Question about Ovens
Leftfront burner on my frigidaire oven will not
Leftfront burner on my frigidaire electric oven will not get hot
    Sergeant:
    Champion:
  • 338 Answers
I would replace the burner..
Posted on Feb 28, 2009
My burners nore my oven get red hot anymore, they still heat but take along time to. the oven is a yr and a half old what could be the problem?
Sorry to read about your problem, I hope this helps you out.
check to see if you still have 220 volts coming to the oven
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 21, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven won't get hot
If your oven still uses a pilot light, it also probably has a thermocouple positioned in the pilot's flame path to detect whether if is safe to turn on the main burner. When the thermocouple fails, the oven thinks the pilot light is not lit and will not let gas flow to the primary burners. The part isn't costly (should be <$20 US) but replacing it may require some expensive labor.
Feb 11, 2010 | Frigidaire 30 in. Electric Gallery Series...
My oven wont heat up at all. gets no gas. the top
your glow coil is wron out , need to replace it, you may see it glowing in there but it isnt getting hot enough, usually you can switch out the broil one for a quick fix to get you outta truoble. easy do it yourself problem
Feb 05, 2010 | Frigidaire FEB27S5A Electric Single Oven
My four burner electric stove top is not heating properly. When I put it on simmer it goes way too hot on all the burners? The switch? The thermastat?
need model # not a common problem when all will do that, if only one bad burner switch but when all do that could be shorted wiring
Oct 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
MY OVEN DOES NOT GET HOT, THE BROILER WORKS AND
If we are talking about an electric oven. The oven coil is probably bad. Easy to test remove it and check for continuity. If it shows open cicuit them the coil is burned out.
Oct 04, 2009 | Frigidaire Ovens
Left front burner will not shut off
Get the Model number of the data plate on the oven so I can help
Jul 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
The right front burner won't heat
The switch probably failed. Remove power. Take off the top rear cover and inspect the switch for signs of discoloration (burned or brown areas). If looks OK then maybe the element failed.
May 28, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
