Question about Apple iMac G4 Desktop
The screen on my Apple Powerbook G4 goes dim and sometimes out.
It doesn't have anything to do with the brightness of the screen. I thought it was my power supply. Could it be my battery is going bad? The computer is almost 4 years old and on the same battery.
  • 2 more comments
  • trieva Feb 28, 2009
    It doesn't always do it. It starts strong and all of the sudden it goes dim. When I shift the computer. When I do a restart it seems ok until it happens again.
    Is it expensive? I am toying with the idea to get a new laptop.
    Model Name: PowerBook G4 17"
    Model Identifier: PowerBook5,7
    Processor Name: PowerPC G4 (1.2)
    Processor Speed: 1.67 GHz
    Number Of CPUs: 1
    L2 Cache (per CPU): 512 KB
    Memory: 2 GB
    Bus Speed: 167 MHz
    Boot ROM Version: 4.9.1f3
    Serial Number: W85350QTRJ3
    Sudden Motion Sensor:
    State: Enabled
    Version: 1.0
    OK. THANKS SO MUCH for all your help! Guess I'll bite the bullet and taking it into an authorized dealer to see the damage.
    Have a good evening!
My screen was getting dim as well and very annoying -- I went into Display in System Preferences, and unclicked the 'detect ambient light' thingie, and then adjusted the brightness on that screen, as using the F10 button on the keyboard wasn't doing a thing - voila, bright display again on my getting ancient PowerBook G4  . . . I think the ambient light thingie went haywire?
Posted on Jul 03, 2009
    President:
  • 2,653 Answers
How long before it goes dim?
Does it start strong, then dims right away?
Posted on Feb 28, 2009
  • 2 more comments
  • RescueTechLA
    RescueTechLA Feb 28, 2009
    That's what I'd thought you say.
    The problem is most likely the inverter and / or the lcd backlight. Most of the time it's just the inverter.
    You'll have to have a local Apple tech fix the problem.
    I don't recommend normal users fixing Apple's themselves, they're too difficult.
  • RescueTechLA
    The part itself isn't it's the service that will kill ya.
    What's your exact model? I can send you a link to a guide so you can see if it's something you're willing to try.
  • RescueTechLA
    Nah, forget about it. I just looked at the process. It's way too complicated for a home user.
  • RescueTechLA
    You might want to try craigslist first, Apple will really sock it to ya!
    Here's a link to the guide just so you can see what I'm talking about.
    It gets to about the half-way mark.
    SERVICE GUIDE
Dim screen on Mac A1013
What os are running. Check in the preference pane under display if auto brightness is enabled if yes doable an increase brightness slider.
Feb 13, 2014 | Apple PowerBook G4 Mac Notebook
Powerbook g4 no brightness have yo use flash light
Okay. Try this
http://support.apple.com/kb/TA25861?viewlocale=en_US
If it does not help then it is possible that the Back light on the screen is faulty. If you just purchased the computer, then you should go back to the vendor and ask him to change or fix it .
Oct 25, 2010 | Apple Power book G4 Refurbished Notebook -...
My apple powerbook display is just showing blank. I had turned the powerbook G4 and when I went to restart it the display would not show anything. I can hear the startup sound but nothing on the screen....
Just remove ur CMOS battery and harddisk connection from motherboard. And then try to restart it will give u a msg no boot device or OS found.. Now reboot and add the CMOS battery and harddisk on motherboard...
Apr 24, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Hi, I have a PowerBook G4 17" laptop and the monitor has gone dim, to where it appears black. I can barely see images on the screen, but the backlight is not working. Could this be a video inverter...
Yes, this does sound like it's an inverter issue.
The only way to get this part is straight from Apple or from a Authorized Service Provider who get there parts straight from Apple.
Feb 17, 2010 | Apple Powerbook G4 15" 1.5GHz SuperDrive...
My screen flickers and goes out sporadically.
Bad video graphics chip on logic board. Probably made by Nvidia. Repair logic board or replace the logic board.
Feb 17, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
When I turn on my 17" power book g4 I hear the drive and chime and see a blip of screen light up from the lower right corner of the screen but goes black right away. I have no software at this time. I...
Do you have this machine plugged into AC power? If not, you may just have a depleted battery, which would fit these symptoms perfectly.
The problem is not software related, because with a missing or empty internal drive you would get a flashing question mark folder icon instead.
Does the machine power off when the screen goes black, or does it continue to run with a dark screen? Common solution for the latter is to wait two minutes until the boot sequence sounds complete, then press the F2 button to raise the screen brightness. Failing that, you may have a blown-out backlight tube in the screen itself, which can be addressed.
Oct 18, 2009 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
Canoot get Mac to boot up all the way
there is a hardware fault or full hdd ...
thi guys will help Micromen - London
Aug 30, 2009 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
My powerbook G4 will not startup... All that appears on the screen when I try to turn on my computer is a tiny folder with a question mark on it. The mouse pad is nonresponsive.
Computer cannot find operating system files. Start up from Install Disk or Utility disk and re-install system. Hold down C key while starting from disk.
Aug 11, 2009 | Apple PowerBook G4 Mac Notebook
Powerbook G4 screen getting dim.
Did you already increase the brightness through the control panel? If not it is software driven and that can increase your brightness.
Jun 07, 2009 | Apple iMac G4 Desktop
Apple iMac G4 Desktop Logo
556 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
