Question about Jeep Yellow Sports Outdoor Power Wheels vehicle
Spare pushchair wheels for hauck jeep shopper 6
Want better wheels for pushchair manufacturer suplied wheels not sturdy enough can i replace them and where can i have this done...THEY ARE NOT ONES THAT PUMP UP...not sure if you can put them on this pushchair as it is a 4 wheeler
5 Suggested Answers
  • 286 Answers
SOURCE: i need the back wheels/brakes
hi
I would advise that you contact hauck direct their cusomer service is good I'm sure they will be able
to help here are there contact details phone number is to the right of the page
http://www.hauckuk.com/company/service/service-contact.html
Posted on Nov 14, 2010
Testimonial: "thanks for your help!"
ogre1967
  • 16 Answers
SOURCE: Low spare fault in a 2005 Jeep Liberty, tire is at rated pressure.
Wow another great problem by a dodge product i would check for a recall on the sensor switch
Posted on Nov 05, 2008
  • 9 Answers
SOURCE: 1995 Jeep Cherokee Country straight 6 cyl 4.0L: I
First of all, the fuel pump is generally located in the fuel tank, not always though. Yours probably is, in did not research it. The fuel electric fuel pump turns on only when the ignition key switch is turned to the start position and then left on. A series of one or two relays along with a pressure monitor in the fuel rail delivery system may or not cycle it on and off depending on design. Enough of that. I suggest that you remove the spark plugs to see if they are oil/heavy cabon deposits.If so, professional attention is reguired. One more thing you could try is replacing the spark plug wires. the may be old/worn out/damage. This would give the engine spark a stronger spark,if worn and also replace the spark plugs.
Posted on Jul 30, 2009
lindsay836
  • 677 Answers
SOURCE: My 2003 Jeep wrangler seems to have a fuel suply
Fuel pump is going bad, pulling to many amps.
Posted on Feb 04, 2010
Testimonial: "Had a feeling that was it but was hoping for a diiferent solution. Really dont feelike pulling the pump."
  • 6982 Answers
SOURCE: What is a way that i can get more horsepower out
Putting a r/v cam in sometimes will help a bit. An r/v cam will not really give you more HP, but will move the torque curve of your engine to a more usable rpm range. Believe it or not, most of the gain you will see isn't from the cam but is from changing the timing chain which in a high mile engine is likely worn. Most engines benefit from advancing the cam a few degrees (they actually sell kits for doing that) when installing. As a chain wears, it actually retards cam phasing.
Changing anything usually is a trade-off. Moving the rpm range of the cam will add low end response but will take away high end performance. If you do not generally run the engine up to 5,000 rpm, you may not notice that though.
Changing the intake, adding headers or adding a "performance chip" all have some benefits but never really give you the "advertised" increase. As far as those chips go, they generally work up around 4-5,000 rpm's and don't add much to everyday driving (read: worthless).
In reality, the most reliable way to restore lost power in a high mile engine is to do a total rebuild or find a compatible engine with lower miles. There is no "bolt on" cure for internal wear and though the Jeep engine is a tough reliable old bird, they do wear!
Posted on Aug 30, 2010
Hauck duett top seat unit wont lie flat as the long cable has broke where can i get one please,baby due in 6 weeks help
eBay has many spare parts for pushchairs so worth looking there. Also contact Hauck directly in my experience they can be very helpful
Feb 28, 2015 | Hauck Duett Twin Stroller Black
Hauck shopper 11 how to elevate base into sitting position
Have you tried using the strap at the back of the seat and using the black toggle to hold it into place. I am having a problem when the seat is upright position and you fold the pushchair the clips that hold the seat undo. The shop where I brought it from says you have to have the seat flat to fold the pushchair. But the seat string/toddle gets stuck. Anyone else having this problem?
Jun 12, 2013 | Hauck Shopper 11 Trio Set - Pooh Doodle...
I need a spare footrest to replace in my daughter's pushchair. Any idea where I can get it from?
Contact the manufacturer of the pushchair as they specialise in their specific product and may sell replacement footrests. Usually they'll have a website or you can find contact details in the manual.
Feb 17, 2010 | Hauck Infinity Umbrella Stroller
I can't fix on the two large wheels onto my Hauck pushchair
Hi just bought the same and spent over 2 hours trying to fix the back wheels on as they just kept falling off. Just discovered the diagram is wrong, insert cap c the other way round, it takes a bit of pushing but once on the black small cap d snaps shut keeping the wheels on. Hope this helps
Sep 04, 2009 | Hauck Infinity Umbrella Stroller
I need back wheels for my hauck sprint 6 pushchair
if you go to a bike shop thay should be able to help
Jun 12, 2009 | Hauck Infinity Stroller
Hauk infinity reversible pushchair, swivel wheels won't swivel
Removed the wheels and gave a little spray of WD40 lubricant, the wheels swivel perfectly now - very easy!
Aug 29, 2008 | Hauck I'coo Pico 4 Standard Stroller
Hauck Infinity- green pushchair
these just clip in place make sure black connection on back is pushed back in
Jun 18, 2008 | Hauck Infinity Umbrella Stroller
Jeep Yellow Sports Outdoor Power Wheels vehicle Logo
305 people viewed this question
Top Jeep Toys Experts
Glenn Smart
Glenn Smart
 Brian Main
Brian Main
Are you a Jeep Toy Expert? Answer questions, earn points and help others
