Question about Hoover Washing Machines
Hoover 750lb remove agitator,My wife some sort of chain wrapped around underneath agitator
5 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Necklace caught under the agitator
In the center of the sgitator, there is a bolt.
Sometimes there is a plug to remove by prying out.
Remove this bolt.... or just loosen it, and the necklace will come free.
See item 2 in the expanded view on the left side.
Thank you for using FixYa - A FixYa rating is appreciated!!
Posted on Jan 26, 2009
hattonhall
  • 349 Answers
SOURCE: my Hoover 750LB washing machine smells - not the
No need!
Put 3 cups of sugar Soap concentrate in machine and fill. Leave 24 hrs and run a wash cycle without clothes.
If this fails....only option is complete strip and clean of innards of the machine,
Posted on Oct 25, 2009
blueextc3221
  • 15935 Answers
SOURCE: removing agitator hoover 800EL
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
SOURCE: A pair of my son's
Remove the agitator
Top plastic piece should come off
then a nut to remove
Posted on Jan 29, 2011
How do I remove the agitator? ***** hose wrapped underneath.
The link is for a whirlpool and the agitator is very similar for most of the top loaders. the link is for a repair but in your case you will only remove, clear the trapped garments and re install.
Broken Agitator Whirlpool Imperial Series II
Jan 10, 2016 | Washing Machines
Trim on blanket caught between agitator and drum. How do you remove agitator on this model?
The agitator simply lifts off the shaft. Grab it and pull upward with a little force, and it'll pop free. Under the agitator you'll find a plastic drive coupler that has a single bolt through the top. Remove this bolt and remove the drive coupler. Whatever got wrapped around it you'll find underneath and should easily come out now.
Aug 16, 2013 | GE GTWN5250DWW Top Load Washers
Help my hoover w/machine will not agitate or spin.
ok does that mean u know how to bypass lid switch so u can see the agitator and bowl while it is cycle? normally when the lid is lifted the machine stops.sorry to ask u this question but it will help in fixing your unit.please reply 4 more help.
Apr 15, 2010 | Washing Machines
Tooth floss got wrapped around underneath the agitator. Can't reach it to get it all out.
you would need to remove the agitator,,,pop the cap off the upper agitator and remove the bolt holding it on and just pull up on the agitator,,fairly easy to do
Mar 06, 2010 | Kenmore Washing Machines
My Hoover 750LB washing machine smells - not the lint filter - how do you remover the agitator to see underneath?
No need!
Oct 24, 2009 | Washing Machines
I have a Whirlpool Ultimate Care II washer that had developed a "wrap" sound coming from the agitator. The agitator had a loose fit at the top, and can be moved about a 1/4 inch from side to side. How do I...
Remove the fabric softner cup. Remove cover underneath it by pulling up on it. It just snaps in and has a seal on it. Remove the bolt and lift up the upper agitator. You will need to get an agitator repair kit from an appliance parts store. It has seals for bolt and cap,.thrust washer for the botttom of upper agitator , cam dogs and a new holder and plate. Be sure to take the model number with you.
Jul 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
A sweatshirt cord is wrapped around my HotPoint top load washing machine. The machine is 18 years old. Can I pull off the agitator to retreive the string?
If it's wrapped around up underneath the agitator you can.
Have you tried just figuring out which way it was wrapped?
Keep a can of WD-40 handy.
Jan 29, 2009 | Hotpoint VBXR1090B Top Load Washer
Hoover 800 washing machine
take the cap of the top of the agitator you need a 10mm socket
on along extension bar undo the bolt in the bottom of the agitator and it will lift out replace by do-ing the reverse process
i have just done it better than paying $100.00 for a service call
for five minutes work
Aug 18, 2008 | Hoover HTC243 Top Load Washer
Necklace wrapped around bottom of agitator
1. Pry off protective cap with knife or small screw driver.
2. Remove agitator bolt
3. Lift off agitator
4. Retrieve Necklace
Regards;
reg501
The FixYa team
Jun 23, 2008 | Roper RAS6233KQ Top Load Washer
Washing Machines Logo
158 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
