Question about Kenmore Elite HE4 Electric Dryer
How do I install the element?
Last week my dryer quit. I called and scheduled a service man and one week later he came. He replace a fuse and I am waiting for 2 weeks for a for a new element to come. And probably another week for the service man to come back. That's 4 weeks without a dryer. I had my old element coil welded back together and would like to try it. Can you show me the proper way to install the element into the dryer?
Thanks
  • 57 Answers
You dont want to reuse the old element because it could cause more damage to the dryer if and when it shorts out
Posted on Mar 05, 2009
MY DRYER QUIT HEATING AND THE TIMER WOULD NOT CUTOFF THE LAST FEW MINUTES AT THE SAME TIME. REPLACED THE ELEMENT AND THERMOSTATS AND FUSE. ELEMENT HAD OBVIOUS BREAK IN COIL. REPLACED THE TIMER AND THE
Have you reached into the back the dryer's vent port? Most will just replace the hose but fail to clean out the dryer's internal vent tube from the internal blower.
Re-check the fuse, a clogged internal vent tube will blow the fuse again.
Mar 31, 2014 | Kenmore Dryers
Dryer overheating on timed dry/no heat settings
Replace the thermostat. A very inexpensive thermocouple that is not sensing the heat anymore and caused the element to overheat. In the UK the part will cost less than five pounds!
If the element had touched the ground, your safety earth leakage breaker in the fuse box would have tripped.
Mar 20, 2014 | Frigidaire Electric Dryer
Maytag neptune dryer doesnt heat
On the housing the element mounts in is a couple of safetys The smaller one is rated for 300f and the bigger one is rated for 250f. If the smaller one is tripped obviously you replace them both, making sure the vent to outside is clear. Them fuses blow or trip because of air restrictions.
Aug 04, 2012 | Maytag Dryers
I installed a new thermostat on a whirlpool cabrio dryer (wed6600vw0) last week..part went out again because I forgot to clean out the vent...cleaned vent out replaced part...now it is blowing a fuse on...
You have a short somewhere. As long as it was put back together properly it is most likely a bad element that is touching the heater box. Check for a short there by testing each terminal of the element to ground.
Sep 02, 2011 | Dryers
No heat
IF YOUR DRYER RUNS, BUT NO HEAT, THEN IT MAY BE JUST A FUSE PROBLEM
IN THE ELECTRICAL SERVICE BOX. CHECK THE DRYER FUSE'S AND SEE IF ONE IS FAULTY OR BLOWN. REPLACE IT IF ITS BAD AND TRY THE DRYER AGAIN. IF IT HEATS YOU ARE
ON YOUR WAY. IF THERE IS NO FUSE PROBLEM, THEN YOU MAY HAVE A HEATING ELEMENT OUT AND THIS WILL NEED TO BE REPLACED. A SERVICE CALL BY AN
APPLIANCE REPAIR MAN WILL BE NEEDED TO FIX THIS PROBLEM.
Feb 21, 2011 | Maytag Neptune MDE7500AY Electric Dryer
Hello my dryer is only 3 years old. Last night it stopped drying. The drum will turn and the light comes on. It is an electric dryer. What might be the problem. Thanks.
Have you tried a different cycle? The thermostat that controls heat has failed. There are more than one for the different heat settings. Try a different setting, then go from there.
Jul 01, 2009 | Dryers
No heat
Hello Friend, Your problem is very simple to fix. You need a thermal fuse and or heater element, both very simple and affordable to replace. Try replacing the thermal fuse first to see if that's the problem. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. If this don't solve your problem you will need to replace the heater element. To replace the heater element, with the back cover off of your dryer just look down and to the right of were the air blows out. You will see the electric heating unit with two fat red wires plugged into it. Unplug these wires and you will see on the sheetmetal housing two screws that hold it on, one on each side. On older elctric dryers there is only one screw that holds element in place, it is on the bottom center of element screwed in from behind. Remove screw(s) and remove old heater element. Now, lay the new element next to the old one and take notice that there is a heat sensor attached to the old element where one of the red wires unplugged from. Gently remove this sensor and install it onto the new element in the same location as the old one. If you have an older electric dryer, the old heater element doesn't have the heat sensor on it, just skip this step. Now, plug in your two red wires and re-install your heater element. Your dryer will run like new. Happy to help, Tim.
Apr 21, 2009 | Kenmore 62802 Electric Dryer
Squeaking sound on new samsung dv448aew dryer
first off you need to put your foot down and tell them to replace the belt or the adjuster .dont let them leave until they have satifyed you
Mar 24, 2009 | Samsung DV448AEE Electric Dryer
3 1/2 year old Whirlpool Duet Dryer stopped heating up
it could be several things but the element could should be the last part i would check first if you are still using fuses change them both if that doesnt work call for service call a good service man stay away from major companies they are expensive i know i worked for most of them
Nov 22, 2007 | Whirlpool GEW9250 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
101 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
