Picture flickers to blue screen.
I have an older Mitsubishi CRT TV, model CS-31MX1. The picture flickers between a nice picture and blue screen. It seems to improve somewhat as it warms up. I am curious what this is, how much it would be to fix (roughly) and if it is worth the fix.
  • 1 more comment
  • toobiloo Feb 28, 2009
    Thank you for the info, Len. I'm not an expert, but I don't think that is the problem, or at least not the whole problem. When the picture is on, it is great, a nice clean picture, then it flicks to a pure blue screen, the same blue screen that appears when you cycle through the inputs, or enter the menu. This happens continuously, flicking back and forth. It doesn't appear to be a problem with the picture tube itself because both the picture and the blue screen are very clear and crisp.
    - Tobias
    Thank you for your help I appreciate the info. I googled a bit and found this about the same model tv:
    . TUNER VIDEO AND SOUND CYCLES BACK AND FORTH FROM CORRECT VIDEO AND
    SOUND TO SNOW. CHECK C713 (4.7UF NP 50V) ON MATRIX-PWB
    If there is a blue screen option in the customer menu it may be on and
    if it were off you may see snow instead of blue screen between video
    flashes.
    The thread is here: http://www.freelists.org/post/techassist...Not sure exactly what they are talking about, but seems to be some sort of capacitor? I that a hard thing to fix? I appreciate the input.
    Len,
    Funny thing happened. I was testing it like you suggested. When I turned video mute off, the problem went away! No trip to the repair center, no need to buy a new TV. Thanks for your help.
  • 57 Answers
After a typical picture tube ages it gets a coating of chemicals (carbon, phosphor and various metals form heater filaments) on the red, green or blue electron guns. This degrades any one or all three guns over time. There is a process to "zap" or rejuvenate the picture tube. A "good" TV repair shop will have the device to do this. The cost should be between 1 to 2 hours of repair labor. That equates to $75 - $150. The only thing is that this process does not clean the guns effectively and they can "cake up" again. Think of it as a coronary cleaning, it does not mean the "plaque" can build back up. It will, and usually within 1 to 3 years depending on how old the unit is and how long it is on per day. The other alternative is replacing the picture tube. 2 - 3 hours of labor plus parts. An average picture tube (after technician's mark up) costs anywhere from $100 for 13'" set to thousands. Looking at your model, it's a 31". I would guess at $400 - $500 just for the picture tube. I like Mitsu's. A good machine. Right in line with Sony on up. (and better in a number of occasions I have seen) When the cost of the repair is over 50% of the cost of the unit, that's when I declare it replaceable at the hospital system where I worked. (Over 900 TVs) You should weigh the price too.
Hope this insight helps - Let me know if it did.
Len
Posted on Feb 27, 2009
  • Len Falk
    Len Falk Feb 28, 2009
    Thank you for your reply - Yes - I misconstrued - That is totaly different - That's the "Blue screen of no input". My question to you is - What is the source of your signal? Check your connections at the television and at your receiver box (Cable - Satellite - DVD) to the input jack of your TV. - Now it is a process of elimination to see what is causing the signal loss -
    Its usually caused by loose connections or bad connection fittings. Sometimes caused inadvertantly by haveing the TV jack in back pressed against the wall. This can cause damage to the cable, it's connection jack, and in extreme cases to the printed circuit board inside the television - Try those suggestions once - Sorry for the incorrect read the first time
    Len
  • Len Falk
    I saw Jim's post and not looking at the schematic the repair would be
    simple enough for me. I like to side with safety on the issue of CRT
    type tv sets as they hold a very high voltage potential. If your electronics knowledge is sufficient then yes, the part can be ordered easily at
    www.digikey.com
    follow his advice to set the menu for "Blue Screen OFF" options to see if that happens. (Second opinions are always welcome! :)
    If not, a TV technician should be able to repair it in an hour of labor time (see initial response) I hope this helps and thanks for the web link!
    Len
Picture is wider than screen
Hi JC,
please google this with tv model number
mitsubishi xxxxxxx tv servise mode code.
go to servise mode and do the adjusment.
good luck.
regards,
nuwan
Jan 27, 2014 | Mitsubishi CS-40505 TV
Why does my tv have one blue, one red and one green line at the top of the screen but no picture?
The CRT inside the TV has gone bad. You can either find the make and model of the CRT and replace it, or get rid of the tv and buy another one.
Jun 08, 2012 | Televison & Video
I have a tv mitsubishi model cs 27205 the problem is green screen, what is the problem?
CHECK RESISTORS ON CRT BOARD .THE BOARD IS MOUNTED AT THE BACK OF PICTURE TUBE .
Aug 12, 2010 | Mitsubishi CS-27205 TV
Mitsubishi CS-35X7 CRT TV (vintage 1993) no picture
THE PIP MODULES GO BAD IN THESE SETS. THEY PLUG IN AND ARE EASY TO CHANGE AND EVEN CHEAPER IS THE PIP BYPASS MODULE. IT ELIMINATES PIP AND PLUGS INTO THE SAME SPOT
Dec 21, 2009 | Televison & Video
Cs-36509 mitsubishi tv has a flicker.Makes it hard to read words. Is real bad when you first turn the tv on, but after a minute it settles down, but is still there all the time... any suggestions?
Yes first it may just be bad solder on the
flyback transformer , or the Picture in Picture
module has some bad caps . a fair shop
price is about 180-200 and it worth the repair
they are great TVs and are made to last.
ps i have repaired my mitsubishi once , and
its going strong. 18 years old .
THE OLD STUFF IS BETTER THEN THE NEW STUFF.
Mar 25, 2009 | Mitsubishi CS-36509 TV
Narrow blue horizontal line across screen on intial power up
You have trouble with the vertical deflection circuitry. Probably something in the driver circuit or power supply to the driver. Maybe even a cold solder joint since it comes up after a little warmup.
Jan 17, 2009 | Mitsubishi CS-40503 TV
Mitsubishi CS-31MX1. When first turned
no. capacitors in vertical circuit going south. sorry.
Dec 17, 2008 | Televison & Video
Mitsubishi CS-40503 Horizontal Picture Problems
Your trouble is with the vertical deflection circuitry. You'll need to have it serviced by a professional.
Sep 13, 2008 | Mitsubishi CS-40503 TV
FORGOT PASSCODE ON TV PARENTAL LOCKOUT
that's a big problem. sometimes using the 0000 can unlock it but it's not 100 percent.try the trial and error.
Apr 19, 2008 | Mitsubishi CS-40503 TV
Mitsubishi CS-27405 no picture but sound
your problem is the PIP board,tough to repair,can be taken out and replaced with two 10 mfd caps 50v bipolar from pin5 to 11 and from pin 7 to 9
Sep 27, 2006 | Mitsubishi CS-27405 TV
Televison & Video Logo
145 people viewed this question
Top Televison & Video Experts
