Question about Minolta DiALTA Di520 Laser Printer
I REPLACED MY TONER COLLECTION Minolta d520
I REPLACED MY TONER COLLECTION BOTTLE ON MY DI520 COPIER. IS THERE A CODE TO RESET THE MACHINE SO IT WILL WORK
  • Minolta Master
  • 1,297 Answers
Press Utility key and press in this order STOP-0-STOP-0-0-1,select COUNTER windows,select waste toner windows: for SET press C(cancel 10 keys pad) introduction 320000; for Counter press C.press Exit too quit,back the basic menu.
Posted on Jul 30, 2009
Error code c0070 konica minolta copier service code c0070
Sir/Mam
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KNUB on the side of the bottle is damage put a new one in. That KNUB is what the toner motor uses to turn the bottle, if it damaged you get a code. If that does not work, you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad.
Feb 05, 2014 | Konica Minolta DiALTA Di200 Copier
Konica minolta 363 error message c2201
Toner bottle failure to turn. Shut off the machine remove the toner bottle, turn on the machine with the bottle inside it, wait for the machine go thru its paces when it ask for the toner install in correctly if the knub on the bottle is damage get a new one . if this does not work get a tech to look at it either the motor is bad or worse the control board is bad$$$
reset open close side door
Feb 24, 2012 | Minolta Office Equipment & Supplies
KONICA MINOLTA ERROR CODE CALL C0070 MACHINE
Problem with toner bottle motor
After
a reset problem, remove the bottom cover back and PC11 toner sensor block cover. And release the locking lever bottle, turn the bottle 1 / 2 turn recontact PC11. The bottle turns she released the lever?
May 25, 2011 | Konica Minolta DiALTA Di200 Copier
Minolta ep 3050 copier error code coo70, toner bottle does not turn. have replaced toner motor.
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner install it correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
Nov 01, 2010 | Minolta EP1030/1030F CS/PRO Copier
Toner collection bottle
Please pres UTILITY key ,after touch Neter count to touch panel display,press in that order Stop - 0 -Stop -0 - 0 - 1; select COUNTER,select Consumables,select waste toner:
SET : 320000
Counter:press C to cleared the value.
After press exit etc.
Feb 27, 2009 | Minolta DiALTA Di520 Laser Printer
Minolta DI200 Error Code 00070
try and take the toner bottle out and turn machine on and than put the bottle back.it;s bottle sensor problem.good lock
Feb 05, 2009 | Konica Minolta DiALTA Di200 Copier
Di520 black and white copier toner collection box
Enter the tech rep mode by pushing the utility button, pulling up the counter screen, and pushing Stop-0-0-Stop-0-1.
This will pull up the tech rep mode menu. Select "Counter" and then "Consumables."
Select the toner collection count and hit "Clear." Exit the mode and you should be good to go.
Dec 30, 2008 | Konica Minolta DiALTA Di200 Copier
Can't find toner collection box
So which is it, a Di200 or a Di520?
A Di200 has no toner collection box - the waste toner is recycled.
The toner collection box on a Di520 is located in the rear of the machine - just remove the main rear cover and it is obvious.
Nov 18, 2008 | Konica Minolta DiALTA Di200 Copier
Minolta Di200f copier
The error code has to do with the toner bottle/hopper. You just adde toner Right? Take the new toner bottle out and make sure not to spill any. Then close the doors of the copier and turn the main power switch OFF then back On. Let the copier warm up to Ready toCopy. Then reinstall the toner bottle and that should do it for you. The toner was out of HP when the toner was replaced. ... Good Luck
Oct 08, 2008 | Konica Minolta DiALTA Di200 Copier
Service
it means it time for the cleaning web, and waste toner bottle to be replaced. once you replace it you can reset the indicator.
thanx,
mikey
Mar 19, 2008 | Minolta EP4000/5000 CS/PRO Copier
144 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
