiver
Mike cable needs rewiring on Kenwood KMC-35
downloaded the schematic of the radio and figured it out myself
Jan 08, 2009 | Radio Communications
When I turn off my car my stero resets all it's setting
Mike
Here is a owners manal and wire diagram on page 55. You have the yellow wire hooked up wrong need to put to a constant hot not one on a switch.
http://inform3.kenwoodusa.com/manuals/KDCX889.pdf
Good Luck
Dec 18, 2008 | Kenwood KDC-MP628 CD Player
Computers & Internet Logo
375 people viewed this question
David Payne
David Payne
