Question about Kenmore 24032\24036 Top Load Washer
Kenmoore Top Load Washer: Model #LSQ9645
Unit stops at rinse cycle; does not empty out dirty water
  • MarkFuller Mar 01, 2009
    Well done! That is exactly what the problem was. It was a $40 parts fix with a total drive time of an hour to Sears and back (part in stock) and about 20 minutes of fix time. You saved me some bucks!! Thank you very much.
  • Anonymous Mar 01, 2009
    washer will not spin dry
  • Kenmore Master
  • 8,220 Answers
That is the lid switch most likely.
Kenmoore Top Load Washer: Model #LSQ9645 - a462c91.jpg
Posted on Feb 27, 2009
Washer fills with water during spin cycle
Go to and have model number ready. They have videos how to check it
Mar 02, 2015 | Samsung WA422PRHDWR 4.2 cu. ft Large...
Washer stops in rinse cycle
your contacts swithces for rinse cycle inside timer could be burned or bad..very model I will locate part number
Dec 15, 2007 | Washing Machines
Rinse and spin cycle keeps repeating at 11 minute time to 17 minute time and won't stop
Sounds like your washer does not empty enough water for the spinning to stop. Have you check that the filter(s) are not clogged?
Jan 23, 2013 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
Water will not empty from the wash cycle and go into rinse cycle.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
If the hoses are fine (make sure that the outlet hose leading to the drain or wash basin isn't clogged), check the shaft from the motor to the pump ( make sure that the pump turns) and check inside the pump to make sure the inlet and outlet aren't blocked.
May 27, 2010 | Kenmore 24032\24036 Top Load Washer
My washer will not empty rinse water to begin spin cycle
i believe you have a lid switch issue..if you unplug machine and find the wires to the lid switch. you can connect the wire together..this will make it continue if its the proble. if it is make sure you secure them real good...
May 20, 2010 | GE WWSE5240D Top Load Washer
Washer does not fill quickly for rinse cyle
check your water pressure if its good check the valve on the back of the washer to see if anything is stopping it up . you may have to replace the water valve
Mar 29, 2009 | GE WBSE2090A Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
78 people viewed this question
Sal De
 Brian Main
Brian Main
