Question about JVC Video Cameras
Error message ''condensation operation failed''
JVC GR-D70U Has not functioned in three months.
1. There is a silver condensation detector in the tape compartment, rear left corner. You can try cleaning this with isopropyl alcohol. I have tried this, and it did not resolve the problem.
2. You can open the camera and unplug the power connector. This will reset the camera, and will resolve the issue for several months. I suggest looking further on this site, where there are instructions for which screws to remove to do this. I have done this, and it has resolved the issued for varying lenghts of time on my GR D30U.
Posted on Apr 13, 2009
  • 350 Answers
Try this...
Condensation means moisture in the systems so you need to dry it out!
Remove batteries.
Leave batteries out and store the camera in a warm dry place for at least a week.
I'd put it in the car where the floor heat comes out and turn the heat to maximum high fan and heat with the air conditioning button on (air conditioning removes moisture) then crack the window so it doesn't get too hot in the car.
The longer you do this the better chance you have of drying it out!
Let me know if I can help any further!
jackiaria
Posted on Feb 28, 2009
When trying to record or replay, I'm getting an error message that says "Please wait - Condensation, Operation Paused." I've waited now over a week & still getting the same error...
Put the camcorder in a warm dry place for a few hours, there is moisture inside the unit, that triggers the humidity sensor and shuts the camera off. If after drying the camcorder for a reasonable time it still will not function you will need to get it repaired.
Mar 03, 2011 | JVC GR-D90U Camcorder
My JVC GR-D22U is showing a message "condensation,
This is usually caused by a failed component in the moisture detection circuitry within the camera and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Feb 27, 2011 | JVC GR-D22U Camcorder
Lens cap
You JVC GR-D70US camera has problem with CCD Imager and JVC will repair it free of cost.
Please click JVC Offer for details.
Regards,
Sep 10, 2008 | JVC GR-D720 Mini DV Digital Camcorder
JVC Picuture gets blurry
The ccd block is starting to fail. Thats the chip thats the eye of the camcorder at the back of the lense assy. Its mounted on a small circuit board. You can find the chip at parts.com. Its just a matter of dissassembling the camcorder and removing the chip from the board and soldering another onto it taking care not to over heat the chip. You do need good soldering skills.
Tim
Aug 24, 2008 | JVC GR-D22U Camcorder
Condensation, operation paused, JVC Video Camera model GR-D70AS
If the camera becomes damp or cold and brought into a warm atmosphere damp forms in the mechanism which would cause the tape to stick and become damaged or fouled.
leave the camera to warm up for a few hours and the fault should clear.
If not the most common reason is the dew sensor has failed and needs replacing
Apr 27, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
Gr-dx97 - condensation, operation paused message on screen
Dec 31, 2007 | JVC GR-DX97 Mini DV Digital Camcorder
JVC CAMCORDER
I have the same problem and I need a solution. Please, can somebody help?
Dec 19, 2007 | JVC GR-D90U Camcorder
JVC Digital Video Recorder Problems
Most models of cameras have a built in feature to give you a message and turn off if it has condensation on the inside components. Powering back on during this period can cause damage to components. It should remain off in a warm dry area. Condensation might occur in high humidity, or when switching from a cool location to a warmer place. Try cleaning your video heads with a "cleaning tape" let it play for 10 seconds then pause. If that solves nothing your camera may have permanent damage in which case JVC or a repair shop will have to replace parts.
Sep 22, 2007 | JVC GR-DX100EK Mini DV Digital Camcorder
Jvc digital video camera GR-D20 condensation error
Did you ever get this fixed.  I have the same problem and can not use the camera.  please let me know.   thanks
Sep 02, 2007 | JVC GR-D20 Mini DV Digital Camcorder
Problem with JVC GR-D70U
It's ... a. A broken connection. b. A failed chip or component. It is not something an owner usually can repair.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Video Cameras Logo
557 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
