Question about Canon PIXMA iP3000 InkJet Photo Printer
I need a service manual for the canon ip3000 or how to open it up and get inside a it don't work. have checked power supply. a good 9volts. but printer has no life in it.
  • bgraeme Feb 28, 2009
    of course i have reader but problem is finding a service manual . no prob to read once i have found it . i think it maybe in power supply but need to know what voltages to test for and where.
Here is a link to disassembly of iP4000 which is similar to iP3000
Posted on Jan 02, 2010
Here is a link to a 43 page service manual. Unfortunately, doesn't have disassembly instructions!
(File is in a '.rar' archive. I used 7Zip to open it.)
Posted on Mar 26, 2009
  • 54 Answers
Do you have the latest version of Adobe Reader....if not get it. Then lookup manual for your product and get that too...Goodluck
Posted on Feb 27, 2009
  • leprof969 Feb 28, 2009
    These printers when they go...they foftunatly really go......fus inside is usually an electronic component....They are unfixable
My Canon iP3000 printer just stopped working as if unplugged from mains.
As with most modern electronics, your unit has a 'switched-mode' power supply and most are built well enough to outlast the warranty.
They are very efficient but the kind of service some parts (especially electrolytic capacitors) are subjected to adverse conditions.
If you want to try a DIY analysis, remove the housing from your unit and locate the power supply; if it is modular, you may have to open a second case (much smaller).
Power supplies are easy to identify since they are clearly a different animal than found on the main boards, being made up of coils and larger semiconductors than the other functions.
If you gain access, look for cylindrical components mounted perpendicular to the circuit board with a plastic foil jacket and an exposed aluminum top, there may be a lot of different sizes but these are the most likely failures.
Since they can burst when failing, the aluminum is scored in a 'Y' pattern to enable a more gentle bursting.
Check them closely and look for domed (bulging) tops. These are close to dying and typically no longer able to function as designed.
They vary in quality so replacements can be better (longer-lived) or worse.
Most techs will know which replacements are best and the cost difference is low and negligible.
Good luck-
Dec 12, 2014 | Canon PIXMA iP3000 InkJet Photo Printer
How to run a cleaning cycle on the iP3000
Hi Rebekah, this site will help get the manual, select: table of contents, all details are there, select print head cleaning. You can download the manual for further need. good luck.
Dec 13, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
Driver Printer Canon Pixma iP 1300
you can install new latest software drivers for
Canon Pixma iP 1300, just download your canon printer drivers form canon support website or any other support website, just you need to find out your printer model and operating system
You can download drivers from
Oct 18, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Canon printer
Remove the print head and try powering it up. If it powers up, then your print head is shorted and will need cleaning or replacing.
May 22, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
My printer power wont turn on when i press button
Try removing your printer cartridges and then the print head from the printer. If the printer powers up with the print head removed, then the print head is either shorted or clogged. If it's shorted out then you will need a new print head (usually cheaper to just buy a new printer). If you can clean the print head without damaging it, sometimes it will work again. Usaully a good 24 hour soak in alcohol or a cleaning solution will work.
May 09, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Printer won't start.. Working yesterday won't come on today... Plugged in and attached to computer??
Check the wall outlet.Plug something else and see working.Unplug the printer from power cord and wait 30 min.Then plug it.If not working there is a problem in power supply in printer.Look for service in your area.
Nov 18, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixma ip3000 flashing amber 6 times
If the 6 flashes are accompanied by an on screen message #5400, this is a "Service Call Error" code.
This code indicates the following;
Internal temperature error [5400]
The solution to this is the following part replacementl
- Logic board ***'y (QM2-1548) *1
*1: Before replacement of the logic board ***'y, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or
more, also replace the bottom case unit (QM2-1205) or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864 / 4221 / 4257) when replacing the
logic board ***'y.
[See Section 3-3. Adjustment / Settings, (6) Service mode, for details.]
Good luck!!!
Jan 12, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
The paper feed on my canon pixma iP3000 is not working
You can search on internet for service manual, in order to find how you can open the printer and fix the issue.
Dec 09, 2017 | Canon PIXMA iP3000 InkJet Photo Printer
How to check the PSU for IP3000 printer
I've just checked mine as it suddenly stopped working - does not even light up the green button.
I'm getting 8 volts Red to Black and 23 volts Red to Yellow so I guess it's fubared?
Dec 04, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
570 people viewed this question
old marine
old marine
