Question about Canon CanoScan LiDE 30 Flatbed Scanner
Re: CanoScan LIDE 30 on Mac OS X (Version 10.5.6)
I downloaded the Scanner Driver & CanoScan Toolbox following Cadwell's instructions. When I tried to install the CanoScan Toolbox, I got the following message: 1008;5, - 5000 Access denied error.
Any suggestions would be appreciated.
Thank you.
H.B.
  • hmbhmbh Mar 04, 2009
    I didn't rate the solution because I found it on another site!
    I e-mailed Canon to get advice about my second problem (i.e. I'm not able to install the scanner driver. According to Canon, this scanner driver is not compatible with my mac (10.5.6).
  • Anonymous Apr 20, 2009
    So my scanner I've had for several years now -- and which worked fine on previous Mac OS X versions -- won't work because I got an OS update?  Canon truly sucks...
I was able to install the CanoScan Toolbox by doing the following: MacIntosh HD --> Library --> CFMSupport --> Get Info. Under 'Sharing & Permissions', I added my name & changed 'Read only' to 'Read & Write' .
Problem now: I can't install the LIDE 30 Scanner Driver. I clicked on the downloaded driver & a box opened. I clicked on ScanGear CS Installer, but that didn't work. I then clicked on 'Into Plug-In' --> ScanGear CS 7.0X --> Choose Application --> CanoScan Toolbox 4.1 --> Plug-Ins, but couldn't continue as the 'Open' tab was greyed out. What should I try? Any suggestions would be appreciated.
Posted on Feb 28, 2009
Lide 60 not working in mountain lion
Guide to installing Canon CanoScan LiDE 35, 50 and 60 on Mac OS X 10.8. Mountain Lion:
FIRST PART: DELETING OLD LiDE DRIVERS AND SOFTWARE
  • If this is the first attempt to install the scanner, skip this part
  • Trash the following files/folders from these folders:
HD:/Library/Image Capture/Twain Data Sources
delete the CanoScan CanoScan XXXX.ds file
(Make note of any other files that may be in this folder. If other files are present, move them to the desktop for now. Then place them back after successfully using the scanner.)
HD:/Library/Preferences
delete the 'CanoScan XXXX' folder
HD:/Users/Shared
delete the folders containing the name CanoScan, or starting with CNQL.
HD:/Applications
delete the CanoScan Toolbox Application
HD:/Users/YOUR-MAC-USERNAME/Library/Preferences
delete any items named "CanoScan Toolbox"
  • Restart your computer, then empty the trash
SECOND PART: MAKING YOUR SCANNER WORK
  • Make sure your scanner is well connected
  • Download the right driver depending on your Model. Also download the Scanner Software. Copy the filenames and search them via Google. Make sure you download the Canon files from an official Canon domain.
CanoScan LiDE 50 and LiDE 35 work both with the 35 driver:
lide35osx7721en.dmg
CanoScan LiDE 60 driver:
lide60osx11131en.dmg
VueScan Software:
http://www.hamrick.com/#download
VueScan 9.2 (or later) x32 for Mac OS X
Alternative to VueScan: CanoScan Toolbox. I prefer VueScan.
Try your luck with Version 4 or Version 5.
CanoScan Toolbox 4: cstbosx4934ej4.dmg
CanoScan Toolbox 5: cstbosx5014ej4.dmg
  • Open the downloaded driver file (lide35osx7721en.dmg or lide60osx11131en.dmg)
  • and Double-click the ScanGear file, install and restart when prompted
  • Open the downloaded VueScan file (vuex3292.dmg) and drag the VueScan application to the Mac Applications folder
  • Open the VueScan application. The scanner should be recognized automatically.
(Alternatively try and install CanoScan Toolbox 4 or 5)
Nov 04, 2012 | Canon Office Equipment & Supplies
I have canoscanlide 30 i canot install the toolbox to my pc windown vista whay can i do
two possibilities...
1. the toolbox software may need to be installed as administrator and in compatibility mode
2. it may not be installable if your pc is a 64 bit pc and your toolbox software is 32 bit... this is a common issue...
Dec 23, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
I've lost my CD for CanoScan LiDE 60. I
Goto Canon website
Use the following link
http://www.canon.com.au/products/scanners/scanners_low_medium_volume/canoscanlide60.aspx
Find the Downloads for your scanner.
Download the driver (if you don't have it)
Download the ToolBox for Win OR Mac as the case may be)
This Toolbox contains the software which was packaged with the Scanner.
Hope this will work for you.
Cheers
lucian44
Sep 02, 2009 | Canon CanoScan LiDE 600F Flatbed Scanner
Canoscan Lide 30 - want to use on laptop running XP Pro
Did you restart your computer after you downloaded your drivers and software? Did you select the correct operating system? Make sure the USB cable is plugged into the computer and the scanner...Open the toolbox and click scan or save and check to see if the scanner makes any noise or lights up...If you are using Windows XP then make sure you have downloaded the "TWAIN" driver and the "WIA" driver (two seperate downloads)
Jun 30, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
Canoscan Lide 20/lide30 Ver. 1.02 Will not load in my Mac 10.4.11 Tiger.Had it in my previous vergin mac 10.2 but since I've upgraded scanner tells me I've got error .06 and will not reload. I assume I...
http://www.usa.canon.com/consumer/controller;topic=609.msg7369?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=104&modelid=6624#DownloadDetailAct
Mac OS X (Native Mode)
  1. Turn the computer on. Log in as the first created administrator account to install the software. You cannot install the software when logged in using added administrator accounts.
  2. Place the CanoScan Setup Utility CD-ROM in the drive.
  3. Double-click the CD-ROM icon.
  4. Double-click the MacOS X folder/icon.
  5. Note: Some versions of the CanoScan Setup CD-ROM will not include the Mac OS X version of Toolbox. If this is the case, you should download and install Toolbox from Canon's website. www.canontechsupport.com
    If you will not be installing Toolbox at this time, skip to step 7.
    Double-click the CanoScan Toolbox folder/icon.
  6. Double-click the CanoScan Toolbox Installer icon. Follow the on-screen prompts to complete the installation.
  7. Once the installation of Toolbox is complete, you should then access the ScanGear CS folder also located in the MacOS X folder.
  8. From the ScanGear CS folder, click the ScanGear CS Installer icon. The installer will search for available install locations for the scanner plug-in driver. Follow the on-screen message prompts to complete the installation.
Jun 18, 2009 | Computers & Internet
Installing CanoScan Lide 20 / Lide 30 into Mac OS X 10.5.5
I found this scanner at a garage sale today, and had trouble finding this info myself. Finally stumbled upon this site ( http://cadwell.livejournal.com/39545.html )
I'm using it on a Powermac G5 but both the driver and toolbox app say they are univeral binary. Hopefully this gets you up and running too:
CanoScan LiDE 30 on Mac OS X 10.5
This technical help may seem completely out of place on this art blog but after scouring the internet for 3 hours trying to set my 6 year old scanner up on my new MacBook, I found this info half way down a lengthy comments section of a random blog. So I thought I'd post it here (slightly altered) as a message in a bottle to anyone else in need of it.
How to set up CanoScan LiDE 30 on Mac OSX 10.5
STEP 1:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6623
STEP 2:
Select MAC OS X
STEP 3:
Download BOTH:
LiDE 20/LiDE 30 Scanner Driver Ver. 7.0.1.1aX
(Mac OS X)
lide20lide30n670un676un1240uosx7011aen.dmg
CanoScan Toolbox Ver. 4.1.3.0X
(Mac OS X)
CSTb4130MXE.dmg.gz
STEP 4:
INSTALL CanoScan Toolbox Ver. 4.1.3.0X
STEP 5:
INSTALL LiDE 30 Scanner Driver Ver. 7.0.1.1aX . Make sure Applications>CanoScan Toolbox 4.1>Plug-Ins is selected as the install location.
STEP 6:
You will be asked to RESTART. You should.
STEP 7:
When you run CanoScan you can choose Photoshop as the default program to open the image in once it has scanned. You do not need Photoshop to open using Rosetta for this to work.
NOTE: If you want to scan directly from within Photoshop CS3, you need to copy the driver 'ScanGear CS 7.0X' which is found in Applications>CanoScan Toolbox 4.1>Plug-Ins into the photoshop pluggins folder, Applications> Adobe Photoshop CS3>Plug-Ins>Import/Export. You also need to open photoshop in Rosetta mode. Apple + I on the photoshop icon and select 'Open using Rosetta'. I would not recommend using this method though.
STEP 8:
Go to System Preferences>Accounts>Login Items and remove both of the following:
N067U_ButtonManager.app
N124U_ButtonManager.app
STEP 9:
SCAN.
Feb 15, 2009 | Canon CanoScan LiDE 50 Refurbished Scanner
the solution is here:
(at least it worked for me, OS X 10.5.5 / LiDE 20)
Aug 30, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
TWAIN ERROR AND CANOSCAN LIDE 20 SCANNER PROBLEMS
Select your operating system and download the driver "TWAIN Driver - LiDE 20 Scanner Driver Ver. 7.0.3.1a_xp" and then download the software "Canoscan toolbox" ...here is the link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6624
Aug 04, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
Canoscan Setup Utility CD-ROM missing
You can find drivers here. Select your OS in the box, then download the standard driver (not the WIA driver). Also download the CanoScan Toolbox listed under Software. Install both to your computer following the instructions.
Jun 18, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Problem have lost the installation cd for my canoscan lide 25 flatbed
Drivers and manuals are available here. Wait a few seconds for all files to load, then select your OS in the box. After a few more seconds, the drivers and software for your OS will be listed.
Download both the driver and the CanoScan Toolbox. Follow the instructions to download and install.
May 20, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Canon CanoScan LiDE 30 Flatbed Scanner Logo
869 people viewed this question
old marine
old marine
