Question about KDS 17S 17" Monitor
No power My daughter was touching the power cord as I was on the PC and then the LCD screen went blank then dim and then I touched the power cord to adjust and unplugged it then plugged back in. Now no power at all. Is there a fuse I can change on this LCD? I would hate to have to buy another right now. Help please... jessica
    Brigadier General:
  • 5,158 Answers
Leave it unplugged for a few minutes and plug it back in making sure it is firmly plugged into the monitor and the wall socket
Posted on Feb 27, 2009
  • 54 Answers
Check your power cord very carefully....especially the plug ins (square box)....could be the power supply itself. Regarding fuses; You can't see it inside the computer it is an electronic component. Got to go to store
Dell xps touch sreen just blinking blue light but blank screen
Sounds like it went to sleep due to low battery power. May be time for a new battery if it isn't holding charge well.
Plug it into the wall and push the power button once. It may come back on. If not...
Hold the power button down until the machine shuts off completely. If that doesn't work, remove the battery.
Feb 04, 2015 | Dell Computers & Internet
Tip
Diagnosing a LCD blank screen problem.
Recently a 3 year old VIzio TV I bought started having problems. The set would turn on normally for a few seconds then the picture would go dark with everything else operating normally including sound. Remembering a similar laptop computer problem I diagnosed previously, I immediately suspected a defective TV screen backlight. To verify this in your own TV, get a very bright flashlight and with the TV operating in the failed blank screen mode, shine the flash light into the blank screen from various angles and distance (including touching the screen). If the LCD is still operating, you'll see a dim motion in the flashlight's reflection, thus proving it is indeed a failed backlight.
on Jan 27, 2015 | Televison & Video
Screen goes blank in aux mode
Check parking brake connection. Not connected properly.
Apr 22, 2014 | Pyle PLD40MU 4.3 LCD Touch Screen Car...
Touch screen doesn t work
The touch screen connects to a control board. Regardless of what the diagnostics indicate, the control board may be defective.
Jan 16, 2014 | GE Dryers
The touch screen display does not work. It turns on but you cannot give the unit a command through the input panel.
Is the lcd screen completely blank? Or does is it just the touch functionality that is not working?
If the screen is blank, though the copier still turns on and appears to function (test it by printing to it,) then you most likely have a failed power inverter board. This board provides the current needed to operate the lcd screen and is a rather common failure. However, if it is just the touch feature that is not working though the screen lights up, then you most likely have a ripped ribbon cable that connects the lcd touch function to the main board on the lcd screen.
Keep my updated.
David R.
Dec 11, 2010 | Xerox WorkCentre M-24 Color Copier
Touch screen is blank
I am not sure which DS your daughter has. There is the DS original, lite, etc.
You can try recalibrating the touch screen, to do this follow these instructions:
http://www.nintendo.com/consumer/systems/dslite/en_la/recalibrate.jsp
If this does not help, you may need to send your DS in for service. The problem may be something with the hardware where only professionals should be performing maintenance on.
Give a call to Nintendo's 1-800-255-3700 (6 am - 7 pm Pacific, everyday) Customer Service number, or use their web form ( http://www.nintendo.com/corp/contact.jsp ) to contact them, and they can set up the repair process for you.
- Neal
Apr 27, 2009 | Nintendo DS Lite Console
Cannon NP 6551 (Danka A50) Touch Screen Lost Brightness
SOMEONE TURNED THE CONTRAST BUTTON ON YOUR DISPLAY, YOU JUST NEED TO READJUST BY PRESSING AND TURNING TO DESIRED CONTRAST
Apr 03, 2009 | Canon NP 6551 Black and White Copier
AL2216W LCD monitor "Power status Green blinking" & No display.
LOOKS LIKE A BURN SOLDER !! , open the monitor , check the PC BOARD around the transformer area , look for burn spot or cold solder , RE solder it , try again , hope this helps please rate solution and thanks AJ
May 06, 2008 | Acer AL2216W LCD Monitor
KDS 17S 17" Monitor Logo
93 people viewed this question
Top KDS Computers & Internet Experts
RobertFonner
RobertFonner
ray
Level 1 Expert
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
