Question about Whirlpool LER4634J Electric Dryer
Belt on dryer
Where is the belt on the dryer located
  • Whirlpool Master
  • 4,654 Answers
The belt goes around the outside of the drum and an idler pulley and then to the motor. below is a kit you will need to complete the replacement.belt on dryer - 8b2b1a9.jpgThe kit is $30.00 and below is a link so you can view the parts. Click link below. Let me know if I can help you more, Thanks Sea Breeze
http://www.repairclinic.com/Appliance-Parts?s=t-LER4634J-%3d%3dd583376
Posted on Feb 28, 2009
Where is the belt located on this model? Where do I access the belt from?
The belt is usually located from the access panel. You just take the front panel off of the dryer and you can access for the belt.
May 17, 2011 | Dryers
Tip
My dryer drum will not turn...."how to change your dryer belt"
There are many styles and different models of dryers but the one thing they all have in common is the dryer has a belt that turns the drum.In the procedure below we will show you how to take apart your dryer,change your belt,and show you the correct threading of your belt. Here is a typical Kenmore dryer idler pulley(it has a plastic wheel on it) motor/pulley (the pulley is attached to the backside of the motor) and the belt configuration.Note the picture below.
Each different model dryer also has a different lint trap location. This location will have a bearing on how your dryer is taken apart and how to change your belt.
Note the location of your lint trap and choose the correct video on how to take your dryer apart. There are two different locations,on top,and in the door.
This video will show you how to take apart your dryer and change your belt if the lint trap is on top of your dryerhttp://www.youtube.com/watch?v=CFnXwmUb4f4
lint trap on top
This video will show you how to take apart your dryer and change your belt if the lint trap is inside of your door. http://www.youtube.com/watch?v=rtATa0a28bE
lint trap in door
This video will show you how to take your dryer apart and change your belt with the control panel in the front side panel rhttp://www.youtube.com/watch?v=zpUqCrLaI7g
control panel in front
This video will show you how to take apart your Maytag L shaped dryer and change your belt.
http://www.repairclinic.com/PartDetail/Belt-Drive/1246110?modelNumber=LDE8424ACE#repairHelpVideoTabs
L shaped dryer
If you happen to run into an issue with your belt and pulley configuration all the diagrams are here click on the linkhttp://www.repairclinic.com/Dryer-Belt-Diagrams
If this has helped you please consider giving us a 4 thumbs up on our rating.This procedure has saved you a minimum of $125.00
Thanks in Advance and Thank You for using Fixya!
on Mar 21, 2011 | Dryers
Want a wiring diagram for hotpoint dryer, mod#DLB2750BAL.ser#AD 209876H dryer wont run after starting
Make sure the belt is good. These dryers have a belt switch located near the motor. If the belt is broken the dryer will not run.The belt switch could be bad also. Also check the door switch.
Verify 220 volts of power at the terminal where the cord attaches to the dryer.
Feb 11, 2010 | Hotpoint Dryers
Diagram for setting up belt on drum tenion
Replacing the Belt
  • Step 1 Put the dryer door-side down on the floor. This allows easier access to the back.
  • Step 2 Locate the center pivot suspending the dryer drum. If held by a clamp, removed any nuts or screws retaining the pivot axle.
  • Step 3 Move the pivot out of the bracket and slide the new belt inside the bracket.
  • Step 4 Replace the drum pivot in the bracket and reassemble the bracket.
    Looping the Belt
  • Step 1 Flip the dryer up so it is once again sitting upright.
  • Step 2 Locate the groove or wear mark the previous belt left in in the circumference of the drum.
  • Step 3 Wrap the belt around the drum in this groove or wear mark, with available slack at the bottom of the drum.
  • Step 4 Wrap the belt around the drive wheel located on the drive motor in the lower corner of the dryer.
  • Step 5 Insure the belt is snug but not biting the drive wheel. This indicates the proper size belt is installed.
    Reassembly
  • Step 1 Reattach any clips or wires to the back cover.
  • Step 2 Reattach the back cover using the six-sided sheet metal screws removed earlier.
  • Step 3 Reattach the top cover. Close tightly so clips secure the cover.
  • Step 4 Plug in the dryer and turn it on to test the belt repair.
  • Step 5 Reattach the dryer vent conduit
  • Feb 06, 2010 | GE Dryers
    I need to replace the belt in my GLER341AS2 model Frigidaire dryer. How do i open up the dryer to do so?
    Unplug the dryer and using a 1/2 inch pait scraper locate the spring loded clips holding the top down to the front of the cabnet. They are located about one to two inches from the front corners of the dryer.
    Lift the top and rest it on the wall behind the dryer.
    Looking inside the dryer locate the screws holding the front panel to the cabnet and remove the screws.
    Mark the wires to the door switch and remove.
    Remove the front panel.
    Go behind the dryer and remove the small rear panel near the bottom of the dryer.Observe how the belt is attached to the pulleys.Release the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
    Go to the front of the dryer and grab the belt on the top of the dryer drum. Holding the belt lift the drum straight out holding the drum with the belt.
    Check to see if all the rollers are in good shape and rotate freeley. Oil if needed.
    Check to see if the teflon gliders located on the front panel that hold the drum are in good shape. Replace if needed.
    Vaccum the inside of the dryer.
    Put the new belt over the drum and line the drum up and install back into the dryer.
    Put the front panel back on and reinstall the two screws.
    Replace the door switch wires.
    Make sure the grooves on the belt are flat to the dryer drum
    Put the top down and go behind the dryer'
    Locate the belt.
    Pinch the belt and insert it under the tention pulley and slide it over the motor pulley. Make sure the belt is positioned straight and located where the old belt was positioned on the drum.
    Jan 03, 2010 | Frigidaire GLER341A Electric Dryer
    I have my kenmore 80 series dryer apart, and i am replacing the belt. having trouble configuring the belt around the pulley and motor, since the belt cannot actually go into the pulley, its sealed. help.
    Kenmore dryers are configured in several different ways as far as the location and routing of the dryer belt. For drawings of how the belt is configured on your dryer, go to Repairclinic.com and click on the "Repair Help" link. On the following page locate the "Dryer Belt Diagrams" link under the "Special Features" section. Scroll down to the Kenmore section and refer to diagrams H, B, or K. If you are not certain, please post back with your complete model number (located on a nameplate around the door opening) and I can determine for you. I hope this helps you.
    Oct 23, 2009 | Kenmore 62622 Electric Dryer
    Not working, theres power but nothings working? belt maybe, where is the belt located? If not what els could it be? and where would that be located?
    There should be a trouble door in the back so you can see the belt. If the motor is not running, I would check the door switch first. The pcappliancerepair.com site has parts and help.
    May 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
    Need routing diagram of dryer belt on maytag dryer D7600
    Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, locate the "Dryer Belt Diagrams" link under the "Special Features" section. Scroll down to Maytag. The dryer belt diagram for Maytag should be listed as diagram E. I hope this helps you.
    Jan 28, 2009 | Maytag PYE2300AY Electric Dryer
    Broken Belt--kenmore 70 series dryer
    it is not that hard to replace the belt if you have the front panel off of the dryer. place the idler pulley in the holes located below the motor pulley put the belt around the drum pull the idler back and the belt loops around the idler and onto the motor pulley
    Dec 10, 2008 | Kenmore 24032\24036 Top Load Washer
    Do you have a diagram on to fit a new belt to a tumble dryer
    Go to repairclinic.com and click on "Repair Help". Locate the "Dryer Belt Diagrams" link at the bottom left hand side of the screen and locate your Dryer Brand name. You should be able to find your diagram there.
    Apr 21, 2008 | Dryers
    Whirlpool LER4634J Electric Dryer Logo
    109 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal DeAngelo
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
