Question about Nextar MA933A MP3 Player
I dont know how to charge it
I plugged it into the usb port but it wont charge
It actually has a battery in it. You need to take off the little end cover and then you can slide the battery cover off. It's on the back.
Posted on Mar 01, 2009
The charger wont go in to the port to charge it and the tablet needs to be charged it was working just fine last night dont know if my son did something or not
Robin, the charge ports can be changed at a computer or cell phone repair facility. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android tablet charging port fix
How to replace the fixed charging port
How to Fix Tablet Charger Port
Amazon com 2 pcs Replacement Micro USB Charging Port Connector for Vizio...
Apr 24, 2016 | Tablets & eReaders
Can I hook up a 4 port usb hub backwards?
well if you plug the usb cord that powers it into some thing else that has a usb port that is running electricty through it such as a pc you should be able to plug in any thing that needs charging with a usb cord that will go into the 4 ports . so i guess it should work i know it wont mess anything up so go ahead and try it. also if you got a usb wall charger that can hold a usb cord you can plug the 4 port usb hub into that and it will work like a charger for things with usb chargers.
Dec 17, 2012 | Video Game Consoles & Games
How dont know how to charge my mp3 player
Some things to check for when your player does not act like its taking a charge. USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player. USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems). USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device. Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery. Latest firmware Depending on what player you have, make sure it's up to date with the latest firmware. AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
Dec 25, 2010 | Philips GoGear Flash MP3 Player
Charging batteryif i dont have a device to charge the actual batt
Yes, assuming the USB port into which you plug it provides enough current. Not all computer USB ports put out enough current to charge other devices.
Jul 11, 2010 | Vivitar ViviCam 8025 Digital Camera
I have ipod nano 1st gen and my ipod wont detect by itunes even my explorer using USB 2.0, i have firewire port wall charger when i try to plug it it charge but idont know if it will work to computer cause...
There might be a few issues here:
1. Your ipod software needs to be updated
2. Your usb cord is bad
3. Your usb port is not working properly
Either find someone that has a firewire port and update it via itunes, or use someone elses computer to update your ipod's software.
www.huskyipodrepair.com
http://repair-scratched-ipods.blogspot.com
Jan 26, 2010 | Apple iPod nano
Will not charge thru the USB or the car charger. Is the battery replaceable?
a magellan 4040 can not charge through the USB port and if it wont charge with a known good car or home charger, then read below.
This is very common problem with this and many model of magellans.
Try the car charger.
Make sure
green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 2000, 2200t, 2500, 3000, 3100, 3140, 3000, 3050, 4000, 4040, 4050, 5310 and the 6000 are known to have faulty dc connectors...if your Magellan
gps is not charging or will not power up, its most likely the dc power port...
You can
buy the port or get it repaired, HERE
if the links dont work or If you need further help, just let me know.
Jan 18, 2010 | Magellan Maestro 4040 GPS Receiver
I dont know hopw to charge it
thats because it doesn't charge plugging it in lets you sync files from your comp it runs on batteries open the usb cover then slide the bottom off to replace the battery.
Feb 27, 2009 | Nextar MA933A MP3 Player
My itunes won't detect my ipod nano 4gb
hi my name is silvana, i want to know how to download music to my ipod nano
Apr 27, 2008 | Apple iPod nano
Wont charge
hello, i think you are haveing the same problem i am having. i dont know for sure but i think the usb has to be a 2.0 usb to charge.
Jan 10, 2008 | RCA OPAL M4001 MP3 Player
Nextar MA933A MP3 Player Logo
Top Nextar Audio Players & Recorders Experts
Robert Graf
 Grubhead
Grubhead
topcat7736
Level 1 Expert
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
