Question about Avital Vehicle Parts & Accessories
Why does the car start by itself after I installed the remote starter?
  • tdang3105 Feb 28, 2009
    The car will start immediately after the button is pressed, but sometimes no body will be around the remote and we will walk outside to find the vehicle has been running, when nobody pressed the button.
  • james kappers
    james kappers May 11, 2010
    how long does it take for the car to start by itself. Is it after a couple of hours, right away?
  • 95 Answers
I could be to things, if the remote start has a remote timer, that you can program the remote start to start every hour for like 5 minutes, or there is an activation wire on the remote start that is getting grouned somehow and allowing the car to start. What i would do is look in your manual and see how to bring the remote start back to all its original factory settings, and make sure all loose wires are taped up and not touching anything. If you need help on manuals or anything let me know and i can walk you through it.
Posted on Feb 28, 2009
By remote starer (5103) just start for 30 t0 second then shut off ?
please help me Thank you.
Posted on Jan 08, 2014
2 Suggested Answers
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
MECP Guy
  • 344 Answers
SOURCE: my remote car starter starts my car without
You probibly have it set for cold weather start or something
Posted on Sep 29, 2009
Remote start chevy
Clean all the battery contact points on the remote starter, then re-install your battery. If that doesn't fix the problem, try a fresh battery.
Make sure you remove the little piece of contact paper on the battery itself before installing it. Hope that helps.
Nov 23, 2016 | Chevrolet Cars & Trucks
Remote will only start when i am close to vehicle
It depends on many things - mostly the range of the system itself and especially where you located the remote antenna. Some installers don't use the antenna and that will limit range severely. Most manufacturers want the antenna routed up the windshield pillar and mounted near the top of the windshield glass. This gives best reception since glass does not hinder the RF signal. OF course, a weak battery in the remote can cause range issues as well.
Nov 25, 2015 | Car APS921 Remote Starter - Keyless Entry
Wiring diagram for ce 0890 remote start
On some remote starters, there is print on the back of the remote starter itself. It is hard to see with it being black raised text on a black box. If not there, sorry DEI Viper is pretty protective on their installation manuals.
Nov 28, 2014 | Remote Start System
My 2004 honda pilot with a remote starter installed by best buy starts by itself. Is there a fuse I can pull to kill the remote starter?
Take back and have them fix right or refund money,stay away from places like that,go to a stereo installer that is not a big brand name,best buy uses young unexperience help.
Aug 18, 2013 | Cars & Trucks
Avital 473L TX will start and keep the starter engaged
Sounds like the ignition or accessory output from the remote starter is connected to the starter wire. Has it always done this?
Mar 06, 2013 | Avital Vehicle Parts & Accessories
Last Year I installed an AVITAL5103 Remote start & Security on My 2002 DODGE RAM 1500 Q.Cab.Everything was working fine,util I instal a new car battery.When I attempt to remote stert ,the starter cra
There are two types of starters for Dodge, if you installed new battery, check to see if the remote start is to ignition module or starter solenoid, then make sure the circuit has not been closed-they go in series circuit!
Nov 29, 2011 | 5103L Security/Remote Start System
I have a 2 in 1 prostart remote car starter. It was installed a few days ago on my standard honda civic. Sometimes it works fine, but most often when i try to start it with the starter the lights will...
Dear,
Check if the remote Battery is genuine (I mean full) other wise maybe it's a relay issue or timer issue in the module itself (which you installed).
Regards, Eng. Ghassan Alasmar
Jan 03, 2011 | Honda Civic Cars & Trucks
After install every thing but the starter itself won't start no matter what i do. can anyone help me ? or if you know how to reprogram the remote please show me...
did you follow the procedure for programming the remote starter portion of the unit yet?? We get 20-30 calls a day because people do NOT program the starter to start a certain way. It is specified in the INSTALLATION manual that the unit needs to be programmed before using the remote starter.
Jan 03, 2011 | C3RS915 SST Remote Car Start Vehicle...
Car is NOT starting. Lights are not "flashing" when I hit the yellow start button. It will LOCK and UNLOCK using the remote, but it's not STARTING the 2008 Honda CRV. Do I need a new battery in the...
is the car starting using the key? (manually), if so, then replace the remote battery, if problem still persists, then check the remote & the car's receiver...
or
the car's battery or some controller might be out-of-service!
new cars are electronically controlled, if any problem occurs, it jams the whole car,  perhaps this might be your case.. For your Safety: it is recommended to ask help from Honda Service Centre!!
Apr 24, 2009 | Viper Security and Remote Start System...
Car starter not working
look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the system..you may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is up..to keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
Dec 16, 2008 | DEI Valet Keyless Entry System
Vehicle Parts & Accessories Logo
1,120 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
baire
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
