Foils and blades needed
SOURCE: Loose Cutter Block
when you remove the cutter block is there a white nylon fixture atop the vibrating mechanism? this nylon piece snaps on the vibrating rod and the cutter snaps into the nylon fixture.
SOURCE: Remington HKVAC-2000 Electric Shaver
Hi beebee73
If you are referring to the hkvac2000, it is a clipperstyle shaver, where the blades, because of the cutting action, do not generally need to be replaced. I have checked on the Remington website, and they do not sell any spare part blades for this model. To se what all comes with the shaver... comb sizes etc, check out the user manual for the device here
Hope this helps you. If you need me to do some more research, just ask:) Thanks for using FixYa, a FixYa rating would be great for my efforts to get this information for you. Cheers
regards
robotek
SOURCE: I have a remington F7790, a great razor but the
This problem is because the shaver has not been thoroughly cleaned. There is a build-up of hair particles where the screen snaps onto the shaver which is preventing it from latching into place. Clean it thoroughly and it should be fine
If you are certain that it is thoroughly cleaned and still have problems, your screen is worn and will need replaced. You will find replacements for model F7790 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-sp-390-foil-and-cutter-set.html
SOURCE: How do you insert a new Remington Microscreen
You will find instructions at shaveroutlet.com. See link below
http://shaveroutlet.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/f/i/file_21_10.jpg
SOURCE: FS790 Remington triple foil razor
The model is F5790. You will find replacements at shaveroutlet.com. See link below
