Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
My ' plastic' screen is damaged, can i replace it? i have a 42WT29B
  • slimtaff Feb 28, 2009
    many thanks! wil do.
    Genius:
  • 2,920 Answers
Can go to any used tv shop and have them order a new one or you can order one through the company it comes from
Posted on Feb 28, 2009
How too take part samsung galaxy J3
https://www.youtube.com/watch?v=q7i-3HxyDHQ
https://www.youtube.com/watch?v=E2uuYTwHth8
https://www.youtube.com/watch?v=ifKCjyxWgy4
depending on why you wish to pull it apart ?
If you are replacing the plastic screen you need to heat the plastic to loosen the glue. If you use too much heat or force you can damage the digitiser. this means another part to fix and more cost
if the touch screen is faulty then you don't have to be so careful as the digitiser isgoing to need to be replaced also .
Replacement part may come with double sided tape or sometimes the plastic wedges to lift up the plastic . you may need to get double sided tape to stick down the screen
Jul 23, 2016 | Samsung Galaxy J3 Cell Phone
The plastic screen isn't broken, but when I turn it on, it appears as broken.
if there are no visible marks or cracks on the plastic case itself then it sounds like the LCD screen behind the plastic protective screen is cracked or damaged (especially if its been dropped, or had a lot of pressure put on it e.g. left in a pocket when sitting down, heavy object on it), if its new i would consider taking it back with the receipt for a replacement.
otherwise it will need someone with some repair skills to replace the screen.
Aug 06, 2010 | SanDisk Sansa e250 MP3 Player
Scratches on tv screen.
I have used clear plastic sheets and silicon tire dressing for smaller problems like this, but no idea how well it would work with a large screen TV. The westleys silicon tire shine smooths out the scratches, and you place the clear plastic sheet on top of that and work out any bubbles then tape the ends. It pretty much changes a standard screen into a glossy screen with the added benefit that you can always replace the sheet if it is damaged.
I usually get my clear plastic sheets packaged with the new LCD screens I purchase for repairs and I just keep them in storage.
Mar 12, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Screen has been pushed in 42wt29b
If the protection screen is broken, Just take it out and replace it with a sheet of plexiglass. If the freznel lens is damaged I believe you will have a hard time finding a replacement. Good luck.
Mar 09, 2010 | Toshiba Televison & Video
Damaged plastic screen cover of my flat panel LCD. Anybody have any fixes? T.V. works great but blemishes on plastic can be seen. I'm wondering if a new screen cover can even be bought. Sceptre X37sv-Naga...
most lcd/led tv,s the front panel is the display you can try polishing the screen with very fine abrasive like jewelers rouge or your local car dealer sell plastic polish to remove scratches from plastic headlamp lenses if not its a new display a new tv is poss a better option. i have used silver polish to rejuvinate car headlamp lenses to good effect
Dec 13, 2017 | Sceptre X37sv-Naga 37 in. LCD Television
The diamond shield has been damaged and looking for a replacement
you can get a cheap replacement protective screen at a local plastics company. you will have to cut it yourself with a cut-off wheel and dremel. or you can have them cut it for you. the original protective screen is to expensive to worry about at this age of the set. check the yellow pages for a local supplier for plexiglas/clear plastics 1/8" or 3/32" clear its cheap!!! and all you need is a phillips head screwdriver to replace it.after you remove the speaker grill there are 4 screws on the bottom of the screen frame. then you lift the frame straight up and it comes out. inside there are brackets holding the screen in place. be very careful not to damage the screen.
Jan 07, 2010 | Mitsubishi WS-65819 TV
Cracked case
Hi there.
You can order spare parts from Acer themselves or alternatively look on Ebay for spare plastics.
It sounds like you need the lid face and bezel (plastic that surrounds the screen), as for disassembley i'm afraid its trial and error as you may have to take the laptop apart to replace the plastics.
Good luck and thanks for using FixYa!!
Mar 04, 2009 | Acer Aspire 3680 Notebook
I have a Toshiba Satellite series laptop that was dropped and the screen was damaged. I've gotten a replacement but I don't want to mess anything up by changing it myself. Anyone have suggestions? I've...
you'll need to pry the screen gently forward(away from the plastic casing)...along the side s of the screen will be the hinge brackets.....4 screws (2 either side) hold the screen in place...undo these screws and the screen will be free....the only thing connecting screen to computer will be the video ribbon cable which connects to the back of the screen via a plastic pressure clip...release the clip and your done.....remember to be very careful when installing the new screen as its easy to overtighten the screws and damage the screen
Jan 07, 2009 | Toshiba (225EXTR5)
LCD screen
It's a plastic overlay cover which can be replaced. It's held in place by double sided tape. Fuji can do it for you, or you can see if someone can order the part for you. Fuji Canada has a policy to not sell parts to consumers to install, because there's been lots of problems with people trying to install the part and damaging the camera even further. Now the consumer blames Fuji for a bad part, and for the subsequent damage to their camera. Better to let Fuji (or a qualified shop) handle it for you.
Sep 28, 2008 | Fuji FinePix S7000 Digital Camera
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
87 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
