Question about Sony Playstation 3 (PS3) Console
My ps3 wont connect to play online
When I try to play online its saying test connection failed. Please help me.
    President:
  • 2,653 Answers
You need to setup your connection.
Are you using a wired or wireless connection?
Posted on Feb 27, 2009
Ps3 error code 80029020
Make sure UPnP is enabled on the PS3 and Router.
Place the PS3 in the DMZ of the router or find the appropriate ports to forward to the PS3's connecting IP (set to static in the PS3 if you have it setting dynamicly in the PS3 for either)
If this does not help, do a forum search there are a ton of answers for this on on the Network board here.
Feb 23, 2014 | Video Game Consoles & Games
How to get it online with a ps3? I hooked it up to the ps3 with the Ethernet cable. It says connection failed .but it wont go online. Any help would be dearly needed. Thanks
First test the Internet connection by connecting a LAN cable from your DSL or cable modem to your computer and see if you can get into the Internet.
If you can't access the Internet then phone your ISP and get them to test your connection to your modem.
If the Internet connection is OK then click on this WEB site and follow the instruction to configure the PS3 :-
wii.php">http://fixhomenetwork.com/xbox-play-station-wii.php
Jan 01, 2010 | Arris SURFboard SB5101 Cable Modem
Hello ps3. connection test fails all the time. i cant play online. help
if your wlan light isnt blinking, that might be your ethernet connection. try switching your ethernet connection from your computer to your ps3 ( if you have a wireless router ) if not keep it there but change your phone wire connections.
Dec 13, 2009 | Video Game Consoles & Games
Had my ps3 for year and half now, never played online (80710102)
Ok first off create a psn account online via computer, this is free of charge. Then after that connect your ps3 via cable to your modem. turn it on and access network settings. Then select internet connection settings, select easy. After it is finished select test connection. Should this time out it means you have a faulty connector somewhere, try checking your cables and the ports on the ps3 and modem. But if it states connected, back out and go to network via your ps3 dashboard then select sign in and enter your account info from your psn account.
Dec 08, 2009 | Sony Video Game Consoles & Games
Trying to do a 1.04 version update, and it wont do...when i do a connection test, i can get online, but when it says playstation network, it is failing the test. as a result i can not update the games i am...
You'll probably have to download the update via the PC method.
Sony details all the instructions HERE.
Just follow the guide and you'll be all set.
--RescueTechLA
Nov 28, 2009 | Sony Playstation 3 (PS3) Console
IP Address "Failed"
restore your default settings. check your security key and you shoudl be good to go. it's nothing with your ps3 and probably just something with yoru router. also try restoring the default settings and just connecting directly to your router or your modem with an ethernet cable
Dec 29, 2008 | Sony Playstation 3 (PS3) Console
I cant get my ps3 to hook up to my internet
Use the PS3's Internet connection test under Systems Settings to determine if you've access to the web. If this test fails you will need to do the following:
1) Reset your DSL modem.
2) Once the cycle is completed, run the Internet Setup under Systems Settings within your PS3.
3) Follow the instructions you should be able to gain access to the web and online game play.
Nov 19, 2008 | Linksys WRT300N Wireless Router
PS3 wireless internet problems
It sounds like a defective wireless antenna. Connect your PS3 via a long network cable and see if you can get online. If you can, the problem is a defective antenna.
Assuming you purchased the PS3 from a store and have the reciept, you should be able to get it swapped or fixed via warranty.
Good luck and take care,
Chimpster
Aug 06, 2008 | Sony Playstation 3 (PS3) Console
PS3 online problems
ive got kind of the same problem....but my problem is....ive created an account and the internet is working fine on the ps3....but it says i need to upgrade the game (resistance & Motorstorm) to go online....and like half-way through the upgrade process it always says it failed to complete....any ideas??
Feb 12, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
