Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series - machine won't rinse or spin
Tried to wash a load last night - wash cycle works fine, but when I went to switch the laundry, the clothes were sitting in the water and the machine stopped after the wash cycle and would not rinse or spin. Any ideas??
I really hate to have Sears come out and drop a small fortune on this repair.
  • 1 more comment
  • kmaxa13 Feb 28, 2009
    Thank you! The model number is 23812100. Moving the timer manually does nothing.
    From reading other similar problems here, sounds like it's the lid switch to me. I just wish it was easier to fix.
    How difficult is it to change the lid switch? I thought I saw some instructions how to do this and it requires disassembling the majority of the machine. Is that right?
    Can you tell me where I can buy the lid switch?
    THANK YOU!!!
  • Kenmore Master
  • 3,361 Answers
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
Posted on Feb 27, 2009
  • steve
    steve Feb 28, 2009
    You have a bad lid switch.
    You can change it yourself.
  • steve
    steve Feb 28, 2009
    Sears or any appliance parts house in your city has the switch.
    Remove 2 phillips screws on the right and left corners of the control panel.
    Lift the control panel to the rear of the machine.
    Snap out 2 metal clips holding the cabinet to the rear of the machine.
    Unplug the wire harness connector to the lid switch.
    Remove the cabinet by pulling it forward.
    Remove the old lid switch and install the new one inside the cabinet.
    Reverse the above order to re-install the cabinet.
    Make sure the bottom front of the cabinet goes UNDER the front chassis frame.
Have same kenmore mod# 23812 that was my exact problem people shutting the lid to hard broke the switch.
Posted on Mar 14, 2010
Will not spin or drain tried unplug and lid switch is fine fill ok
Susan call your service repairman the warranty should cover the fix .
Dec 09, 2015 | Washing Machines
I want to keep the water in my Roper top load washer overnight so it will soak the load of whites I have started but the machine drains.
You should be able to select a soak cycle without having to turn off the water supply, but it may time out eventually and drain the tub. This p[events oversoaking the clothes
Oct 13, 2012 | Roper RAS8445KQ Top Load Washer
Kenmore series 80 washer won't drain after wash cycle
Try the 'drain' portion of a few of the other cycles (heavy, perm. press, delicates) and see if it will drain/spin there. You can also try advancing the timer slowly through the 'spin' portion to see if it kicks in anywhere.
If it will rinse and spin in the other cycles, you most likely have a bad timer.
Hope this helps.
Sep 25, 2011 | Kenmore 22422 Top Load Washer
Kenmore 80 Series Washer is not draining. Worked fine for first wash last night, but did not drain on the second. Anything that can be done by us to check this problem?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 25, 2011 | Kenmore Washing Machines
I have a WD 1049C front load washing machine and behind the front seal there appears to be a mould buildup. How can we clean this area?
you would need to take out the whole drum assm....in other words you will need to dismantle the whole unit.....first thing first get lysol aerosol spray and spray around were there is mold.....i would take the unit outside and then spray it.....becuase once the mold have been disturbed it will find another place to live on......next u will need to use front load HE detergent......when you wash your laundry....start with the cold water clothes first then the last loads use hot water so it will wash clothes and disinfect at the same times...
lastly after all luandry have been washed ........open washer door over night so it can air out.......if not opening it at all the water and detergent that sits over night can cuase mold buildup and foul odors.....the gaskets are air tight and can not evaporate when door is closed.....
if your house has a/c i would put a fan in front of the washer over night..............
a feed back would be good if this helps anybody.....
my opinion........
the older top load washers are better..............
Apr 11, 2010 | LG WD-1045FH Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
984 people viewed this question
Sal De
fordexpert
Robert Rankin
