Question about KitchenAid KEBC107 Electric Single Oven
My KitchenAid Supra self cleaning convection wall oven stopped heating after I had used the self cleaning program. I ordered a new heat sensory unit $80.00 but after I installed it the oven is still not heating up. Do I need to reprogram the oven or anything. Please help me!!!
  • golfhog Mar 21, 2009
    Oven won't heat after using self-cleaning feature
  • winslowcase Apr 05, 2009
    Cleaned the oven for the first time, now it won't heat up. Control panel is fine, no error codes. Fan comes on.
  • KitchenAid Master
  • 3,361 Answers
There is a overload thermostat on the rear of the oven that will have to be replaced.
Self cleaning features are not recommended by most appliance technicians.
Self cleaning causes parts to fail often.
Posted on Feb 28, 2009
Kems308sss05 starts heating to a preset temp, then stalls. Both broil/bake elements get hot, no spots or breaks. When I try to preheat again, the start temp is less than the # it stalled at.
Top 42 Complaints and Reviews about KitchenAid Wall Ovens
www.consumeraffairs.com > Homeowners > Ranges/Ovens/Stoves
Rating: 1.6 - ‎35 votes I missed 2-days of work, once for diagnosis and then another for them to ...KEMS308SSS05 - I purchased this product in Jan 2012. ... Ordered parts, two weeks later parts came and when the heating element was .... I used the self-cleaning unit in top and bottom and noticed in November the temperature took a long time to ...
Nov 08, 2015 | Ovens
After using self cleaning feature...oven door locks up...4th time this has happened...kitchenaid says "no known issues with your unit or the problem you reported...can you halp
Hello - we have had this same issue a number of times as well. Do you lose all power on the unit too? We do - have discovered that using the self-cleaning isn't really a good idea with these ovens. The ovens aren't really made to heat to such high heats that are used in the cleaning cycle and during that last hour of cleaning it hits it highest peak - and it blows it's fuses. We recently blew 2 fuses at the same time, locking both doors (Double oven) and knocking out the power for the entire unit. Our repair man said that the average on wall ovens is anywhere between 6 - 12 cleanings before you will blow the same fuses and the whole cycle starts all over again. Our expense was $350. So, self-cleaning now means elbow grease around this house. How this information was a bit helpful for you.
Jul 02, 2010 | KitchenAid KEBC208 Electric Double Oven
Oven will not heat up on bake broil or convection cook.
I justn encountered the same problem (Model KERS507Y). Haven't checked yet...but am suspecting the Thermal fuse. Have you solved the problem?
Jan 18, 2009 | KitchenAid Architect Series KEMC308KSS...
Kitchenaid superba electric oven kebc107kss05
Did this with me twice now on self clean. It's the thermostat on the back of the oven. Set to trip when oven gets too hot which happens with self clean. Part is about $45 - $50 and pretty simple to install. Hardest part is pulling the oven out of the wall.
Nov 11, 2008 | Ovens
Bosch HBN 642 -- single oven cycles and doesn't get above 325
WHAT WAS HAPPENING AT 1ST YOUR HI-LIMIT TERMAL SAFETY OR OVEN TEMP SENSOR FELT THAT THE OVEN WAS GET TOO HOT AND SEIZING OPERATION UNTIL SAFE TEMP WERE OBTAINED THIS IS GENERALLY A FAULTY OVEN TEMP SENSOR. I WOULD ADVISE YOU TO CONTACT A CERTIFIED TECH TO LOOK AT IT AND P.S. DON'T MENTION THAT YOU TOOK THE MACHINE APART MOST SERVICE COMPANIES WILL NOT SERVICE THE MACHINE IF IT BEEN TAMPER WITH BY THE CUSTOMER DUE TO INSURANCE AND LIABILITIES
May 28, 2008 | Ovens
OVEN will not heat
KitchenAid KEBC107KSS does not heat hot enough and does not heat evenly. When the temperature is dialed higher, it burns the cookies. When the convection fan is on, it has a 'cooling effect' so the temperature never reaches the proper level. Is this problem repairable? Or is this a thermostat issue? Thank you for your help!
Feb 24, 2008 | KitchenAid KEBC107 Electric Single Oven
OVEN will not heat
After reading the above, here is how I fixed my KEBS177DSS9
I pulled out the wall oven from the cabnet. Took off the back tin panel about 10 tin screws. Follow the wire from both heating elements. They are both connected to a thermo fuse. When using the self clean feature this fuse protects the oven from over heating and starting a fire. I put a jumper wire from the hot lead on the left and connected it to the 2 leads on the right side. I turned the power back on and turn the oven on to bake at 350 degrees. Yep It worked like a charm. I bypassed the thermal fuse and used the oven, until the new thermal fuse was ordered. If you have any questions about this fix email me at jodunn5555@aol.com Good luck
Nov 01, 2007 | KitchenAid Architect Series KEBC107KSS...
Oven will not heat at all after an interrumpted cleaning cycle (power went off)
There is a thermo fuse located behind the back panel of the oven. If the oven appears to be working but is not actually heating then this is the cause. The oven will have to be removed from the wall, power to the oven shut off at the main breaker and the back panel removed. the thermo fuse is just to the left and up from the center of the convection fan. It has 2 wires connected to it.
Jan 02, 2007 | KitchenAid KEBC107 Electric Single Oven
KitchenAid KEBC107 Electric Single Oven Logo
1,003 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
