Question about Janome MyLock 634D Mechanical Sewing Machine
Janome left needle thread breaking CONSTANTLY
I have a Janome my lock 634D. The left needle thread seems to be caught by teh upper looper thread in front of the needle and then it will pull and eventually break. I am sewing cloth diapers and I was only sewing 2 layers of an OLD bathroom towel into a soaker pad... If I run it through just one layer it does fine .. Any ideas what teh problem is?? Am I just trying to serge through to many layers???? I had serged less than 10 inches and it happened about 6 times.. QUITE discouraging and frusterating.. I just had it serviced not long ago.....
  • 29 Answers
Sounds like a tension problem. Your machine should have two tension adjusters. One for each needle. The book that came with your machine will tell you how. Another possibility is a bent needle.
Posted on Feb 27, 2009
Can I just change the needle plate on my janome overlocker been told I need to have loopers reset
Sergers are funny things. You can certainly try just replacing the needle.... make sure you thread correctly. upper looper, lower looper, right needle left needle... etc.
Before you take off sewing... run the machine by hand a few revolutions if it seems to be moving with no more clunking etc. try to sew. If it breaks the needle again. Stop immediately and take it in.
Dec 02, 2012 | Sewing Machines
Adjusting tension on overlocker
overlockers and sergers are annoying in that every time you change materials and threads they must be re-tensioned.
Get a scrap piece of material. Thread your machine correctly according to the instructions in your manual. If no manual most sergers are threaded, upper looper, lower looper then needles from right to left. Make sure you thread with the presser foot UP.
You want to balance the stitches Begin by adjusting the looper dials, you want them to meet right at the cut edge. Then adjust your needles. Keep doing test seams until you have them balanced. If you are a novice... try threading with each thread point having it's own color. That will help you identify which thread is giving you fits.
Have fun.
Oct 15, 2012 | Janome MyLock 634D Mechanical Sewing...
My Janome 204d Serger won't form a chain stitch. It is threaded correctly. I have changed the needles??
I would suggest that you check the needles again, make sure they are both fully up into the needle housing. Also they should be at different heights in order to form the stitch sequence.
It is important that you thread the loopers first in the sequence shown in your manual, then the needles. So you may need to recheck the threading again and make sure the threads are in all the eyes correctly, especially the lower looper. Also some overlockers, have a sliding eye on the lower looper for ease of threading, if yours does, make sure it has been slid back to normal operating position.
When you have checked the threading up, take all four threads under the raised pressure foot and make sure that the upper looper thread and lower looper threads are not crossing over each other. Lower the pressure foot and try to chain off again.
I hope this helps you to resolve the issue.
Oct 11, 2011 | Janome MyLock 634D Mechanical Sewing...
I BOUGHT A USED JAMONE SERGER MY LOCK 634D . I DON'T HAVE AN USERS MANUAL. I DON'T UNDERSTAND HOW TO THREAD IT
Here is a manual - http://ifixmachines.com/Janome-Model-634D/View-all-products.html
The thread guide should be inside the door.
Lift the antenna and presser foot. Turn the tensions to zero, if possible.
Turn the handwheel so the upper looper is at the highest point - there may be a mark on the side of the serger to align with a mark on the handwheel.
Begin threading from the right to the left, beginning with the lower looper.
Mar 06, 2010 | Janome MyLock 634D Mechanical Sewing...
Upper looper will not saty trheaded to sew what
You have to thread the needles last.
1 - Take the threads out of both needles.
2 - Thread both loopers according to the diagram on your serger.
3 - Thread the needles.
If this fails, you need to bring it to a pro for service.
Feb 11, 2010 | Janome MyLock 634D Mechanical Sewing...
How do i thread my 434d overlocker i have forgotten the sequence i need to use
I scanned my manual for it, and it can be downloaded for free here.
The gist of it, is that you should do the lower looper first, upper looper, right needle, then left needle. From the front of the machine, this is starting with the rightmost holes on the threadguide plate, and finishing with the leftmost holes on the threadguide plate.
Jul 08, 2009 | Janome MyLock 634D Mechanical Sewing...
MyLock 634D won't serge
Check that your lower looper is actually threaded and not tangled with the upper looper (needle thread) when it moves. I wish they'd include pictures in the manual how to lay the thread.
Apr 05, 2009 | Janome MyLock 634D Mechanical Sewing...
The needles on my Janome 9102D keep breaking
I had a similar problem with my machine. What I've started doing with mine is setting the stitch length at 3 and the differential feed ratio at 1.0 then I set all 4 thread tensions at 3. I thread the machine from right to left, and then when everything seems to be working okay I take scrap material to test the tension and then set them to suit the material I'm using. Right now I'm working with a twill so my settings are 4-4-5-5. This seems to have stopped the thread slipping off the bottom looper and I haven't had any more needles break. I hope this is helpful.
Dec 02, 2008 | Janome Harmony 9102D Mechanical Sewing...
Lower looper
It is impossible for a looper to come unthreaded if you are holding one end and the other is still feeding off the spool. Somewhere a thread broke - must be either the upper looper or the needle. Try completely re-threading your machine. Many machines have an "order" they prefer to be threaded. Try starting from the right tension guide and work to the left.
Sep 17, 2007 | Janome MyLock 634D Mechanical Sewing...
Janome MyLock 634D Mechanical Sewing Machine Logo
205 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
