Question about ASUS P4S533-X Motherboard
The motherboard makes a 3 second beep over and over.
When I turn on the computer during POST the motherboard buzzer makes a 3 second long beep error code. I was wondering what error code this is? It has very little thermal compound on the CPU because the Bracket broke and I had to remove it and zip tie the CPU/HeatSink/FoxConn fan. I am looking to replace the mother board, Case, PSU and CPU. I am a student at Western Governors University and taking information systems management and Network Security I will also be receiving MCSE, CISCO, ORACLE, A+ Tech and some other certifications and I am into gaming when I have time .What Asus Motherboard would you suggest I get. I would like to use my PC2700-PC3200 memory?
  • RescueTechLA
    RescueTechLA May 11, 2010
    sry i'm a **** i know.
    Usually the 3 beeps is memory related.
    Try reseating the memory or just using one stick if you've got more than one.
    Hope this helps.
  • RescueTechLA
    OMG if you can't figure this one out by yourself you've got a LONG WAY to go.
    Good luck with that education.
  • 59 Answers
Award Bios BEEP Codes
1 Long Beep: Memory problem
Explanation: There is a failure of some sort related to the system memory.
Diagnosis: The first bank of memory probably has a failure of some sort; this is usually just a physical problem such as an incorrectly inserted module, but may also mean a bad memory chip in a module. It is possible that there is a failure related to the motherboard or a system device as well.
• 1 Long, then 2 Short Beeps: Video error
Explanation: The BIOS is unable to access the video system in order to write any error messages to the screen.
Diagnosis: This is usually caused by a problem with the video card, or the memory on the video card. It can also be a motherboard issue.
• 1 Long, then 3 Short Beeps: Video error
• Continuous Beeping: Memory or video problem
Explanation: The system is producing constant beeping in no specific pattern, or a fast "ringing" sound.
Diagnosis: This is usually caused by a problem with the system memory, or possibly the video card. The memory is more likely--the system complains long and loud if it can't find any usable memory, as there is no way to even start the boot process when this is the case. The motherboard itself could also be the problem.
• Other Beep Codes
Explanation: You have encountered an Award BIOS beep code I do not have documented.
Diagnosis: Award says that any beep patterns other than "one long followed by two short" are likely problems with the system memory. However, of late they have started adding other beep codes to their systems as well.
Hope this helps.
Posted on Feb 27, 2009
  • 37 Answers
Nick,
That beep code usually signifies one of the devices connected to your motherboard is having an issue and the motherboard is not able to past the POST.
You will have to do some digging to determine the cause of the problem. First step, remove the RAM, and see if the error code changes.
How did the bracket brake? If it is broken your CPU or CPU Socket might have gone bad.
If you're thinking about upgrading, you might as well ditch the PC2700-3200 and upgrade to DDR2 or DDR3. PC2700 is DDR which is becoming a phased out product line. Just FYI.
Hope this helps.
As a reminder, if this post helps, please rate it. Thankyou.
Beep Error During POST
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM and Cmos battery are securely seated
Test all leads that attach to your hard drive including electrical extensions IDE SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
graphics card is seated properly with no dust in the socket you might have to remove it to check for dust
a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty
a computer needs all electric current and computer data to travel to and through every working device and have an end to work properly click start right click on my computer so any faulty leads will end up with a computer error
hope this helps you
Apr 10, 2012 | Chaintech CT-6AJA4 Motherboard
My asus p5n-E sli motherboard just beeps when i turn the computer on, any ideas?
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
a computer needs its connections to continue its cycle and to have and end to function
the beeps are post pre operating system searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs all electric current and computer data to travel to and through every working device and have an end to work properly click start right click on my computer so any faulty leads will end up with a computer error
hope this helps you
Aug 28, 2011 | ASUS P5W DH Deluxe Motherboard
When turned on a long beep then every 15 seconds beeps continue
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
hope this helps
Aug 24, 2011 | Soyo SY-P4IS2 Motherboard
I have recently built a new PC with an Asus P8H61-M and upon turning the PC on I am recieving no Visual on either of my monitors
Hello
If this is the first time to turn you on your computer check first the power supply of your computer if connected to their proper connector. Check your memory if clip properly in there memory slot. If you are using Video Card check it if it is properly connected to the connector. Then connect your VGA connector at the back of your computer when you have video card connect the VGA Cable of you monitor to the video card VGA output if does not have connect it with the onboard VGA output. Then press the power switch if the unit is still no visual in monitor try to search or hear a beeping sound in your computer by its on board buzzer. Find which beep you hear from your computer.
No Beep- No Power, Loose Card, or Short.
One Short Beep- Normal Post,, Computer is OK.
2 Short Beep- POST error, review screen for error code
Continues Beep- No power, Loose Card, or Short
Repeating Short Beep- No Power Loose Card or Short
One Long And Short Beep- Motherboard Issue
One Long and Two Short Beep- Video (mono/CGA Display Circuitry) Issue.
One long and three short beep- Video (EGA) Display Circuitry
Three Long Beep- Keyboard/ Keyboard Card Error
One Beep, Blank or Incorrect Display -Video Display Circuitry
Hope this help with your problem. Keep on touch in fixya
Jul 19, 2011 | ASUS P8H61M Intel H61 TX Motherboard
Intel motherboard (DG41) desktop is continuously beeping with green light for 3 second then stop and again start
make sure that your RAM is securely seated
obvisously the beeps are windows searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Jun 15, 2011 | Intel Motherboard
PowerEdge 2850 server beeps as soon as it is turned on - 3-2-1 beeps format. What has failed?
hope this helps
May 03, 2011 | Dell 3.0 GHz Second Processor for...
Beeps once when starting up then beeps second time once after it runs the memory test then nothing else happens
hope this helps
May 02, 2011 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
I have agigabite ga-k8n51gn motherboard, i get 1 long beep every few seconds on boot up, black screen and can't get into bios linsey
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 19, 2011 | Gigabyte GA-K8NS Motherboard
When I turn on the computer during POST the motherboard buzzer makes a 6-7 second long beep error code. Thanks in advance for your answer.
Hello;
The "beeps" your motherboard is making is an error code, designed to alert you of an error in an essential system component, such as a memory failure, general motherboard failure, video card failure, etc. When a PC is started, no matter the brand, it goes through a POST (power on self test).
The types of beeps is a code, and is often system specific; changing from the manufacturer of the system BIOS, (BIOS; Basic Input Output System). If you know the bios mfg, you can get a POST error code chart for that specific manufacturer online... this will tell you what component is in question...
I do find it odd that you've changed a motherboard, without trying to change your keyboard! Seems like it would be easier to troubleshoot a keyboard issue, than swapping out a motherboard.
I don't know how fast your post code error is coming out, but if you don't know the mfg of your BIOS, it splashes it on the screen at bootup, or you can check your manufacturer's website.
May 06, 2010 | ASUS P4S533-X Motherboard
SOLTEK SL-65K2-CT Motherboard
The beep pattern is a beep code and is how the motherboard communicates errors during the early booting process otherwise known as the POST (Power On Self-Test). List restart the computer and listen for the pattern of short and long beeps. Soltek does not list the beep codes in their manual, instead they refer to Phoenix who manufacturers the AwardBIOS on your motherboard. There are only two POST beep codes; a single long beep followed by two short beeps (Video error) and anything else. Apparently anything else you hear *probably* refers to RAM problems. Since you?ve already tested both one of the remaining options is to install a *POST* card (about $30 to $50), boot the PC and read the hexadecimal error code for a more detailed clue to what failed. If you ask around you might find someone who has one and may be willing to loan it to you. Another option is to write off the motherboard since the cost of the test equipment it about 1/3 the cost of a new board. Let us know if you have any other questions and please don?t forget to rate the posing.
Jan 06, 2007 | Soltek SL-65KV2-T Motherboard
ASUS P4S533-X Motherboard Logo
251 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
