Question about Sony RDR-VX555
Unable to change the DVD 1 Command Mode back to DVD 3 (DEFAULT) SETTING
While changing Command Mode settings in the Options section, I Made the misstake of switching to DVD 1 from the default setting of DVD 3. Now the only funtions on the remote that work are the channel up & down and the volume buttons. I tried to reset the recorder by holding the on/off key down dor 10 sec. until the display stated Sony DVD, this didn't reset the machine, Note: every time I press the system menu button, DVD 1 is visible in the display and nothing else happens. How do I get DVD 3 back as the default in the Command Mode?
  • 2 more comments
  • Anonymous Mar 31, 2008
    i did the same thing ecept i went from dvd3 to dvd2 now the remote wil not work
  • Anonymous Apr 09, 2009
    sony
  • Anonymous Mar 12, 2014
    I went to change the time and dvd wouldn't get off HELLO. Tried all the resets to no avail.
  • Anonymous Mar 16, 2014
    Reset recommended by tech doesn't work
    Tried holding blue and yellow buttons while pressing power button. nothing happens
Had the same problem when I changed the factory settings by mistake. There is no "cancel" button in the remote or the set. What worked for me was to follow the directions on P. 22 of the manual and change the remote settings to DVD 1. This is done by holding the "Enter" button and pressing number 1 on the keypad simultaneously for more than 5 seconds. Then, you go back to the "Settings" screen with the "Settings" button, change the control back to DVD 3, and reverse the setting in the remote by pressing "Enter" and the number 3 this time. Remember to hold them down more than 5 seconds. Good luck!
Posted on Sep 04, 2007
These didn't work for me... what did work was:
On the REMOTE: Hold "ENTER" and "2" (Because I had got stuck in DVD 2) until the display on the machine changed...
Then let go of the buttons and hit the "SYSTEM MENU" button...
AND ALL YOUR TROUBLES WILL BE OVER...
(PS:  if you got stuck in DVD 1 (like the guy above) I imagine you hold 'ENTER' and "1")
Posted on Jan 18, 2008
Solution 5 worked for me except that after going to the System Menu I pressed ~ Setup~Options and changed the Command Mode back to Mode 3. This locked the remote from exiting, but turning off the power and restarting restored the ability to show the System Menu. I then used the System Menu to Restore factory settings and all functions returned to normal in Command Mode 3.
Posted on Mar 22, 2008
    Problem Solver:
  • 3 Answers
Problem was the same with me. Changed batteries and lost communication with DVD/VCR player. When I hit any button the play showed DVD 1. The solution for me was press and hold enter and 1 key simultaneously, then I pressed menu system. I reset the date, then exit, then the remote worked as before. Thanks for the post - amazing Internet.
Posted on Aug 25, 2010
I found the easiest way of all.
Look at your remote......at the bottom of the remote on the front side their is a panel that slides down.
Just push it in and slide it down.
There is a button that slides between DVD 1 2 3 .
Slide the switch to the one your stuck on and BAAM.
You're back in business.
Posted on Sep 21, 2008
You have to hold the number that coincides with the mode it is currently in down: DVD1= 1 DVD2= 2 DVD3= 3; but most of us are caught in DVD1-no mans land.
Hold down 1 and enter at the same time for 5 seconds (I couldn't get the System menu to pop up) so after the 5 seconds I pressed the power button and it worked. Everything is back to normal now.
Posted on Aug 30, 2008
By removing the batteries in the remote, I was able to reset.
Posted on Mar 11, 2008
Holding the enter button and the 1 until it changed then holding the enter button and the 3 until it changed worked for me, now the remote works again.
Posted on Oct 02, 2007
Try pressing the cancel button and holding it down for 5 seconds (this resets the factory settings)
Posted on Aug 26, 2007
COMMAND MODE SETTING HAS BEN CHANGED FROM DVD3 TO
press enter and 1 or enter and 3 hold for 5 sec should match whatever unit set to
Oct 02, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Dvd recorder
The following should give you access to a service menu containing controls for macro-vision and region coding. You can change the regional settings from there.
1. Set your player to Standby
2. Press Title, Clear and Power
Jul 05, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Sony dvd recorder rdr-gxd310
Click here to get the user guide and go to page # 21.
May 23, 2008 | Televison & Video
Locked out of the menue ,Need to reset command mode
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
Set the command mode for the remote so it matches
the command mode for the recorder you set above.
1 Hold down ENTER
2 While holding down ENTER, enter the
command mode code number using the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
seconds.
4 Let up, press RETURN, all done!
Jul 28, 2009 | Sony Televison & Video
Command mode change disabled remote
According to Sony, if you turn the power on and hold the Enter key and the #1 key down together for at least 3 seconds, everything will default back to factory settings.
Mike
Feb 01, 2009 | Sony RDR-VX515 DVD Recorder/VCR
My remote control to RDR GX3 Sony DVD recorder does not function. When put on TV it works but does not work on DVD setting
Please change command mode on dvd recorder remote as it has 3 modes, dvd-1, dvd-2 and dvd-3. command mode switch is located at bottom part of remote.
DVD Recorder default command mode is DVD-3
Jan 30, 2009 | Sony RDR-GX3 DVD Recorder
Command mode
I did the same thing and lost all remote control to the recorder. Try holding ENTER & 3 in unison for as long as it takes (30 secs or more ) to view change on TV screen. This should get u back to system menu where u can change back to dvd 3 (default ) If doesn't work get a one for all remote and enter code 0533 which will get u in to the recorder command lines. PS enter & 3 worked 4 me.
Oct 22, 2008 | Sony RDR-GX300 DVD Recorder
Sony Video Cassette Recorder/DVD Recorder RDR-VX555 I have changed the command mode too DVD 2. How do I change it back to default command mode DVD 3. My remote will not work or allow system menu to...
Hold the "Enter" button and press number 1 on the keypad simultaneously for more than 5 seconds. This takes you back to the "Settings" screen with the "Settings" button, change the control back to DVD 3, and reverse the setting in the remote by pressing "Enter" and the number 3 this time. Remember to hold them down for more than 5 seconds.
Hope this helps
Thanks for reading!
May 02, 2008 | Televison & Video
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Remote doesn't work
Slide the bottom part of the remote control down. Switch the bottom right button to DVD 1. There might be a white sticker that covers it so remove the sticker first. Then hold down the "Enter" button and the "1" button down at the same time for a few seconds. That should make the remote work again.
Feb 25, 2008 | Sony RDR-VX530 DVD Recorder/VCR
Sony RDR-VX555 Logo
1,920 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
