Question about GE Spacemaker JVM1640SJ Microwave Oven
Cannot remove handle to replace it.  The handle broke on top.
  • deemisto Mar 02, 2009
    Thank you I am oing to try that. wish me luck.
    dee
    thanks again I have to wait for the weekend to try this. My handle just arrived. Yes it was $50.00 bucks. I can't tell you how much I appreciate this advice.
    dee
You must pry out the plastic strip that surrounds the window on the inside of the door to reach the top screw that holds on the handle. Be prepared to spend a pretty penny on the replacement handle as well.
Posted on Mar 01, 2009
  • Mark Mar 02, 2009
    Good luck! It's not hard once you remove the plastic. As I recall, the handle was around $50 with S&H!
2 Suggested Answers
MicrowaveSvc
  • 9086 Answers
SOURCE: Broken handle on GE Spacemaker XL1800 microwave
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 07, 2008
Handle broke off microwave
lLAST TIME MY GE MICRO HANDLE BROKE IT WAS 179 FOR REPAIR
IT BROKE AGAIN AT THE TOP
AS ITS TEN YEARS OLD I JUST PUT CRAZY GLUE AT THE TOP AND THEN TOOK AN OLD RUBBER HANDLE FROM A CAN OPENER AND TAPED IT WITH ELECTRICAL TAPE TO THE INSIDE TOP OF THE HANDLE THIS WAY THE HANDLE CAN ONLY BE OPENED FROM THE BOTTOM NEXT I WILL TRY TO GLUE THE CAN OPENER HANDLE TO THE BACK OF THE MICRO HANDLE AND REMOVE THE TAPE
Jan 28, 2012 | GE Advantium 120 Convection/Microwave Oven
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
can u send me the pic of door and the handle of ur oven at khader_abu@yahoo.com........
Jun 01, 2008 | GE Advantium SCA1000H Convection /...
I have a whirlpool mh1150xms-3 and the handle is broke! how do i replace it without breaking the glass? i took out the 3 screws on the left side and it wont seperate from the outside case!
Unplug the microwave oven from its power outlet or turn off its circuit breaker. Remove the right fuse from the home fuse-box if your microwave is a built-in model.
Open the microwave door and take the top pin off its pivot bracket. Lift up the door and remove it from the bottom bracket. Lay the microwave door with its front side down on a folded towel. Remove the two choke screws from the door frame using a Phillips head screwdriver.
Remove the choke cover with the knife blade, starting from the microwave door's top right corner. Pry out the bottom and top right sides, leaving the side which houses the door handle in place.
Remove the choke tabs from their slots on the microwave door frame using the knife blade. Continue to work clockwise around your microwave door; remove the choker cover when you get to your handle's side to separate it from your choke.
Remove the two handles with the Phillips screwdriver. Remove the handle from the microwave.
Screw the new handle in the position of the original handle. Lay the choke on the microwave door; set the choke cover right on top of it. Insert the choke tabs into their slots on the microwave door frame using the knife blade.
Secure the two choke screws using a Phillips head screwdriver; set the microwave door back on the bottom bracket. Slide the top pin into the microwave's pivot bracket.
Press the top pin down until it pops securely into place.
Oct 03, 2011 | Whirlpool MH1150XM Convection/Microwave...
Handle broke off on Samsung 7185STG. I ordered a new handle from Samsung parts and need instruction on how to replace.
remove the inner panel on the door itself and with the use of a Flathead screwdriver carefully pry off starting closest to the door hinge and careful not to break off the tabs push them down one by one until you free the top and remove all together now then 2 screws or nuts are accessible simply remove and replace .set the bottom of the trim panel in place then snap the upper portion back into place ..you are done
Sep 07, 2009 | Samsung Microwave Ovens
The handle broke, got a new one took off the
Sometimes you have to rotate the handle after the top screw is out.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If this doesn't solve your problem, please reply back with your brand and model number so we can help you.
Jun 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Door handle broke off
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can get Samsung parts here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 18, 2008 | Samsung 1.8 Cu. Ft. Over-the-Range...
Handle Replacement on a HKMS155L Microwave
I think you have solved your problem already.
I have seen your requesty only now and I am sending the diagram to replace handle.
You remove door latch (nr 3 on diagram) first, then you unscrew the screw nr .8 and remove handle (nr.7).
Below the diagram:
You can find all parts and diagram for your appliance here.
Jun 09, 2008 | KitchenAid KHMS155L Microwave Oven
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
May 07, 2008 | Microwave Ovens
Check out this door frame diagram, specifically number 1805. It clips on to the door frame. Remove it using a dull table knife or something similar (be careful not to scratch or break anything). You will then have access to the bottom screw.
Mar 18, 2008 | GE Advantium SCA1000H Convection /...
Problem with GE Door Handle
You can find helpful exploded view diagrams and by entering your model number here: http://tinyurl.com/gv383
Oct 08, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
121 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
