Question about Dometic Rooftop RV Air Conditioner
Roof ac runs for six minutes then breaks the circuit breakers
Every time we have tried to use our new Dometic roof a/c when it is hot outside it runs for a few minutes then the circuit breakers switch off. We have had it tested three times and it runs, but each time it has been tested it is no more than about sixty degrees outside. Our air conditioner works when it is not needed but does not work when we need it.
    Guru:
  • 462 Answers
Your problem may or may not be tied to the ac unit its self.
You did not state how old it is or at least how old you think it is. This would help eliominate some assumptions on my part. I assume from the pic with it and from what i know about RTU on motor homes or travel trailers this is what you have. In anyh case most of the items Im outlining here under the UNit apply to other AC's as well. You also didnt mention what kind of outdoor temps or parking conditions or where you may have been taking the RV. Dirt in the outdoor coil is the most likely problem, from your discription. Take a water hose with a nozzel and good water pressure and flush wash the outdoor coil. If you get mud dirt out with this retry the unit after  lettting it air dry for 30 min to an hour depending on humidity and temperature.
If the ac is the real problem begin by inspecting the out door coil. Usually air is "sucked in" and blown out over the fan motor and compressor, . If the coil is clean (and you can see light thrugh it by looking streight throgh it, being horizontal) then it still may be inside the ac unit. A run capicator or possibly (though I doubt it) low on refrigerant, or a start component if so equiped (not seen on most smaller ac units unless added after the sale and installation). .1 other thing it might be is a loose fan blade but usually this makes so much noise you hear the problem and know right where to look.
If your unit is installed on a travel trailer or other mobile recreation vehc. I suspect it may be wired other than directly or have a bad breaker or a weak connection in the wiring or on the breaker or unit itsself. An ampmeeter would be of help to you in comming to a more accurate diagnosis. About the only way to check without one (and it may not be complete or show anything directly) is to begin at the breaker and feel the surface of it while the AC is running and under a load (like when you have had it trip out before) note the FEEL temp it should not be HOT and not go past where the touch on the front surface is uncomfortable. If it gets HOT , be extreamly careful and disconnect the power and remover the pannel and inspect the breaker. If the wire is tight and is not corroded check the nutural side if its 115V and make sure the wire there is tight. Now If you see any thing that dosnt look right ask somemore questions if you dont feel hot breaker, see any wires loose or corroded, go to the unit on top and inspect the  "TIE BOX" where the wireing attaches to the unit. Again looking for the same thing. With the top off while inspecting move the fan blade aroiund and hold the shaft on the motor if it slips the problem is on the fan blade most likely. Its not suppose to slip.  To my knowledge the power may also come from a generator connection and this needs to be checked too. Get back to me if any of this is not clear
Posted on Feb 28, 2009
E7 error code
when you trip breaker it will give e7 code. something pulling to many amps. heat and ac running at same time.
Jul 11, 2013 | Dometic Heating & Cooling
Runs/cools great unless outside temp gets in high 80s
try replacing capacitors. or communication cable issue to that a/c
Jun 25, 2013 | Dometic Rooftop RV Air Conditioner
My Dometic roof top ac doesn't cool. Fan runs fine, no COOL air. With thermostat in off position. Checking the voltages I found 118v at the breaker. At the run relay, 118v going in and a coupl
Please reply with Model number of bottom of AC unit ( upper) . Can be seen from inside usually. Thermostat model, plus if controls are at the ceiling assy or at thermostat on wall.
Jan 17, 2013 | Dometic Rooftop RV Air Conditioner
MY DOMETIC RUNS ALL DAY THEN IT BLOWS A BRAKER ONCE A DAY, WHATS THE PROBLEM ? BLOWS COLD AIR
Depending on how hot it is outside, there may not be a problem. It might just be running all day to try to keep up with the amount of heat that's outside. It'll blow a breaker most likely because it's drawing so many amps through the circuit breaker that it trips.
Jul 27, 2011 | Dometic 57915531 Air Conditioner
Keeps tripping breaker when running ac
you need to check that the breaker it rated high enough for the ac unit
Jun 04, 2009 | Dometic Rooftop RV Air Conditioner
Ac Problems
You must have too many things running on that circuit. Check your connection to the power box.Loose connection on the receptacle can cause the breaker to trip or too many things running on the same circuit. If the breaker is old it might need to be replaced.
May 10, 2009 | Dometic Rooftop RV Air Conditioner
Tripping circuit breaker
You probably have a dirty condenser coil or the con den ser fan motor is bad or the blades are jam that's why it overheat and shut off by overload.
Apr 20, 2009 | Dometic Rooftop RV Air Conditioner
579 series, 13.5K BTU Rooftop trips AC circuit breaker in hot weather...
Is your condensing unit located in a well ventilated area and have an ample space, atleast a foot, from the rooftop flooring? Just make a check that free flowing outside air properly ventilates the condensing unit specially on high ambient temperatures. Hope this would solve your problem
Sep 16, 2008 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
221 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
