Question about GE Profile Spectra JGBP79 Gas Kitchen Range
Oven comes on and hits the temp and turns off
The oven turn on and heats up for about 5 min and then turns off. When the overn turn off the top burner and the clock shut off. It's like the oven as a shut off switch. Clock ups back on and the oven works again.
  • GE Master
  • 3,361 Answers
Unplug your range. Then open the control panel and remove and re-install all the wires one at a time.
Sounds like a loose connection.
If that does not correct the problem replace the electronic control.
Posted on Feb 27, 2009
Kenmore 790.70603013 oven and broiler do not heat up, no gas smell and no ignitor glow. Top burners work and overn light is functional.
You will need to replace the igniter in the oven. Here is that part to order.
All parts come with a 365 day, any part, any reason return policy.
Oct 24, 2013 | Kenmore Kitchen Ranges
It doesn't turn on - no ignitor glow, suddenly
Hi and welcome to FixYa. I am Kelly. Without a model number we are pretty much shooting from the hip here. Having said that it takes all of the following to make the oven burner light:
1. Gas pressure to the gas valve and good solenoids (2 ea)
2. Power to Oven control and selector knob set above min temp
3. Over Temp sensor closed
4. Temp control "thermocouple or thermistor" functional
5. A functioning ignitor
So if you have power to the unit... and we assume the oven control is working.. suspects are:
a. Open ignitor
b. Open flame sensor
c. Open over temp sensor
d. Thermocouple or thermistor (depending on model)
e. Open coil on gas valve
Determining which of the above has failed is performed with an Ohm Meter.
If there is more that we can do for you just respond here.
Thanks for using FixYa.
Kelly
Apr 02, 2010 | Magic Chef 9122 Gas Single Oven
Build in Over Gas - Oven does not heat
I called a repairman it was the igniter.
Jan 26, 2009 | Magic Chef 9122 Gas Single Oven
Oven not heating KitchenAid KERC506HWH3
It could be the sensor. Remove the sensor and check for 1 to 1.1K ohms. at room temp. If that's not the problem it may be the oven solenoid on the burner. You can also have a problem with the door lock making when it shouldn't check that also.
Dec 21, 2007 | Kitchen Ranges
Fagor overn doesn't heat
I had a similar problem - turned out the knob on the left by the clock was set to automatic instead of manual.
Dec 15, 2007 | Fagor 5HA-196 X Single Oven
GE RANGE MODEL #JGBP35BEA2BB
Sounds like that ignitor is weak.  When the ignitor glows it builds up resistance to the gas valve for gas to come in.  If it sometimes takes 10 min then the proper resistance isn't there and this will give you that gas smell.  Replace the ignitor and this should solve your problem.  Can expect to pay $80 - $100 for the part.
Oct 14, 2007 | Kitchen Ranges
Both ovens do not heat max heat is 150 to 200
good luck.  We have the same range and have had issues with the ovens since the range was installed.  The overn does not heat evenly on convenction or bake.  Thermadore doesn't stand behind the product and neither does the distributor.  They tell us that Thermador isn't standing behind the product so there isn't anything that can be done.  We spent $8000 for an oven that burns the back corners of everything we bake.
Mar 21, 2007 | Thermador PG484GGEBS Stainless Steel...
GE Profile Spectra JGBP79 Gas Kitchen Range Logo
160 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
