Question about Interactive Health Ht 135 Massage Chair
Human touch HTT 800 just beeping from back, not remote
Older model, just beeps from electrical console in back when plugged in. Please help!!
Just had this problem with our HTT 800. Discovered it was the curled phone-like cord attached to the remote that had been chewed through by one of our dogs. Some electric tape fixed it right up. Still looking for a replacement. Anyone know where I can find one? A standard-size phone cord does not work with this, as it is too large.
Posted on Nov 28, 2009
Had the same beeping problem as you. Tried a new remote control "phone cord", but the beeping continued. The cord that fits it is a standard "handset" phone cord. That cord has the slimmer end connectors and will fit this chair. The "wall plug" phone cord is much wider and will not fit. You are correct there.
I found the problem to be in the phone jack on the remote- where the phone cord plugs into. There, the pins had bent back quite a
ways, that it was not making good contact with the phone cord.
The fix: unplug the phone cord from the remote control. Look inside
the phone jack and use a "pick" or a bent paper clip in a
hook-shape to reach in and gently pull the gold pin
contacts back out a bit. Replug your phone cord and
enjoy your "beep-free" massage again !
Posted on Jul 17, 2010
Drying and Lid Locked lights flash red and it beeps continuously. Dryer will not start.
look on coolblueworld.com or paperwork for error code is in back consol . please unplug dryer if you remove consol.
Mar 21, 2015 | Fisher and Paykel SMARTLOAD DE62TG1...
Brought a second hand ps3 slim 160gb.when everything is on tv says no signal i hold button down but no beeps light goes from green to red anybody help please
Try this Make sure no game in ps3 turn ps3 off and by the switch at the back unplug it wait a couple of sec then plug it back in turn on buy the switch at the back then hold down power and eject hear a beep keep both preseec till 2nd beep let go should be able set it to ya tv
Dec 28, 2013 | Sony Playstation 3 (PS3) Console
We have a Maytag CWE 1000 electric wall oven. It will not turn off, you hit Cancel on control panel and nothing happens. It also will start flashing other items like Broil or Conv. and beeping. If you...
As oppesed to the control itself i believe the touchpad is the colprut it plugs into the control and its a lot less expensive. The model number listed on your question,please replay with full exact model off the label which on that wall oven is either on a label by the door hinges or on the bottom or the control console between it the console and top edge of door. reply with that and i will give you the part number for that touchpad.
Gene
Aug 20, 2011 | Maytag CWE4800A Electric Single Oven
Cannot set up ps3 on older big screen tv - no hdml - when using colored input wires - cannot find on tv using input - WII is on video 2 tried using the same plug ins - did not work - any ideas
You need to reset the video resolution back to standard by doing the following :-
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later. Release the power button when you hear this second beep.
The display will now reset back to standard definition.
Hope this helps
Oct 25, 2010 | Sony Playstation 3 (PS3) Console
My ps3 is not working because when i plug in all the leads the picture or sound does not work so i bought a new cable but it still does not work I think it may be because i plugged it in to a hd tv then...
Ok, please follow these steps :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep once when you first press it then beep again 5 seconds later, let go of the power button when you hear this second beep
Step 3. Wait for the PS3 to restart
This basically resets the video output back to standard definition where you should now be able to set it up properly.
Hope this helps
Sep 26, 2010 | Sony Playstation 3 (PS3) Console
After a weekend at a freinds house using his smart flatscreen tv and using a hdmi lead when i plug it back into my tv using a scart lead nothing appears on the screen please help
Ok, you need to hold the power button down for 5 seconds until it beeps once, this will revert back to standard definition.
Hope this helps
Aug 07, 2010 | Sony PlayStation® 3 (80GB) Console
When i turn on my ps3 its the older model not slim it beeps and turns itself off i cant even get my game out of it
Hello, You Will Need to Remove the Power Cord of your Ps3 and then Press the Power Button till u hear 3 Beeps then u need to do it again but this time u need to let go when u hear the 3rd beep and you Restore the Whole Ps3 System
Mar 28, 2010 | Sony Playstation 3 (PS3) Console
Model 84152 beeps and won't start
probably the thermistor is bad. located on the blower housing in front of the motor nest to the thermostat. if you tilt the console back(remove the screws at either side, either visible or under snap off console ends) there is a tech sheet wiring diagram to trouble shoot the circut. unplug it first...
May 24, 2009 | Kenmore 84152 Electric Dryer
I just got a used stove and its a single magic chef eletric stove. when I plug it up it will beep and on the display screen it says L1. what does that mean. im not sure what model it is though. its a older...
Usually L1 is a code for power on. So try to clear it by pushing enter or clear and see if it helps.
Please rate me accordingly if this helps and good luck.
Mar 13, 2009 | Magic Chef 9512 Electric Single Oven
Elements wont turn off
i unplugged stove plugged it back up now its got beeping sound not like the alarm my model numberb is13351737wy
May 06, 2008 | Crosley CE35100AA Electric Kitchen Range
Interactive Health Ht 135 Massage Chair Logo
2,116 people viewed this question
Top Interactive Health Furniture Experts
Jason Morris
Tom Chichester
Are you an Interactive Health Furniture Expert? Answer questions, earn points and help others
