Question about Gigabyte GA-K8N Pro-SLI Motherboard
When I push the power switch nothing happens....
Hi , I'm Koen , i'm from Belgium, and i have the following problem with powering up my computer:
When I push the powerswitch of my computer nothing happens. It always went well before as long as I did not unplug it from the mains. (220v) . So last week i had to unplug it because i was installing some extra memory cards.(upgrade up to 4 GB) So when the cards where installed I pluged in the mains again and hit the power switch, nothing happened . Then i started unplugging some usb connectors , and plug them back in again , and hitting the power switch again , no use , until suddenly when i unplugged and reconnected a usb again , it started !!.
When i shut it down , the normal way , and tried to power it up again ,again nothing happend like before, so i did the trick with the usb connector again and it started.
So i thought the powerunit was not working ok , it was a q-tec PSU 450 , after reading on forums there where lots a problems with q-tec psu's , I bought a new psu, a corsairHX620W modular. I installed it , reconnected everything , double cheked , and then i hit the power button : same result as before , nothing happens. If i do the the trick with the usb, pull it out and back in again a few times , the computer starts up and works normal !!! so ....this is really driving me crazy ...
My motherbord is a GA-K8N-Pro Sli from Gigabyte,a couple a harddisk , Western Digital , amd x64 dual processor, nothing out of the ordinary, no overclocking or tuning.
I'm out of idea's to try , and the only thing i don't want to hear is that my MB is bad.....
Has anyone got any idea what might cause this problem ?? I had this problem once before i installed the extra memorycards , but after it restarted, with the usb trick, i could always restart it afterwards with the power switch in a normal way ,as long as i didn't remove the mains.
Now , i always have to do the usb trick everytime even when i don't unplug the mains....
....so , i'm getting a little bit desperate...lol
I hope someone has heard of this before ,or has a clue what might cause this erratic behaviour ?
So many thanks in advance for having read my story, and maybe provide a slolution...
Thank you.
  • 3 more comments
  • kope436 Feb 28, 2009
    hi,thanks for the respons, i already unplugged everything that is connected to the board so...i guess the problem is not there, but thanks for the hint.
    I will disassemble my pc and clean all the parts and try to look for some short circuits. Thank you also for this reply myjosh007 , i will let you guys know how it go's...
    Thanks again.
  • Anonymous Feb 28, 2009
    ok , yes, i don't use thinner it's too agressive , i have an industrial cleaner for electronic circuit boards that i use, so i cleaned the whole bord , took off everything except the cpu and cleaned and visualy inspected the whole board. Everything seems to be alright. After reinstalling the MB back into it's case ,i only connected the boot hdd and NO usb or other connection except for the powerswitch. I tried to power up the board but it doesn't work , so the cleaning job didn't help ! Then i cleared the cmos , took out the battery and shortend the pins, then tried again , no power up.
    So, ? has anyone have any sugestions i might try ??
    oww, sorry , the reply of the 1 other user is me !! Koen , I sent it the wrong way , but as you can read i did all you said and i still have the same problem, the board won't start , even with nothing connected....
  • Eric Lanning May 11, 2010
    BE EXTREMELY CAREFUL WITH LAQUER THINNER!
    If you are not careful you will destroy your motherboard.
    I personally don't think you need laquer thinner at all. Use at your own risk.
    It almost sounds like there is not enough power to the system. But you put a 620W into it.
    Do you have any USB Hubs attached? If so, how old is it? What USB devices are attached?
    Does the system startup good everytime, if all USB devices are unplugged? If it does, disconnect one device at a time. Eventually you may find that it is only one USB device that needs to be unplugged. It could signify that the USB device is having issues.
    Hope this sets you in the right direction.
  • 530 Answers
Hi im josh in cebu phils. may i help you? friend in your problem all i can say is there is a what we called short cicuit between your power source and the motherboard thats wy when you put the usb it will turn on normaly because your usb is the one igniting the powersource and it will not make the usb good because as time goes your usb is always at risk because it serves as the load. Friend mainboard is made up of many transistors capacitors, diodes and the IC or integrated circuit these IC is auto shut when there is a short circuit happening on your mainboard so thats why whn you turn it on it will the because the IC will shutoff because there's short circuit happeing. and every time you put the usb it will turn on because the usb will be the one to absorb the short circuit at will act as a load and thats the time your IC will work and the pc turns on. to solve such problem try to disassemble your pc.remove everything,and clean every parts of it. if you have the lacquer thinner that is the best solution for cleaning just put a little of it on the brush and brush the parts of your motherboard then after you let it dry for sometime then assemble it again. this will solve your prblem.we had tried this many times and it works. so try to do it. good luck hope i helped you.
Posted on Feb 28, 2009
Troubleshoot a Kenmore dryer motor pt. # 20065212
DO U HAVE THE SCHEMATIC? U HAVE TO FIND THE WIRES FROM THE DOOR SWITCH USUALLY YELLOW OR PINK? AND THE WIRE FROM THE START PUSH BUTTON, THEN FOLLOW THEM TO UR MOTOR AND CONNECT UR POWER TEST LEADS TO THEM , U CAN START IT WITH THE BELT AND DRUM CONNECTED JUST TO SEE IF IT RUNS/
Feb 28, 2015 | Kenmore Dryers
When I turn my Garmin 550 on it says loading maps, then goes to the select a local: It's frozen their on United States i push OK and nothing happens can not change the Locale it's frozen I tried...
Hi tkfranks331,
Press the power key and hold it if the screen of your Zumo is frozen. Keep holding the power key while pressing the key that has a plus symbol ("+") on it. This will reset your device and unfreeze the screen. You can also try calibrating the screen by pressing the power key for one full minute.
If this does not work, please follow these steps.
1. Update the internal disk software. Download and install WebUpdater on the computer. Please visit this link to download the WebUpdater.
2. Open WebUpdater on the computer.
3. Connect the Zumo 550 to the computer with its USB cable.
4. WebUpdater will automatically search for updates.
5. Follow the prompts to download any pertinent updates for the Zumo 550.
Hope it helps.
Thank you for using FixYa.
Aug 17, 2011 | Garmin zumo 550 GPS Receiver
Hi, my laptop wont turn on, can u help me?
Sure--if it doesn't turn on, assuming that when you push the power switch absolutely nothing happens, then your battery may be dead. If your battery is dead, you have to plug it into your power adapter. If that doesn't help, make sure there is the correct voltage coming out of the power adapter. Should be 18-19 volts.
If you are actually getting power to the computer and when you push the on/off button nothing happens, try this: unplug the power adapter. Remove the battery. After about 30 seconds hook it up again. Try it with the battery in and the battery out.
If you still cannot get it to turn on, then most likely the CD-in jack is bad or the motherboard is bad.
var fctb_tool=null; function FCTB_Init_be2d215e7e464c6ca04a88c8984f8df7(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_c1ebbb20a62340b2ba7706697e37264d(t) { fctb_tool=t; start(fctb_tool); }
Dec 12, 2010 | Toshiba Computers & Internet
I push the on button and nothing happens. is it
Even though a lot of things might have gone wrong and caused this, especially if where you place the System is not well ventilated, and the CPU becomes very hot, it shuts down automatically...and you will have to wait for a few moments, get a cool environment and power it on. but I will also try and tell you some troubleshooting steps that you can try.
Since you have already checked the power source and all is Ok, then try this out:
Disconnect your PowerPack(Power Supply Unit) from the CPU and try to power your PC with another Power Pack (Power Supply Unit), that you are very sure is working.
If it powers up, then just get a new Power Pack(Power Supply Unit) for system.
If you cant do this yourself, just get a good technician to do it for you.
Try this first and let me know how it goes, so as to know the next step.
Hope this helps.
Nov 21, 2009 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
Compaq proliant 5500 server wont power up
In my experience when a server/computer does absolutely nothing when the power button is pressed it is a dead processor. That may not be the case in your situation. It could be as simple as a defective power switch. Is the switch a soft touch or does it push in and click? Does the switch feel normal when pushed? One of the power supplies could also be bad. Do you have any good power supplies to test in the server? Were there any power outages recently that could have caused damage to the PSU? I would start with checking the switch. You could hook up a circuit tester and see if the switch completes the circuit when depressed. Also take a look inside the server and look for any loose connections on the mainboard. It is possible the wire for the power switch has come loose.
Sep 05, 2009 | Compaq ProLiant 3000/5500 Redundant...
CX200X worked fine yesterday, now I am unable to turn the power on to the laptop. I have power through the adapter to the connection to the computer. I have a full battery charge light indicator. When I...
make sure the power lock button on the lower righthand side is in the UP position.
it locks the computer into the OFF state if it is switched DOWN after powering down.
Jun 17, 2009 | Gateway CX200X Tablet PC
Viewsonic vx910 19" lcd do not start
Hi...there,
It's seems you've got a busted backlight inverter...
Nov 29, 2008 | ViewSonic VX910 19" LCD Monitor
New acer 19 " moniter plug in will not turn on ?
Try other outlet, check the power cord if it contacted the monitor. If nothing happened, maybe it's factory defect, since it still under warranty, you can still change it.
Thanks
Nov 09, 2008 | Acer AL1717 17" LCD Monitor
Cruzer micro 2GB
try in applications, the utilities folder has disc utilities using this try partitioning the drive then verifieing it.
Sep 22, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
No power
check ur smps and power connector Mother board ok
next power switch for on/off ok check front panel byy
May 17, 2008 | Intel Motherboard
Gigabyte GA-K8N Pro-SLI Motherboard Logo
255 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
